• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
DOMINANT P/WATCH MOVEMENT, help please
peter hurst
Aug 15, 2006
121
HELLO,
I have a pocketwatch movement marked DOMINANT A I , 17 jewels, swiss made , 5 adjustments,
Has anyone heard of this movement, it looks to be of fine quality,
I am thinking of recasing it into a silver case, what do you think.
Wrist watches are my interest, and I know nothing of pocket watches, but I am asuming that the 5 adj is a mark of quality,
Thankyou Peter.
CZHACK
Apr 28, 2005
711
Peter,
Share a photo of the movement and someone may be able to help. If Swiss, your maker may also be listed in the reference book on Swiss makers by Pritchard. I will look it up when I return home in a week and let you know.
Mike
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
2,274
1,736
72
Pasadena
Pritchard does not list "Dominant."
Dr. Jon
Dec 14, 2001
6,193
670
New Hampshire
I too suggest a photo. One way to get one if you re not familiar with close up photography is to use a scanner.
If a watch is marked "adjusted" it is probably pretty good. The US had a serious tariff on adjusted watches. Only watch of high enough quality to sell at a premium are likely to be marked.
Five adjustments is a bit on the low side. They would likley be heat cold dial up dial down and pendant up, although isochronism could replace a position adjustment. The top grade is eight.
