double weight movement
Discussion in 'General Clock Discussions' started by info@antiquity.in, Mar 10, 2017.
  1. info@antiquity.in
    info@antiquity.in Registered User
    Feb 5, 2017
    11
    Business
    INDIA
    hi, i just got double weight driven very heavy movement. i have restored the movement and also made the dial. now i wanted to make the case- can anyone help me in making and designing the appropriate case? and i would also like to know the approx. mfg. year of this movement. regards/ Raj
  2. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    890
    Tennessee
    Hi, Raj,
    Great restoration job-I'll bet it was a LOT of work! Can't help much here, but if the Phillips screws on the movement are original, it would mean that the movement could not predate the early 1930s. Others will be along with more detailed information. Nice, heavy movement. Should be a reliable timekeeper!
    Best,
    George Nelson
  3. leeinv66
    leeinv66 Super Moderator
    NAWCC Member Donor
    Mar 31, 2005
    8,033
    12
    Industry Specialist
    Launceston Tasmania
    They are some quite interesting modifications you have made to that movement Raj! That rack is quite unique. What are you driving with all those auxiliary wheels that are drive off the motion works?
  4. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    The screws, I think, are modern replacements. I'm not sure what all the motion work does but the basic movement design is like an English longcase though difficult to date as from the mid 18th century until their demise there wasn't mufch change in style, we normally look at the dial and case if available. some of the detailing suggests earlier rather than later to me.
  5. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    Hi George, Thanks for your reply. Oh sorry, that 'phillips screws' which you see on the front top of the movement are new replacement my myself during restoration. The last 2-pix are the original movement pix taken before restoration. And the first 2pix are after restoration. Yes, this movement is now under observation and keeping good time.
    Raj
  6. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    Hi, I got only the movement. so i do not have any idea of the dial. in india it is too difficult to find the actual / original design of such old clocks. we have to guess a lot and keep on experimenting. till now the movement is working perfectly OK, except the weights, both the weights descending at different speed. the weight driving the movement descends faster than that of the striking bell.
  7. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    regards/ raj
  8. George Nelson
    Oct 5, 2007
    890
    Tennessee
    Thanks, Raj! Glad the clock is running well!
    George
  9. ragobo
    ragobo Registered User
    Apr 14, 2015
    197
    sales consultant
    Barcelona
    Aparently both weights should descend more or less the same amount, at least after 7 days of working. Does it strike only the hours? Some clocks also strike once at the half hour.
    Please could you post a pic of the dial you made? I think that would be a hint on what stile of case would suit it best.
  10. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    yes, over a 24 hour period they should both drop about the same. It looks like an English movement for a longcase, a half hour strike would be rare though I have one so they do exist. If the weights are not descending evenly it does suggest that there is something missing that was there originally.
  11. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    961
    Carson City, Nevada
    On the unrestored image the large wheel on the front of the plate has a cog or flag which is not present on the pictures of the restored version. Based on tooth counts - as best I could do from the pictures - I believe the large wheel is a 24 hour wheel to move a calendar dial. This then drives a 12 hour wheel which is then reversed at the very top. This would also have had a flag to turn a Moon dial. If you google calendar Moon dials you will see a few examples of these in Grandfather clocks.
  12. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    If you can find an older moon dial, they will have 118 teeth. That can be driven
    from the 30 tooth wheels.
    If you use a newer dial, the moon wheel will most likely have 59 teeth. You can
    drive that one from same wheel that drives the calendar.
    Of course, if you make your own, you can do 118 teeth.
    Does the movement have a recoil or deadbeat escapement.
    If a deadbeat, that would set a no older than date.
  13. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    I'm not convinced that all applies if this is an English movement. 59 tooth moons are found on clocks much older than this movement though usually on 30 hour movements. Halifax moons (axe head shaped apertures on square dials) have 59 teeth and are found on 8 day movements.
    Deadbeat escapements date back to the beginning of the 18th century in longcase clocks which is likely 100 years before this movement.
  14. Tinker Dwight
    13,680
    I only meant that 59 teeth have become standard on on movements within the last 50 or so years.
    Both have been used for a long time but 118 tooth simplified the number of wheels need.
    Plastic wheels have made the 59 more popular.
    Obviously, both existed earlier. My comment was more related to the purchasing of a dial.
    My statement was directed to the fact that he could use either, not as a dating of the movement.
    You are most likely right about the fact that deadbeat were most likely uses 100 years before this movement
    was made.
    I should have separated the statements.
  15. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    oh I see, sorry I was still thinking about the movement. I think he said he had made a dial now, but we haven't seen any pictures yet.
  16. Tinker Dwight
    13,680
    Ah yes, I read it fast and thought he needed a dial.
    I see now it was just a case.
  17. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    hi everybody, i am sorry by mistake i posted the wrong pix (one with 2-additional wheels on the Date Wheel) this design i had to cancel as i thought it won't be suitable. please see the pix attached with this message which is the final pix and also the dial. you will notice that i have kept the date wheel 'as is' one with the flag to move the date. this wheel has 60 teeth. the clock strikes every hour. keeps good time. after restoration (28).jpg WP_20170313_11_49_37_Pro.jpg
  18. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    hello everybody, the clock strikes every hour. the pix one which i had posted in the beginning with 2-additional wheels i have discarded and have kept the original date wheel with the 'flag' it has 60 teeth. i have attached the final pictures of the dial and the front part of the movement.
  19. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    Looking good, is the dial engraved, you could silver the chapter rings.
    Why 60 teeth? They are usually either 31 or 62 to cover the months with 31 days.
  20. ragobo
    Apr 14, 2015
    197
    sales consultant
    Barcelona
    Hi Nick, would you counsel to silver the chapter ring on this occasion? for me it looks wonderful as it is!
    Really nice dial, hope someone could help you with some plans to build a period tall case. I think you did a marvelous work with that old movement :)
  21. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    I would, yes. I would silver the chapter ring and the two subsidiaries, if the date ring is brass I'd dso that too. It sets off the numerals really well and makes the dial easier to read.
    EDIT> BTW as the dial plate is not arched you could make a flat top style with an arched mask and door
    https://www.the-saleroom.com/en-gb/auction-catalogues/tennants-auctioneers/catalogue-id-srten10285/lot-d35b97be-5147-425e-b569-a5fe012540ca
  22. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    961
    Carson City, Nevada
    Beautifully done :)
  23. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    You are very correct i am going to make a silver ch.ring and also the date ring in brass. Can you give me some idea of it's age?
  24. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    Silvered hopefully not silver. You may find that a better shape to the internal teeth on your date wheel might help, all of mine like that have teeth like shark fins.
    We did discuss date earlier, the same design of pillar and plates was used for over a century with little change but the detailing on your wheels suggest earlier in the period rather than later, I think late 18th early 19th century is as close as I could get.
  25. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
    In the beginning all went like an experiment but now when the design is getting finalised i will replace the date wheel with brass and fig. etched on it with sharp teeth.
  26. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    It seems like a very worthwhile experiment, it all looks very good.
  27. info@antiquity.in
    Feb 5, 2017
    11
    Business
    INDIA
Similar Threads - double weight movement Forum Date
waterbury double-weight movement id and info? General Clock Discussions Apr 19, 2016
Gustav Becker Double Weight Austrian/German Regulator Wall Clock General Clock Discussions Jan 28, 2015
Double Weight Regulator ID and Sub-dial Hand Replacement General Clock Discussions Jan 13, 2013
ST Office#1 Double Dial - Weight/Pulley???? General Clock Discussions Jun 13, 2009
Clock With a Double Weight? General Clock Discussions Mar 3, 2009
