Double Roller File Rest
Discussion in 'Horological Tools' started by TEACLOCKS, Apr 27, 2020.
  1. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,317
    77
    Clock service & repair
    Santa Rosa Calif.
    What do you use for a "Double Roller File Rest" or single roller, for your Sherline lathe ?
    Did you have to manufacturer one or doe's sherline have one of there own ?
    Could you show some pictures ?
    Thank you for the help
    Lloyd
  2. gmorse
    gmorse Registered User
    11,257
    1,568
    Retired from Xerox
    Hi Lloyd,
    Those rests are for filing a flat or a square on a work piece such as a winding arbor.
  3. David S
    David S Registered User
    Dec 18, 2011
    7,195
    245
    Brockville, On Canada
    Lloyd,
    Here are some pictures.
    side view close 2.jpg guide in use.jpg Those are two needle bearings on home made shaft.
    Added a guard to protect the jig.
    David
  4. shutterbug
    43,172
    1,184
    I'll move this to the tools forum ;)
  5. R. Croswell
    R. Croswell Registered User
    10,223
    830
    This is the one I made. Three small ball bearings from www.mcmaster.com 1/4" square brass stock, cap screw. If I make another one I would consider using four bearings to accommodate a wider file.
  6. motormaker
    motormaker Registered User
    Apr 5, 2010
    102
    11
    Tucson, AZ
    And here is one that I made utilizing readily replaceable oilite bearings...
  7. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    2,109
    762
    Watchmaker
    Baltimore
    A single roller rest is preferred by many, such as the one made by RC.
    The double roller is not used to straddle the work anyway. I have seen people struggle with this trying to create a minute adjustment for getting the right dimension. Whether you use a single or double rest, it goes outside the workpiece and you have to watch the witness of the marks and measure frequently. I use a permanent marker on the work surface to help me control taper.
    Assuming you are filing a square (and are removing 1/2 the required material to get down to the square if you do not move the filing rest you will wind up on the same file angle at the finish cut and the sides will be parallel. It is geometry.
    The secret is to use a one piece t-rest holder, not a hinged one.
  8. dave-b
    dave-b Registered User
    Jul 28, 2010
    40
    #8 dave-b, Apr 28, 2020
    It is worth considering mounting the roller axles at a slight ( 5-10 degree) angle from the horizontal. This allows for fine tuning the depth of cut by advancing/retracting the cross slide.
    Dave.
  9. dave-b
    Jul 28, 2010
    40
    My last post was misleading. I meant adjust the rollers so that one is a little higher than the other so the file is at a 5 - 10 degee tilt. Then fine tune depth of cut with cross slide.
    Dave.
  10. DeweyC
    Feb 5, 2007
    2,109
    762
    Watchmaker
    Baltimore
    Seriously, do not overthink this. It is not hard to learn how to file, measure and control taper. These are such an essential kit of skills to learn that most watchmakers do not bother milling out a stem.
    But if these are not skills you will use on a regular basis, then taking the time to setup for and learn how to mill may be more useful.
  11. Dushan Grujich
    Dushan Grujich Registered User
    Jun 20, 2003
    607
    45
    Watchmaker
    Bondi
    G'Day Dewey!
    I would say that it is not only a question of skill. Myself, at times, I have encountered a problem of procuring - buying quality files, they require replacement since they do not last forever. It is much like with sawing metal, particularly steel that is not annealed, even brass. If one has high quality fret saw blades it is easy to keep sawing in a straight line, but if one can get only cheap saw blades? Having access only to cheap blades, I dare You try and saw in a straight line regardless of the skill level. It is the same with files, I am certain that You do know difference between say Valorbe files or Sandvik files against the no-name ones. Everything comes at a price.
    In some cases and under some conditions it may be faster and easier to mill.
    Cheers, Dushan
    DeweyC likes this.
  12. DeweyC
    Feb 5, 2007
    2,109
    762
    Watchmaker
    Baltimore
    Dushan.
    Absolutely!
  13. Jerry Kieffer
    Jerry Kieffer Registered User
    May 31, 2005
    2,618
    337
    wisconsin
    Lloyd
    When I purchased my first Sherline Lathe, I made an adaptor that allowed me to mount Watchmaker lathe tool rests on the Sherline thus various tools that came with the rest such as a file rest.
    I quickly learned that a Sherline lathe is a machine tool lathe and not designed as a fixture to assist hand work. Once I started using it as a machine tool, things I had done previously by hand, no longer had any appeal since they could be machined more accurately and efficiently in less time.
    One quick example would be the construction of a replacement winding stem as follows. While this can be done on either a lathe or Mill, I will give a brief explanation of the Lathe procedure since you asked about the lathe.
    (1) Square stock would be mounted in the Lathe using a self centering four jaw chuck and major diameters machined per the first photo.
    (2) The second and third photos show machining the square to size with a Endmill. Square stock was selected to be used as a square index in the tool post. Each flat is machined and the stock is rotated in the post. Size of the square is pre determined by hand wheel settings with the same accuracy as turning round stock. The lathe assures that the square is square, centered and non tapered. Winding arbors that have a slight taper such as some clocks and rare occasions in watches are easily duplicated by rotating the tool post slightly.
    (3) Once the square is machined, the stock is returned to the chuck for remaining machining in the normal manner. Before removing the square stock from the chuck, the flat being held by the "A" jaw or any jaw was marked and returned to that jaw to assure the stock runs true.
    The fourth photo shows the Adaptor I made for mounting a watchmakers Lathe rest on a Sherline.
    Fifth photo shows the rest mounted.
    Jerry Kieffer
    fullsizeoutput_58c.jpeg fullsizeoutput_58e.jpeg fullsizeoutput_58f.jpeg fullsizeoutput_591.jpeg fullsizeoutput_590.jpeg
    wefalck and Old Rivers like this.
