Karl & Geo-ulrich
Karl
Geo hit the nail on the head when he suggested time as the real issue. While the stand alone CNC R/T I mentioned is actually a "convenience", it is the convenience that makes the situation practical.
For myself personally, the selection of methods and equipment with the compatibility and versatility to readily configure themselves in ways that allows work to be done in a timely fashion was a major turning point. The wheel in the photo in my last post is a good example.
In this case it was for a early rare Howard as I recall with no available replacement.
First, I did not have the proper cutter on hand, so the one shown was machined and hardened (Not ground) in about 20 minutes as publicly demonstrated many many times.
Next, solid bar stock was placed in a Lathe chuck screwed to the R/T mounted vertical on the Mill. The R/T was place in continuous motion where the stock was faced off with an Endmill and the OD was machined in less than five minutes.
No time consuming Arbor/Blank/setup was required. In five minutes I was ready to cut teeth.
Because the stock was mounted vertical and the headstock is readily able to rotate vertical or horizontal, the cutting process is always very clearly visible saving a ton time. Once the teeth are cut with the headstock horizontal, it is then changed to vertical to allow the crossing to be machined with the assistance of the R/T and rotation positioning for straight cuts with a .020" endmill in this case. Cuts are quick, highly accurate, and very clean with little of any cleanup required.
When complete, the chuck and stock are moved to the Lathe where the wheel is parted off. The center hole can be drilled/bored before or after parting.
All in all, the cutter is 30 minutes max. with the wheel at about two hours. As such, it becomes part of the repair process rather than an extra.
My first watch wheel was done on the traditional multiple belt and pulley arrangement at about two days and was not happy with the results.
Jerry Kieffer
