Diamond-Shape Escutcheon for Terry Clock Door
Songbill
Apr 29, 2021
76
I inherited this Samuel Terry Pillar & Scroll shelf clock. During the many decades in my aunt's house, it was always missing its original small diamond-shaped brass escutcheon on the key hole.To alleviate the ugly hole left when the original was pried off, possibly done 100 years or so ago due to a missing key, I installed the modern one seen here. I really want to install a small diamond-shaped brass escutcheon like the 19th century original but I can't locate one for sale anywhere on the web. Any idea on where I might be able to obtain one?
Robbie Pridgen
Aug 18, 2019
41
59
Raleigh
Songbill, I’ve been searching also for the same style escutcheon and can’t find one, even at Timesavers or Merrits. All I can recommend is to keep checking EBay and Etsey. Regards, Robbie 93EC0E8F-CA18-4B2D-88FB-6CE7328623EB.jpeg
bruce linde
10,173
1,931
oakland, ca.
clockhappy.com
i made one for my george marsh out of an old ivory piano key topper.... but i just noticed you said brass. if you really want brass that makes it easier.... you can buy thin brass stock and then just cut and file into shape.
Reactions: Robbie Pridgen
Songbill
Apr 29, 2021
76
Bruce --
Thanks for the tip. I had assumed originals were brass but perhaps mine was ivory. I'll keep looking for an original made of either.
Sooth
Feb 19, 2005
4,021
105
Cornwall, Ontario, Canada
www.angelfire.com
These are indeed usually ivory or bone. Beef bones (if cleaned and treated properly) can be cut and shaped to size, but it's quite a process, a mask is recommended, and you'll have to deal with the lovely smell of burning hair.
I have cut and fitted at least 3 of these for some of my own clocks. Each one is a slightly different size/angle/shape so they all need to be custom made to fit.
Songbill
Apr 29, 2021
76
[QUOTE="Sooth, post: 1492357,
Sooth,
Thanks. Think perhaps I'll go with the piano key option.
Jim DuBois
Gibbs Literary Award
Jun 14, 2008
3,747
1,284
Magnolia, TX
While true ivory keys still surface from old pianos etc, given the general stupidity of some well-meaning governmental functions, it is best to use bone when making replacement parts. Some auction houses will refuse to put up for auction anything with ivory, no matter the age. Other auction houses have been known to pry out the "offending ivory escutcheons" doing great damage to otherwise pristine clocks. I have had several of these to repair. So, bone is my choice of replacement material. And the last group of keytops I bought from eBay was all celluloid, not ivory, so there is that too.
I use a piece of masking tape placed over the escutcheon recess, rub around the edges with a pencil, then transfer the tape to my material and cut to the rubbed line. Makes a good starting point and additional shaping will be minimized. I also CNC route some of them, but usually getting the layout and drawing done accurately is more trouble than using the masking tape approach.
These examples were all from a couple of NY auction houses 3 or 4 years ago. The auction ads showed the clocks with the escutcheon in place, so they did all this damage themselves. I have made maybe 50 of these in the recent past. So, bone yes, ivory no if you are planning to resell the clock. I have also been making parts from the faux ivory products used for gun grips and the like. Just finished making several wheels for a couple of ivory clocks, made the replacement of both bone and faux ivory. I have also used deer or elk antler material. Also, clean dog chew bones, made of steer bone, can be had at your local pet stores
IMG_2549.JPG 20170714_145132.jpg IMG_2550.JPG IMG_2548.JPG 20171023_161721 1.jpg 20211001_064958 1.jpg 20210620_180720.jpg 20210705_135959 (Large).jpg
Reactions: PatH
Songbill
Apr 29, 2021
76
View attachment 674163 View attachment 674164 View attachment 674165 View attachment 674166 View attachment 674167 View attachment 674168 View attachment 674169 View attachment 674170
Jim,
Thanks. Your comment and photos of what happened at the auctions is appalling. I believe the ivory escutcheon on each of those 19th century clocks would have met the antiques exemption of the law. Not sure what the dealers were thinking. Mine is a multi-generation family clock which will eventually go to my nephew. So, no auction but still pause for thought about using ivory. I'll see what I can do with an attempt at bone or perhaps just leave it as I've got it now. Really was hoping to get the clock back to its original appearance.
Bill K
Aug 4, 2019
33
10
71
Jim's post pretty well covers it. I have used old piano key ivory many times on old American Empire furniture, the original ivory or bone escutcheons always seem to be missing. Done several clocks as well. Old ivory can be brittle so proceed carefully when cutting, drilling or sanding and it does smell when you do, but no worse than the hide glue that works well and is appropriate to secure your old/new escutcheon. A good source for a little ivory is your local piano repair person. Usually when you tell them what you are doing they will be happy share a little of the ivory "stash" most of them maintain. A little goes a long way if you are careful. I can't speak for any legalities concerning the very justified "ivory trade" regs. since I don't sell my furniture or clocks. I have never run into issues buying such however. The ignorance and lack of responsibility illustrated by the vandalism performed by people who should know better on some of the clocks shown on this thread is disheartening. Considering the age of what we're dealing with I would hope we'd be "legal" at least here in the States, internationally might be a wholly different bag o' worms. Good luck with your repairs!
Songbill
Apr 29, 2021
76
Bill,
Thanks for you reply and experience with ivory. That's great info.
bruce linde
10,173
1,931
oakland, ca.
clockhappy.com
found this:
Endangered Species Act and African Elephant Conservation Act
As of February 25, 2014, instruments and bows containing ivory were not permitted into the USA. American musicians who were performing intercontinentally were not allowed to bring back their instruments while returning home. The original law pertained to instruments purchased since February 26, 1976. Therefore, even if the instrument was made and sold legally, the new law forbade the return of these instruments to the states.
These new restrictions were placed because the Endangered Species Act recognizes African and Asian elephants as a highly threatened population. Legislation has stated that ivory over one hundred years old is classified as "antique" and is considered legal. Therefore, the only ivory that can be considered antique and legal is mammoth ivory or fossil ivory. However, any instrument or bow containing ivory will be confiscated at the US border until it is proven (by the musician) to be antique. If proof cannot be given immediately, the instrument in question will be confiscated and eventually destroyed. This new law states that selling an instrument with ivory, or replacing a broken part with ivory is charged as trafficking an endangered species. This crime can result in large fines and even jail.
On May 15, 2014, an important revision was made to the ivory regulations. The revision stated that it was permissible to travel with instruments and bows containing ivory purchased before February 25, 2014. Although this solves the previous issue, it complicates the job of instrument makers and musicians for the future.
Bill K
Aug 4, 2019
33
10
71
A very informative thread. Made me do some research. Musicians and various people in the antiques trade were supposedly involved in the writing of the latest version of the "endangered species" trade law so it seems that the law's intent is to try to discourage the use of ivory by collectors and small time restorers not "working for the public" while going after those who trade in these materials with a vengeance. Certainly not a bad thing. Even though almost all the ivory we encounter is over 100 years old, and while it disturbs my "purist mentality," I believe that I will follow Jim DuBois' advice and rely on bone, or maybe try deer antler, for these damaged and missing plates and "avoid possible hassles." I know I'm preaching to the choir but If anyone out there feels the need to remove their ivory key hole plates.... for heaven's sake use gentle heat (hide glue) or the proper glue solvent (for more modern adhesives) and dental picks. Don't just rip them out like was perpetrated on the clocks in Jim's Oct 1 post. Old veneer is brittle and not fun to replace. It was someone's craftsmanship from ages past, respect them and it!
Thanks everyone for the good information, that's what these threads are all about!
Jim DuBois
Jun 14, 2008
3,747
1,284
Magnolia, TX
And then we have little potential problems like this......so far I have not ever had an issue with this, most likely because none of the various sycophants have bothered to look at any of these? Good ideas taken to extremes serve no one well?
Bill K
Aug 4, 2019
33
10
71
Legislation with good intent resulting in unforeseen and unintended consequences for citizens not originally intended to be the focus of the law. Intent is one thing, application/enforcement is something else all together. Probably was a problem in Babylon and ancient Athens but the more complex society becomes (and things have gotten way too complex) the worse such seems to get. My wife says I was born well after my time...I believe she's correct (or maybe I'm just too old)!
Songbill, best of luck on what you decide to do, the rest of us will face this quandary sooner or later with our old clocks and furniture. Again, enjoyed this thread, thanks for posting.
Songbill
Apr 29, 2021
76
Bill,
Thanks. I'm going to avoid use of ivory (piano key) even though I plan to bequeath the clock, not sell it. Still concerned some "letter-of-the-law" idiot might "gouge its eye out" way in the future, long after I'm gone. For now, I will just leave on the (historically inaccurate) escutcheon that I installed before I even knew about the ivory issue [see my photo above]. I have no desire to attempt fabricating an escutcheon from bone. I may, in the future, attempt using metal as a way to at least get an historically accurate appearing one. I found this at the Hobby Lobby website:
Jim DuBois
Jun 14, 2008
3,747
1,284
Magnolia, TX
Jut fyi, but bone is as easy to work as ivory. Soup bones, clean dog chew bones from pet shops, and materials from various auction sites can provide a lot of bone, or ivory substitutes, for little money. It can be sawn using woodworking tools, readily. Thin the bone using a band saw to approximately the required thickness, then belt sand to the correct thickness for the part needed, then tape the pattern on the piece of bone and use a scroll saw to cut out the required part.
As pictured above, entry #9, here are several pieces of bone. Pictured are pieces of bone, synthetic ivory (Large round piece) from China, deer antler materials, and synthetic ivory pistol grip material from eBay. You can see where I have cut some pieces of bone for wheel blanks for ivory skeleton clocks pictured above also in #9.
Songbill
Apr 29, 2021
76
Jim,
Thanks but I don't have any of those pieces of equipment or a workshop. My expertise is pretty much limited to an exacto knife and similar desktop items. Your written guidance is helpful though. If I can find a local shop or acquaintance who has those tools, perhaps I can just pay him to fabricate the small diamond shaped escutcheon using your write up and my measurements/pattern and supplied bone material.
Bill K
Aug 4, 2019
33
10
71
Songbill,
For the heck of it I got some bone and played around with it. It really wasn't as bad to work with as I was expecting, bone doesn't seem to be as brittle as ivory. Jim is right. While I used my shop tools I also tried working it with simple hand tools (small hobby saw, files, sand paper of various grits). It took longer but the results were eventually the same. If you find a thinner, but solid, piece of bone it makes it easier. You only need one escutcheon so I'd give it a try. If you're like me (and probably many others who do this for a hobby) I take a perverse sense of pride of doing things myself even when it would more efficient to "farm" the work out. Drives my long suffering wife to distraction, she even accuses me of being "hard headed." Imagine that! As a side note: If I used bone to replace ivory I would document it with a discrete note in the clock stating so. I seriously doubt if many people can tell the difference, "if its ivory colored it must be ivory." A note might prevent future vandalism.
Jim DuBois
Jun 14, 2008
3,747
1,284
Magnolia, TX
So, the most recent example of this vandalism can be seen here, along with my semi-decent repair of the same. It is pretty difficult to make it entirely invisible as seldom does one find a veneer with matching details.
Reactions: bruce linde
Songbill
Apr 29, 2021
76
View attachment 679932 View attachment 679933
Jim,
Thanks. Results look terrific. Even looks like ivory.
Hope such "vandalism" on 19th century clocks, whatever is in the minds of those doing it , ceases.
Reactions: Jim DuBois
Bill K
Aug 4, 2019
33
10
71
Jim,
Someone really mangled this one! Looks like they dug it out with a screwdriver. Your repair looks pretty darn respectable . I have stacks and stacks of veneer sheets and still getting a perfect match is near impossible. Yours looks much superior to most of what I see professional furniture restorers accomplish. Nice work! As far as Songbill's comment above....we can always hope!
Jim DuBois
Jun 14, 2008
3,747
1,284
Magnolia, TX
Jim,
Thanks for the good words. I have gotten a lot of experience replacing ripped-out escutcheons and associated veneer repair in the last 4 or 5 years. Something I would prefer to have avoided.....
bruce linde
10,173
1,931
oakland, ca.
clockhappy.com
curious as to how you word that on your résumé? :)
Bill K
Aug 4, 2019
33
10
71
Jim,
I've been doing veneer repair for over 40 years (the curse of collecting American Empire furniture) and it definitely has its moments. Its a great way to boost your vocabulary though! I think that clock case veneer work is more challenging than full sized furniture due to smaller size and sharper curves. One thing I have learned (the hard way) is that when veneering, if it ain't workin', leave it be! The next day the same frustrating repair will slide together with no problem at all. You're either "on the beam" or not, and if you're not, then go fishing or something. There is no future in forcing it.
BK
174,394
1,523,864
52,192
danarog
1,063
2,971
Last page
