deox-007 question... how long?
bruce linde
ADMIN / MODERATOR
8,354
1,173
oakland, ca.
clockhappy.com
wondering how long pieces can be left sitting in deox--007?
i usually just set the timer on my ultrasonic for it's default... maybe 13 or so minutes? don't remember.
but... would it be a bad thing if i put something in and left it there for an hour while i ran an errand? i know that with ammoniated fluids this would not be a good thing to do.
Kevin W.
23,049
514
I have left mine in for a hour or so, no problem. If it lacquer on the plates, not sure about that, depending on temp of solution.
13,544
1,340
I somehow dropped a small pocket knife in my US and it stayed there for months. When discovered, It looked really clean! But the brass looked like swiss cheese ... This solution was either L&R or Timesavers Historic, both ammoniated concentrate 7:1 . Willie
Kevin W.
23,049
514
Deox does not have ammonia, which is one reason why i use it.
bruce linde
ADMIN / MODERATOR
8,354
1,173
oakland, ca.
clockhappy.com
right... i think it's the ammonia that makes longer immersions problematic for brass.
i was thinking of dropping some plates in the deox-007 and grabbing them when i got back from tennis, but chickened out. :)
46,175
1,773
My typical cycle time in the US is 45 minutes. No harm to anything. I also use brass key chain to hold the wheels of each train. Those have been subjected to my ammoniated cleaner hundreds of times, and have no signs of weakening or deteriorating. The only real danger with ammonia is with old movements with hammered brass. Modern movements are pretty dummy proof (which is a good thing for me) :)
If you're not using ammonia, your only real concern is with rust. An hour or two won't cause any real harm. Your US will probably cycle off, so you're just soaking.
R. Croswell
10,922
1,081
www.greenfieldclockshop.com
On a few occasions during final assembly I have discovered a part missing and after a long search found it in the ultrasonic. While I would not recommend leaving part in Poly Chem Deox-007 for an extended period, none of the parts appeared to have been damaged. Poly Chem Deox-007 is a good brass cleaner but perhaps not the best degreaser for really crappy parts. I always preclean really filthy parts with a strong automotive degreaser and a brush. Generally, if it isn't clean after 15 minutes in the US you need to take other steps. Sometimes I find it helps to "scrub" plates with Poly Chem Deox-007 and 0000 steel wool, rinse and back in the US for a few more minutes. I would not leave parts in while I go shopping.
Salsagev
Feb 6, 2020
1,159
117
14
Madison
www.youtube.com
0000 steel wool
Would this cause "Circular micro scratches" in the plates?
Also, what is considered clean after the ultrasonic bath? Sometimes the trundles are practically impossible to get to easily and sometimes deep pinion teeth are hard to clean.
bruce linde
ADMIN / MODERATOR
8,354
1,173
oakland, ca.
clockhappy.com
my US only has a 15 minute countdown timer... does yours go a full 45 or hour? or do you run three times?
yup... started doing that on your recommendation a while back. thx again.
R. Croswell
10,922
1,081
It can if you use a lot of pressure, but doing it wet reduces that probability. I suggest you give it a try on a dirty scrap movement first. .
I use a tooth brush to preclean lantern pinions, and yes, they can be difficult to get really clean without disassembling them which causes unnecessary trauma. My experience is that there is almost always some physical removal of crud that resists brushing and the ultrasonic. One has to set one's own criteria for what is "clean". I believe that at the minimum the movement should look clean and the active surfaces of pivots, pivot holes, wheels, pinions, and the like should be free of contamination when viewed under ordinary magnification. Assembled parts that usually are not disassembled except in extreme conditions (main wheel & ratchet wheel, center wheel and slip clutch, lantern pinion trundle sockets, etc.) are assumed to be less than perfect. The US will usually make these more prefect than if it was not used. At some point we have to ask is it going to affect the operation and life of the clock, and how much time are we willing to spend (or how much time is a customer willing to pay for) to get super clean.
MARK A. BUTTERWORTH
NAWCC Life Member
Jul 4, 2009
2,450
145
Muscatine, Iowa 52761
I think folks would really be surprised at the results of using an Actual clock cleaning solution rather then some bathtub Gin type of make up. Trundles another hard to get two parts can come out quite clean. Quite often one gets what is actually willing to pay for.
Reactions: Kevin W.
Salsagev
Feb 6, 2020
1,159
117
14
Madison
www.youtube.com
After all the persuasion, I will give deox-007 a go.
bruce linde
ADMIN / MODERATOR
8,354
1,173
oakland, ca.
clockhappy.com
i used ammoniated from when i first got my ultrasonic and only recently switched to the deox-007... which is obviously much less hard on pieces than ammoniated solutions. and, based on the comments above, i would have no problem doing a double dip... whereas leaving pieces in ammoniated solutions too long can sometimes have bad results.
46,175
1,773
Mine is digital, and can be set for any amount of time you want. I never thought to test its upper limit :)
bruce linde
ADMIN / MODERATOR
8,354
1,173
oakland, ca.
clockhappy.com
i looked more closely at my US and it has a 'hold' feature on the timer... just did a run and let it go for 30 minutes... really nice results.
of course, all of the standard 'clean before ultrasonic-ing' caveats still apply.
164,853
1,434,456
85,821
ClockWonderer
2,867
