Do you see what is WRONG ??????
bruce linde
10,476
2,208
oakland, ca.
clockhappy.com
easy fix... just file down some the screw-head until there's enough clearance... don't even have to take it apart. :)
Reactions: Dave T
Schatznut
Sep 26, 2020
1,343
687
SoCal
I give up - what? Too much WD-40? Man, I'd be afraid to take that barrel apart, for fear it would come apart like a grenade.
bruce linde
10,476
2,208
oakland, ca.
clockhappy.com
The barrel… The screw on top is binding against the arbor above it. Definitely one for the hall of shame.
wow
Jun 24, 2008
6,746
1,143
77
Pineville, La. (central La.)
The "repairer" is supposed to have cleaned it? All needs dismantling, cleaning properly and fitting a proper barrel hook.
And getting a refund!
Awe, Mike, All you have to do is file off that screw head and wash away the shavings and other gunk with a good spraying of WD-40 and it’s done, right? Only cost is the $5.00 for the WD-40. Then you’re ready to print business cards.
Schatznut
Sep 26, 2020
1,343
687
SoCal
I was being sarcastic, Bruce. Hence my comment about the barrel blowing up. No telling what other bodge work will be found when it's disassembled.
Bernhard J.
Jan 10, 2022
1,021
1,072
Berlin, Germany
You need only about 100 ml for complete lubrication of the whole movement, so $3 should be sufficient. clown.gif
Alternative and instantly done: do not file down the srew head, instead hammer it deeper into the barrel with a few blows, done clown.gif
  • Love
Reactions: Schatznut
wow
Jun 24, 2008
6,746
1,143
77
You need only about 100 ml for complete lubrication of the whole movement, so $3 should be sufficient. View attachment 727794
Alternative and instantly done: do not file down the srew head, instead hammer it deeper into the barrel with a few blows, done View attachment 727794
Yes, your probably right about 100ml for that clock. That would get it “dripping clean”. But what about a grandfather movement with three trains? Or a Hershede tubular chime. Big can! You could clean the tubes too.
Reactions: Bernhard J.
Mike Phelan
Dec 17, 2003
10,957
366
West Yorkshire, England
I could have made a fortune! :chuckling:
R. Croswell
12,056
1,942
www.greenfieldclockshop.com
When a barrel is bulged out like that, it is a sure sign that the spring "let go" suddenly. Can't tell from the picture, but that second arbor may very well be bent a little causing the screw head hang up. Needs to come apart for complete evaluation and a good bath.
Mike Mall
Oct 27, 2021
421
142
These guys all missed it.
The problem is --- there's a finishing nail holding the dial on.
How long of a test run could the last repairer gave given it?
Reactions: Jess19721
Schatznut
Sep 26, 2020
1,343
687
SoCal
Pity, would love to see what is holding the screw in place, most likely nothing.
At the risk of losing an eye or a finger? :chuckling:
Reactions: JimmyOz
17,443
3,171
You can bet there is a nut on the other side of the spring.
Guess the test run wasn't very long though!!!
Hopefully he didn't charge 300 bucks for this masterpiece.
JimmyOz
Feb 21, 2008
1,251
388
67
Gold Coast Qld
Hi Willy,
Gave me a laugh about the $300, I sometimes wounder if we are doing the right thing by informing some people how to do things and the next week they are setting up as clock repairers. :?|
Reactions: Willie X
Schatznut
Sep 26, 2020
1,343
687
SoCal
Hi Willy,
And what idiot informed the rocket surgeon that performed this abomination?!
JimmyOz
Feb 21, 2008
1,251
388
67
Gold Coast Qld
It has to be his own work, a little knowledge is dangerous.
The $300 charged is from another thread on here
Schatznut
Sep 26, 2020
1,343
687
SoCal
I sure hope so. Foisting off this disaster on someone else is just short of criminal!
demoman3955
Apr 9, 2022
469
134
66
There are a lot of things i wouldnt do to a clock, and im good at figuring out ways to do things, that are hacks on cars, i just cant on a clock. Ive put together demolition derby cars using a lot of strange things to get them to run again, but for some reason ive never thought about is why the difference between cars and clocks...
Raymond101
Jun 25, 2022
116
14
69
Wow I am only a amateur. I spent 5 minutes looking at those photos with my mouth open .
Not only the screw head. And the nail which the other end pressing on the front plate.
The face is out of alignment bent down and the cock between rear face and just above the spring shaft is bent . Bottom pin is snapped off . & cleaned never the rust is still visible.
This has enough wd might be worth recycling.
That bulge, that could be the nut on the inside drum,, plate nut .
Return to sender .
Schatznut
Sep 26, 2020
1,343
687
SoCal
Aww, come on guys, all of that stuff can be fixed. The hard part will be locating parts for the missing strike train!
Wait, I'm sure I've got the correct strike train parts in my junk box somewhere!
177,457
1,555,189
53,575
dlfuller
909
3,053
