Designing basic deadbeat escapement
Discussion in 'Clock Construction' started by Knas, Feb 7, 2017.
  1. Knas
    Knas New Member
    Feb 7, 2017
    Hello
    I'm new to this forum. I'm trying to design a basic 30 tooth deadbeat escapement but i'm having some issues finding consistent and complete information. I'm trying to make a basic cad drawing and was going to follow up making a brass prototype to verify my design. This is coincidentally *not* for a clock or watch but i am using the escapement in a mechanical design intended to advance a perforated tape 4mm per pallet cycle and it needs to have zero (or near zero) cumulative error. I figured a escapement design would be the easiest way of achieving this with near-perfect accuracy. Any information highly appreciated!
    Knas
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    I don't think you'll be to happy using a deadbeat escapement.
    Your advancing requires an exact diameter wheel to advance
    the tape.
    It is better to us pawls that are linear in motion.
    The advance of tape over a wheel depends on the thickness
    of the tape. Tape laying flat and push with a ratcheting
    action is more accurate.
    The deadbeat as you've suggested is simple. The pallets follow
    a circular path for the locking surfaces.
    The pallets need to be a little less than 1/2 the spacing between the
    teeth. In a clock, we usually set them to 40-45%.
    The teeth on the escapement wheel need to have a backwards rake
    to clear both the exit pallet and entrance pallet.
    A ratchet wheel and a pawl to push it is more consistent. In order to
    get a deadbeat to work it has to have a drop for clearance.
    The pawl and ratchet has 0 drop and can be driven from a crank.
    What problem are you having.
  3. Knas
    Knas New Member
    Feb 7, 2017
    So what i'm trying to do can be seen here; https://vimeo.com/144454867
    It seems to me that this works really well, the main issue i'm having is that the pallets are not designed right so there's an in-between position where the wheel can spin freely which can cause major problems some times. It took me quite some time just to make it work as well as it does thus i was hoping to find a thorough description of how to properly design the escapement bottoms-up.
    The parts are machine cut so the size should be more or less dead on (cut with a cnc-router right now, i might go for plasma or water jet in the future) - but i guess you're right that there could be cumulative errors after a few hundred turns or so? I thought i'd use this design since clocks are generally very exact devices (my dad was a clockmaker). How would the ratchet be more beneficial? Also, as can be seen in the video i'm using the downwards motion of the machine in question in order to advance the tape - this is something i'd like to keep doing, not sure how i would do this with the ratchet?
    Many Thanks!
    Knas
  4. Tinker Dwight
    13,680
    You need to make the pallets longer. Not much just enough to make it stop on each
    rock of the anchor.
    You may have issues with the straight escape wheel teeth.
    They need to have a bout a 15-20 degree rake opposite
    the direction of rotation. The amount depends on the amount of over travel.
    I wasn't able to view the video because of the machine I'm on right now.
    I'll look at it later when I have a different machine.
  5. Tinker Dwight
    13,680
    I just looked at the video. The pallets are tapered, unlike a clock that has
    impulse faces. I see no reason that it shouldn't otherwise work.
    The locking surfaces need to follow an exact circle of the arbor.
    The exit needs to be 1/2 of a tooth radius larger than the entrance
    for the LOCK surface.
    You may need to make them both slightly smaller radius arc to compensate for
    the width of the teeth tips ( maybe 2-5% smaller ). The anchors arbor needs
    to be mounted such that the average radius of the two lock surfaces
    forms a circle that passes mid way between two of the teeth on the wheel.
    They need to be long enough that as one drops off the other, it lands on a
    lock surface and not missing the end. It only needs to be a small amount
    ( maybe 1/16 inch longer ).
  6. LaBounty
    LaBounty Registered User
    Aug 29, 2002
    3,413
    10
    Clockmaker
    Mitchell, NE
    Hi Knas-
    Click Here for an article which includes laying out a deadbeat escapement.
    Good luck with it!
Similar Threads - Designing basic deadbeat Forum Date
Designing/drawing a deadbeat escapement--conflicting designs Clock Construction Jan 2, 2015
Designing/drawing cycloidal gears Clock Construction Dec 2, 2014
8 Day Longcase Clock w/ Deadbeat Escapement & Center Sweep Clock Construction Jan 18, 2014
