case Disassembly Does this bezel come off?
Discussion in 'Watch Repair' started by PWR_family, Aug 31, 2020.
  1. PWR_family
    PWR_family Registered User
    Jun 5, 2016
    54
    14
    West Chester, PA
    Trying to remove movement from this Tissot as I need to adjust hands and can't seem to figure it out
    Does the bezel come off and movement come out the front?
    thanks
    Steve G
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    4,871
    510
    watchmaker
    Did you take the crown off?
    Can you show photos of the back of the watch?
  3. 179
    179 Registered User
    Sep 16, 2008
    655
    185
    What do you believe is wrong with the hands? Is something hitting?
  4. PWR_family
    Jun 5, 2016
    54
    14
    West Chester, PA
    YES -- stem is out
    YES - case clamp screw is out
    and here is a photo
    thanks for any help
  5. roughbarked
    Dec 2, 2016
    4,871
    510
    watchmaker
    Did you remove the case back seal?
  6. PWR_family
    Jun 5, 2016
    54
    14
    West Chester, PA
    Guess I’m not sure what a case back seal is.......
  7. roughbarked
    Dec 2, 2016
    4,871
    510
    watchmaker
    The "O" ring that sat in that groove around the case under the back. Is the back a snap on back or a screw back?
  8. PWR_family
    Jun 5, 2016
    54
    14
    West Chester, PA
    The back is a snap back
    And yes I removed what I call the gasket
    the movement seems locked in by something so I’m wondering if bezel comes off and it is removed from the front....
  9. roughbarked
    Dec 2, 2016
    4,871
    510
    watchmaker
    Put the seal/gasket in and the back on and try an empty syringe that fits over the pipe. Use air pressure created by sitting the extended syringe on the bench so when ready you can push down on it with the pipe fitted into the syringe end. Push down firmly and quickly. The crystal should pop out into your hand.
  10. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    2,283
    880
    Watchmaker
    Baltimore
    I have been reluctant to get involved because I have not done Tissots. BUT:
    The movement is round and held in by case clamps. The dial is rectangular an is larger than the movement. It is also larger than the bezel. Odds are it comes out from the front.
    Without it in hand and motivation to call some colleagues, I look very closely on the side opposite the crown. Many bezels can be removed by putting the crown into a hole in the bench block and tapping a single edge razor blade into the joint at 9 o'clock.
    I am not saying what you "should" do other than to find someone who has had this case. But the 70s was an era of seemingly mean spirited efforts to make the life of a watchmaker hard.
    roughbarked likes this.
  11. PWR_family
    Jun 5, 2016
    54
    14
    West Chester, PA
    I can see them hitting
  12. roughbarked
    Dec 2, 2016
    4,871
    510
    watchmaker
    There is only one way to fix that.
