E clips for Schatz cuckoo
Discussion in 'Clock Repair' started by Schatz70, Oct 21, 2019.
  1. Schatz70
    Schatz70 Registered User
    Oct 5, 2019
    72
    I broke an E clip for my Schatz 8 day cuckoo (small one that holds on the rack) and am trying to figure out what to order on Timesavers.
    Timesavers
    How do I figure out what to order? Timesavers has a bewildering list of choices here. The post on the front of the front plate that the rack goes on is about 2.5 mm in diameter and there is a groove cut into it to accept the E clip that is a tad smaller than that. The outside diameter of the circle on the front of the rack that the E clip fits into is about 5 mm in diameter.
    Thanks in advance for any help.
  2. Willie X
    Willie X Registered User
    11,575
    581
    A twisted piece of the correct size soft iron (or brass) wire will work just fine. This part has no lateral forces. Willie X
    Schatz70 likes this.
  3. Schatz70
    Oct 5, 2019
    72
    Thank you!! I spent a couple of minutes trying that with a small piece of wire and I think it will work. I was afraid that the wire would cause friction preventing the rack from dropping, but it doesn't seem to.
  4. R. Croswell
    R. Croswell Registered User
    9,115
    470
    Make sure you have at least a small amount of end play after the wire. If you are going to fool with clocks made after about 1950 just get an assortment to have on hand. These things seem to take flight if you look at them.
    Kevin W. likes this.
  5. Schatz70
    Oct 5, 2019
    72
    They are easy to lose and it seems like they can only be reused a certain number of times before they break. I ordered an assortment of 100 "made in India" from Timesavers today in hopes that some of them will prove useful.
  6. shutterbug
    40,141
    605
    The India made parts are notorious for poor quality and short life. I'd get a set of Hermle e-clips. The work on lots of things.
  7. R. Croswell
    9,115
    470
    There seems to be two kinds - those made from spring steel, and those that are common steel that do not "snap" in place and have to be squeezed closed. This sort of stuff from India is often disappointing.
  8. R&A
    R&A Registered User
    Oct 21, 2008
    4,107
    81
    In an emergency you can rap a thin piece of wire around the slit where the clip goes. If the part can't slip off you are fine.
  9. Schatz70
    Oct 5, 2019
    72
  10. bangster
    bangster Moderator
    19,037
    285
    As a couple of people have said, get an assortment.
  11. Willie X
    11,575
    581
    It's easy to make an old school 'split washer'.
    Just make a small washer of steel or brass shim stock, a little thinner than the groove. Punch, or drill, the hole slightly larger than the necked down part of the groove and split it with a thin cut-off discs, or snips. The slot, or split, needs to be a little smaller than the neck of the groove.
    Note, when making small washers, it's much easier to drill or punch the hole before punching, or cutting, the washer out of the stock.
    Just lightly force it on and your done. If it seems a little loose, squeeze the split washer slightly at the center with pliers.
    You can also make small external push on spring clips from spring or piano wire. On these the wire needs to be a little smaller than the groove is wide. The wire goes completely into the groove with purchase at both sides. Look at the pins used on farm and yard equipment hitch pins for a model.
    WIllie X
