Do I need both bushing systems?
Vernon
Dec 9, 2006
1,077
148
I use the KWM system and have since I started repairing. For the first time, I encountered the need to replace a few bushings and they happened to be of the KWM persuasion which was very easy to pop out the old worn one and insert the new. I know that it is a matter of time before I'm faced with a worn Bergeon bushing but I have no tools for this system. Should I plan on buying into this system? What did you do?
Thanks, Vernon
47,341
2,124
Need is probably not the word. But a few of both types is usually a good thing. Especially when you are replacing a formerly placed bushing.
Vernon
Dec 9, 2006
1,077
148
What you guys have said makes perfect sense, I wouldn't need the reamers if I'm just replacing the bush itself! I guess that I'll wait then until the need arises. Thanks everyone
Sincerely, Vernon
14,744
1,733
The need will arise when you work on a clock where the hole has elongated to a point where a KWM bushing will not cover the edge of the hole but a Bergeon bushing will. And there are a few places where only the bigger Bergeon bushings will do what is necessary. For me, out of 100 bushings, maybe 2 or 3 would need (or be better) with a Bergeon size bushing. Willie X
JimmyOz
Feb 21, 2008
960
238
66
Gold Coast Qld
I have never used KWM bushings, the odd time a Bergon bush will not fit (when someone has been messing with the movement before) I just make a bush. For me this saves waiting time for the right! size bush to come and as most sell in packs of 10 (plus postage) the waist of money, you will probably never use the other 9.
kinsler33
Aug 17, 2014
3,762
534
74
Lancaster, Ohio, USA
Thanks, Vernon
I'd wait. I've had to replace a Bergeon bushing precisely once, so I just made one and riveted it in as was the traditional practice.
I've found that replacement bushings generally benefit from a touch of LocTite (the green penetrating stuff) so they won't fall out.
M Kinsler
TEACLOCKS
Mar 22, 2005
2,760
140
71
Santa Rosa Calif.
www.weserviceallclocks.com
I try to use the smallest O.D. possible.
Vernon
Dec 9, 2006
1,077
148
Like maybe repair a bushing within a bushing that I did a time or two? (full discloser) ;)
Teaclocks, I believe in using the smallest size required as well. If I run across some used cutters at a fair price, I may get them just to have.
Jimmy/Kinsler: I can make the occasional bushing when needed so what you said makes sense.
Thanks for the replies, Vernon
168,145
1,466,306
48,109
SimondsSays7
2,955
