Difference between a long case movement and a mantel clock movement
Joseph Coppersmith
Dec 25, 2010
202
St. Paul, MN
Is there a difference between a long case movement and say a mantel clock movement? If so, how does one tell the difference between the two movements.
Also, I have two (2) Gilbert Columbia clocks. I suspect one of the two is a reproduction. Each clock has a different gong base. How can one determine what type of gong base was in the original (not reproduction) case? One gong base is aluminum and round shaped liked a miniature hockey puck whereas, the other gong base is iron and black commonly found in many clocks.
I thank you for your anticipated reply’s.
zedric
Aug 8, 2012
2,224
598
Generally, longcase movements are weight driven while mantel clocks are spring driven, although there are always exceptions
JTD
Sep 27, 2005
11,457
1,778
It would be so helpful to see some pictures.
JTD
Joseph Coppersmith
Dec 25, 2010
202
St. Paul, MN
JTD
Here are two pictures showing two direct gong bases. Question is, which of the two is original to a Gilbert Columbia?
01549F63-52AF-4D0E-AD06-E25860D711FD.jpeg DA29DC5E-5BDD-499A-8A79-DF1EA677D155.jpeg
Steven Thornberry
User Administrator
Jan 15, 2004
25,668
2,683
Here and there
The black gong base (on the right) appears to be a common Asian-made gong. The inside backboard also does not impress me as being as old as I would expect. Did both come with Gilbert movements?
Joseph Coppersmith
Dec 25, 2010
202
St. Paul, MN
I wonder whether the gong shown in the lefthand picture might be covered under the following Geroge Owen patent?
US248206
Thank you Steve and JTD for your prompt replies.
The pictured clock on the left (round gong base) does, in fact, have G.B. Owen inscribed on it. Also, it has a Gilbert movement.
The clock on the right does have, I believe, and, as JTD pointed out an Asian gong base. The marking on the movement has a circle with a triangle inside of of the circle which makes me believe as JTD that the movement is Asian.
According to my books the clock on the right looks to be original and the clock left appears to be a reproduction.
So, would you put the Gilbert movement into the original case and put the Asian movement into the reproduction?
I thank you for you input and look forward to your reply(s).
gvasale
Mar 30, 2005
1,328
40
74
webster, Ma
Pendulum length is an important clue. No mantle clocks use a tall clock length pendulum except there are some that do. Spring wound, for example, Ithica, used spring wound with a long pendulum. I can't tell you whose movements they used at this time. But there's one in my cellar. Spring wound movements were probably used by others for a cheap tall clock.
gvasale
Mar 30, 2005
1,328
40
74
webster, Ma
As you can see, this is your typical CT movement pattern. This is what was in the Ithica tall clock. And no doubt, there are probably others too. I seem to remember that the ST 113 movement found its way into some tall clocks
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Latest posts
Staff online
181,317
1,582,077
54,765
Hec Losame
3,126
Top
