DST question, are there any inexpensive digital wall clocks that connect via wifi or ethernet to set time?
miamaelia
Oct 3, 2021
13
I'm in a metal building so wifi works fine but the time signal from colorado does not. So twice every year I go looking for something that works off ethernet or wifi.
AFAICT about the only reasonably priced option is to just wall mount an echo show or google home hub.
Does anyone know of any better options? Something with a bigger display that would also display the date would be nice.
16,272
2,485
Any big clock should be fine. They usually run within about 30 seconds in 6 months. So, you only have to do one reset between battery changes which needs to be done yearly. Easy peezie.
Cheezhead
Dec 30, 2010
235
26
Wisconsin
Would a 7" Amazon Fire tablet be large enough? These can be found for $30 (used) to $50 on ebay although I got mine new on sale for about $30 at a BestBuy a few years ago. I can't recall if you must sign up with Amazon (no need to provide your charge card) to access the app store. There is a free, large digit clock app with date. If you want it on a wall, some sly way of doing that (cheap picture frame?) will be needed as well as a wall wart, USB cord and an electrical outlet.
EscapeWheel
Mar 19, 2003
540
102
Amazon has a large digital wi-fi clock - West Ocean Digital LED Wall Clock.
"Built-in technology to use WiFi to connect to a standard Internet time server. With this feature, it maintains current time automatically without intervention."
16,272
2,485
"Without intervention" is usually good but ocasionaly it's very bad ...
173,738
1,517,029
51,916
JT123
1,062
2,969
