E & GW Bartholomew Clock weights & pendulum
Discussion in 'Wood Movement Clocks' started by Richard Kennett, Apr 6, 2017.
  1. Richard Kennett
    Richard Kennett Registered User
    May 30, 2014
    10
    [​IMG][​IMG][​IMG]
    Today, a client brought in this clock, gained from an auction and missing parts, and would like me to provide him with new weights and a pendulum. Does anyone have any photos or drawings of what they are? Does anyone know the weight or length of the weights, or the pendulum. Thanks?
  2. R. Croswell
    R. Croswell Registered User
    6,544
    17
    The original weights would likely have been a bit larger than "OG" weights typically 3 to 3.5 lbs. but if your clock is in good condition it may run OK with 2.5 to 3 lbs. Here is a picture of a similar clock by a different maker with about the same movement showing a typical pendulum and weights. The style of the pendulum may differ but the size should be about the same. A closer determination of length can be calculated if you count the teeth on the wheels and pinions in the time train. Or start long and trim the leader until it keeps time.
Similar Threads - Bartholomew Clock weights Forum Date
Hoping to learn about this clock please... Wood Movement Clocks Mar 7, 2017
Unusual wood works mirror clock Wood Movement Clocks Mar 5, 2017
Questions about ivory bushings in Eli Terry shelf clock Wood Movement Clocks Dec 8, 2016
Atkins and Downs 1830-33 clock label needed Wood Movement Clocks Dec 2, 2016
Questions about Barnes and Bartholomew Clock Wood Movement Clocks Dec 14, 2015
