As John Hubby requested, here's a link to some not-really-good photos of some of my clocks, and the pertinent details.
The photos are at my Flickr site: The Clocks
#1 is a K&O marked "The National Silver Co.," and "GERMANY", plus serial #13033; it's plate #1559 in the Book. The pendulum looks like #37 (which the book indicates is much older), and has the same translucent green lacquer as the dial and columns. It also has an odd, neat, inverted-triangle-shaped bottom block, and no guide cup. I haven't had a chance to clean it or polish the brass, but it's running perfectly as is, so I'm in no rush.
#2 is what I believe is a Jahresuhrenfabrik - plate #1439 in the Book, stamped in the lower right corner "Made in Germany" in an arc and serial #80923. The pendulum looks like #21, but doesn't have the small screws at the top of the gallery as shown in the illustration. Porcelain face, beaded bezel. No cup. I need to replace the suspension spring with a longer one.
#3 is, I think, the oldest in my collection - a Kienzle, plate #1423 and pendulum #13, with the narrow gallery, although the two weight discs are shorter than what the Book shows. Serial #22090 and "Made in Germany". Porcelain dial, beaded bezel. A complicated suspension in the saddle that didn't photograph well enough to include in this batch, but it's unlike those shown in Note 188 in the Appendix. It's been an excellent timekeeper since I received it, so I haven't changed the spring nor fiddled with that suspension.
#4 is a plain, but nice, clock - Plate #1151, with Geo. Borgfeldt stamped in an arc at the upper left and serial #42312. A silvered dial. It came without a pendulum and I'm using a K&O I think is later (perhaps meant for use with a guide cup? - this clock hasn't one). I used the standard K&O spring strength as indicated by the Book, but ended up having to thin it a good deal,as it was running far too fast.
Photos of the other clocks were unusable - I was dead beat by the end of today, and too tired to fuss with a tripod - with the expected results... but the details are:
#5 is Plate #1155, stamped "Geo. Borgfeldt & Co. in a circle, with "Trade Mark" and "Coronet" in the center of the circle (I think - it matches the plate illustration as to details). No serial number. Like the National Silver clock above, it has a lacquered, machined dial and lacquered balls, with a celluloid chapter ring mounted on the dial over the lacquer. It has a pink alabaster base with an adjustable brass guide cup, and the same style pendulum as the plain Borgfeldt described above. This came to me with no crown of finials, and I don't know that it would have had one - it didn't appear that it had ever been "messed with" when I received it.
The last is another, later Jahresuhrenfabrik, Plate #1260, with the elephant & clock logo in the lower right corner. No serial number, but on the inside face of both plates is "52" and "1". A porcelain dial with floral swags in a plain bezel. A pretty clock, although I normally don't care for floral dials - this is a bit nicer than the ones used in later years. Although my photos weren't good, a very similar clock can been seen here: A JUF at auction
If you need me to double-check these details (I'm really tired now, so prone to error), let me know, but please be patient - I'm leaving town for a few days, and probably won't have Internet access until I return.
Best regards to all,
