• Upcoming updates
Dent Watch Serial Numbers
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
S/N 15991 was retailed by Edward J. Dent 61 Strand, 33 Cockspur & 34 Royal Exchange. The movement was made by Gibbons as previously stated. I can not say for sure, however E.J Dent may have examined this watch himself. As you can see rhe firm was located at several locations, and was selling a lot of watches. There was a time in the first half of the 19th Century when the firm assembled and or made their own watches.
moskau
Oct 27, 2008
27
Vienna/Austria
Hi!
I recently purchased a Dent in a sterling case with London hallmarks (makers mark:'HH') from 1841/42:
Dial:
E. J. Dent, London, 6195
Movement:
E. J. Dent, Watchmaker to the Queen, London, Nr.:6195
The case also bears the same ser. number.
The watch is crown-wind (hands are keyset from the front)
The ¾ plate movement has a going barrel, lever escapement, a diamond endstone, lever and escapewheel with cap jewels in screw down settings and a cut bimetallic balance with (white gold?) timing screws.
Is it possible that this is one of the earlier crown-wind watches of E.J. Dent, or are there many known Dent crown-winds with a lower ser nr.?
Thank you for your efforts!
Harald
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
Edward John Dent and his Successors by Vaudrey Mercer page 713
E.J.Dent Manufactures S/N 6195 Movement made by Herrick 1843
Page 679 E J Dent S/N 6195 Lever Nicole keyless 1851
It appears that this watch is an early keyless sold by E.J. Dent as a retailer. Chapter XV Page 275 gives a description of Adolphe Nicole's Keyless mechanism and a history of the firm.
moskau
Oct 27, 2008
27
Vienna/Austria
Thank you very much for your fast reply!
But i have to admit, that i am a bit confused about the production dates you suggest.
The London Hallmarks of the case (if i am not completely wrong) are clearly those of 1841/42.
The case features a crown (and it does not seem to be a modification - there is also no winding-square on the barrel visible, which i would expect, if the movement is a later conversion). The case is also very thin and fits the movement perfectly with no obvious signes of modification .
I really have no doubts that it is the original one.
And the winding mechanism looks pretty different to the Nicole patents i have seen - Were there any Nicole crown-winds with the hands key-set from the dial side?...(This one here seems to have some similiarities to the early patent of Th.Prest).
If I read the hallmarks correctly, would it be possible, that a very special case (which also bears the same number than the movement) was made for a movement which is made at least one or two years later?
I add a picture with the hallmarks, the crown and the movement.
Sorry for the quality - it will take some weeks to get better ones (my watchmaker is taking care of the watch in the moment).
Thank you again for your patience,
Harald
moskau
Oct 27, 2008
27
Vienna/Austria
Addendum:
A further mentionable indication that the movement and the case allways belonged together is also possibly the movement hinge at the '9' position (with the springloaded counterpiece fixing it in the case at the '2'(!) position).
For a swing out, open-face design rather unusual positions i think, which are reflected in the case design - again with no signs of modification.
(The caseback is completely closed - the only (golden) hinge is on the bezel (front) side. So there is no inner dustcover. Obviously to keep the height of the watch as slim as possible).
I think, in this case, it would have needed some substantial work, just to fit a later movement in a rather unusual earlier silvercase.
I really hope, i am right with my interpretation of the hallmarks, but i think they are 1841/42.
Thanks again!
Harald
Sandra Sargeant
Sep 12, 2011
I have started to compile a list of Dent Family watch serial numbers not listed in Mercer's book. Send me your Dent S/Ns I will add them to the list and also try to date the watch for you
Your Friendly Horologist Frank Menez
Hi Frank I have a Dent Early Half Hunter Wristwatch 61 Strand & 34 Royal Exchange London 37262 any info, date etc appreciated Thank you
Dr. Jon
Dec 14, 2001
7,586
2,005
New Hampshire
Frank
I have a Dent 49002. It went to Kew where is got a an A certificate in 1898. Its case i smarked for 1896 It is mentioned in Mercer but the Kew certiticate establishes its date since it is not in the serial number tables.
MartyR
Dec 16, 2008
11,072
346
UK
I have heard from Jon Hanson that Frank is very ill, so he may not be currently watching this thread. I hope he will return to it soon :)
Sandra, that combination of addresses, according to Mercer, gives a date range of 1853-1855. Do you really mean wristwatch? If so I can only assume that it is a much later conversion.
If you would like more information, photos of the dial, movement and case hallmarks would help.
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
Sadly I don't have that number but I have a discontinuous run of serial numbers from 37041 to 37457 - virtually all of which were sourced from Courvoisier by Audemars' London depot in 1881, and supplied to Dent.
Best regards
Paul
GJP@4
Oct 2, 2012
20
Can anyone identify my silver Dent Military watch please - s/n 57573. Case hallmarks are Lion, Leopard, date letter p and JW.
Any help would be much appreciated
G
MartyR
Dec 16, 2008
11,072
346
UK
Post some photos, GJP, and we may be able to help.
MartyR
Dec 16, 2008
11,072
346
UK
I have a couple of 57*** Ls Audemars movement serial numbers supplied to Dent in the early 1880s
GJP describes this as a "military watch" so is must be 1900s one would think.
GJP@4
Oct 2, 2012
20
Photo of my watch as requested and I've included the case marks (taken from the British Hallmarks website)
Inside the back case it has DENT in a triangle and 61 Strand, & 4, Royal Exchange London in script font plus Watchmaker to the King.
https://mb.nawcc.org/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACYAAAAfCAIAAAAEKiicAAAni2lDQ1BJQ0MgUHJvZmlsZQAAaAXVmnVUFA3472e2l6WX7u7u7u6QRrq7kU5pQUKkFSQlDBSQUkokBUSUEAEFBUFRwCDv+L73F+fc3/3v/nNnD+xzZoY5O8yc/Tyf7zMAwPvCOSjID0YKAP4BYSFm2mos1ja2LOhlAAUwADiADBB0dg0NUjUxMQD+r8vPBQD8u/GV4N9j/V93+583kLm5h7oCAGgCbXZ0C3X1h+r7UM3hGhQSBtXzUD0TGRYE1bBaqKYIgT4gVHf9rT3/rSf/1i7/1mv/7HPJTB3a5xAAMITOziGeAHQq0MIS4eoJHQfHAgAo8gA37wAAIJMAABolVy9nNwDghbYBAv7+gX/r21DN4/LfjuP532pnZ5f/PKazs+d/1v+eC/SXAID0NnSGzuv/7eLvF/4fx/z7Hyd0D7Awh94x0A8D4A0YAs6Aa5j7lb/nAagHBkWFeHt6hbGoQlfFXYBFN8BVSIBFTERU9O/m/2+Wv/fjvx/2wOyf+wykevlf62K1AUDlIXSfdP3XukuDANA0BAB4j/9axwndI5TZANBP7BoeEvHv8RB/35AAAUACUAC0ABPADvAAgoAYIAXIAyqAJqAHGAOXABvAAXAFvAB/IASIBGKBJCANyAauAzeAMuAWcAdoBFqBh0An0AsMAM+BCWAGeA0sA2vAJvAF2Ad+AicgCKJBIhAP0oLMICfID4qBMqASqAkagGagDegEeoIBYDgYC6aA2WABWAZWg03gA/AJOACOgbPgIrgOboM/wGMYHEYIo4AxwrhgwjAZmCpMH3YJdhnmCQuGRcNSYbmwElgNrAXWARuATcBew9ZgX2BHcACOg1PBWeGCcBm4OtwYbgv3gIfA4+FZ8GJ4DbwN3g0fhb+Cr8F34X8QKAQewYIQRMgjdBAWCFdEMCIekYMoQzQiOhDDiFeIdcQ+4hxJhGRA8iPlkLpIa6QnMhKZhixG1iMfI0eQr5GbyJ8oFIoKxY2SRumgbFA+qBhUDqoSdQ/1DDWL+oA6QqPRtGh+tCLaGO2MDkOnoUvRLein6Dn0Jvo3BodhxohhtDC2mABMMqYYcxfTj5nDfMKcYEmxnFg5rDHWDRuFzcPWYruxL7Gb2BMCMgJuAkWCSwQ+BEkEJQRtBCMEKwQHOByODSeLM8V54xJxJbj7uBe4ddwfQnJCPkJ1QnvCcMJcwgbCZ4SLhAdERERcRCpEtkRhRLlETURDRKtEv4nxxELEusRuxAnE5cQdxHPEX0mwJJwkqiQOJNEkxSTtJC9JdkmxpFyk6qTOpPGk5aRPSN+QHpHhyUTJjMn8yXLI7pKNkX0mR5NzkWuSu5Gnkt8hHyL/gIfj2fHqeFd8Cr4WP4LfpEBRcFPoUvhQZFO0UkxT7FOSU0pQWlJeoSyn7KNco4JTcVHpUvlR5VE9pFqgOqZmpFaldqfOpG6jnqP+RUNPo0LjTpNFc4/mNc0xLQutJq0vbT5tJ+07OgQdH50pXSRdFd0I3S49Bb08vSt9Fv1D+iUGGAMfgxlDDMMdhkmGI0YmRm3GIMZSxiHGXSYqJhUmH6Yipn6mbWY8sxKzN3MR81PmHRZKFlUWP5YSlmGWfVYGVh3WcNZq1mnWEzZuNgu2ZLZ7bO/YCdhl2D3Yi9gH2fc5mDkMOWI5mjmWOLGcMpxenDc5Rzl/cXFzWXGlc3Vyfeam4dbljuZu5l7hIeJR5gnmqeGZ50XxyvD68lbyzvDB+CT5vPjK+V7yw/il+L35K/lnBZACsgIBAjUCbwQJBVUFIwSbBdeFqIQMhJKFOoW+CnMI2wrnC48Kn4tIiviJ1Iosi5KL6okmi3aL/hDjE3MVKxebFycS1xJPEO8S/y7BL+EuUSXxVhIvaSiZLjkoeSYlLRUi1Sa1Lc0h7SRdIf1GhkLGRCZH5oUsUlZNNkG2V/aPnJRcmNxDuW/ygvK+8nflPytwK7gr1Cp8UGRTdFasVlxTYlFyUrqttKbMquysXKO8ocKu4qZSr/JJlVfVR7VF9auaiFqI2mO1X+py6nHqzzTgGtoaWRrTmuSaFpplmqtabFqeWs1a+9qS2jHaz3SQOvo6+TpvdBl1XXWbdPf1pPXi9Ib1CfXN9cv0Nwz4DEIMug1hhnqGhYYrRpxGAUadxoCxrnGh8TsTbpNgkx5TlKmJabnplpmoWazZqDne3NH8rvnPS2qX8i4tW/BYhFsMWpJY2ls2Wf6y0rAqsFqzFraOs56wobPxtumyRdta2tbbHtlp2t2w27SXtE+zX7jMffnK5TEHOgc/hz5HEkdnx3YnpJOV012nU2dj5xrnIxddlwqXfVd115uuX9xU3Irctt0V3QvcP3koehR4fPZU9Cz03PZS9ir22vVW9y7z/u6j43PL55evsW+D74Wfld89f4y/k/+TAPIA34DhQKbAK4GzQfxBaUFrwXLBN4L3Q/RD6kPB0MuhXWEUEPgnw3nCr4avRyhFlEf8jrSMbL9CdiXgymQUX1Rm1Kdorei6GESMa8xgLGtsUux6nGpcdTwY7xI/mMCekJqwmaid2JhEkOSbNJUsklyQfJhildKdypiamPrhqvbV5jTitJC0N+ny6bcyEBneGdOZ4pmlmedZblnj2SLZxdmnOa4549dEr5Vcu8j1yJ3Ok8qruo66HnB9IV85v7GArCC64EOhYWFHEUtRVtHhDccbY8USxbduEtwMv7lWYlDSVcpRer30tMyr7HW5Wvm9CoaKzIpflW6Vc1UqVW23GG9l3zq+7X37bbV2dUcNV03xHdSdiDtbtZa1o3UydU31dPXZ9WcNAQ1rjWaNw03STU13Ge7mNcOaw5u3W+xbZlo1WrvaBNuq71Hdy74P3A+/v/PA6cHCQ/2Hg+0y7W2POB9VPMY/zuoAO6I69ju9Ote6bLpmn+g9GeyW737cI9TT0MvaW95H2ZfXT9Cf2n/xNPrp0bOgZ7sDngMfBh0Hl4esh+aHTYenR/RHXjzXej40qjr69IXii94xubEn4zLjnRNSEx2TkpOPpySnHk9LTXe8lH7ZNSM70z2rMNs/pzw38Erj1fN53fmJ10avZxcsFt6+sX+z9tbt7edFv8XvSxFLJ8uJK8iVrHek74pXGVZr3vO+v7cmtda3rrE+uWG+sfzB9cOXj6EfTzdTt4i2ij8xf2r6LPa5d1tre2bHbmfzS9CXk920PbK9iq88Xx99U/k2uW+9v/k95PvFj5wD2oOGQ4nDwSOTo9Wf/j9PfmX9pv3d+Efmz+ix1fGnk8hT9GnJGe9Z97n++cqF/8VFkHOI8z+9ABz6DfPwAIAfDQBAZAP1DjMAQED8b7/4zx4AAIdaLhhUF4Hs4HdYGtwcQYAYQ+agzNF49CKmGRtLoIEjx30kfESUS+xEIkNKRLpDNkJehY+lsKGUpaKhOqF+RzNAW0eXTR/IYMOowsTPTMECsOyxrrJNsndztHBWcuVzX+WJ5g3kc+e/LGAlaCpkIKwloiqqJKYkriChICkvpSCtJKMqqy6nI2+gYKxoqWSr7KziruqvFqmerHFds1qrXfuFzqrukT6JAY+hqpG9caTJddNmsyHzpUv7lggrKmsOG1FbOTsVe/XLag4qjgpOcs5SLmKuQm787lwebJ6MXjTe5D7Evhg/mN+p/8+Ab4HbQRvBSyGvQifDhsP7Ih5Ftly5E1UenR+TGZsYFxHvl+CaaJ1klKyRIpsqdJUtjTodl36RcZD5KWspezpn8Nrj3Ma8iut5+SkFEYW+RQ43zIq1bsqXiJRylNGVk1SgKk4rD6p2bm3cXq6er5m686J2qO5pfU9DV2NnU8fdzuaulp7Wp23D98bvzz1YfrjV/v3RWQe2k6qL44lYt1qPWa9LX1h/2tOSZy0Dzwbnh3ZGgOfUo0IvtMecxqMmiibvTY1Pb80gZlnnVF45zse/vrXw7M3GImKJZ1l/JfBd4WrX+5V1cIPrg/7H4M2SraefPm2T7Mh8cdnN2XvydXMf/139R+hB3eHiT6Jfmr/j/nQdH56Kn4WdP7m4+Of6u0LXfwgeitBDYpHrqDZ0CkYXy4U9JZjDtRGmErkQK5DQk/wmfUfWRV6Gj6awp1SgYqNGU2/RjNO20eXTX2G4zKjOxM1MxPyd5Q1rD9tt9gwOP04zLhluRh44zzbvS75H/OUCiYIe0PUXE6ERORP9IDYmfl+iWDJOyk1aT0ZUllYOkPssP6vwRPGOUo5yuIq9qpoalzpGfUdjQrNZK1vbR0dXl1sPpbel/9ygwTDDyMfYyETClMEMZfbDfP3SvMWk5XOrEesRm1HbcbsZ+9eXVx22HPedTlwwrhRubO4iHsqexl4O3oE+8b55frf82wL6AieC3gZvhuyHHofDIwgiSa9QRFFFU8dQxpLF4eIR8ScJB4nbSe+T51PGUnuv3k+7k34jIz0zOss32z7H6JpSrkgey3WyfDD/oOBj4eui5ze6iu/erCzJK00piyj3rXCqtKwyvKVxW6FaqkbkjkAtTx13PXcDdyNfk/BdyWalFt1Wiza3e6H3Ux4UPaxv73o08fh9x1EXwRPWbpke016fvtT+2097ny0O/BqiHpYesX4eM1r1Ymjs8wTppMyU83QO9M20OUfxSn0+/HXjwspb8kWdpYTlxyu7q+zvbdcK1ic+ID4qbUZvdXw63BbfCfvSsXvyVfVb1v7rH2wHoYejP5l+Rf1+eyx/UntGfn713+sPfABLYeywKbg31DE3Ic2RB6hqtCb6B+YW1KGeELThnAgpCUeJ4ohliPdIGkhdyJjJ3pGX4q0oqCgWKMuoHKhZqT/TtNKG0ynSo+jnGCoYfZhkmNHMCywNrFFsBuws7Ecc05x1XHHcljyivCS8X/hG+RsE0qH7QVeYT4RIZF/0tdgT8SqJFElvKWNpKRlGWZTsgdy6/IzCkGKnUqtyrUqFarFavvo1jQzNVK1E7VidCN1gPS99JwMLQx0jWWMuEzKTP6bvzYbNGy9lW/hbGlkJW5NYf7N5adtmd83e97KeA48j2nHTadj5jkuyq6ubuju7B9Ljk+eE1z3vGz6xvm5+Rv6yAdyBVEGYoJPgHyE7oRthS+GzES8in115EnU/ujGmOrY0Lj8+KyElMS4pIjkoxTfV/apTmn26VYZ5pkmWYbZejs417VztPO3r2vm6BfqFhkWmNyyK7W46l3iVBpdFl6dWXK+srGq+1XN7snq15kctpo6pXrJBv9G56crd3Oa6lt7W+bbd+4gHjA+l200f+T/O7GjoHOna7Eb38PUa9YX3Vz598exokGPIYjhrZPD5+QvFsYTx0Un8lNt0zwzNbMTc63nx1wUL39+aLD5YJl8Jf7f0XmWtaYPiQ9LHgy3PT2vbl3fe73rsHX7L/M71Y+ow/qf8b9SfjZO5s6W/1//f3OAvE2ikAKAOYoUVBwDofgWA29A6ziSIHVCuYEIEAJdkAfBTLACOagFg7lsADvnmX378XUDoBYNecAABGSgaMngCKKIggkyUDMADlAANQAcwAiyQkXIBvJCTigASgAygAFmpBqADGACmgCVgCzgC7oAPEAiEA9FAImSlOUABUAJUAXVAC2SkT4BnwCjwElgAViEX3QOOgDMQCRKDVJCFcoMioCyoBuqDFqAD6AUGgzHgVTAPLAVrwTbIPIfAacg7P4LfwBMYCkYOOScvTBIyTkOYLcwDFgpLgOXASmH1sHbYM9g0bBm2DfsFR8LxkGcKwxXhBpBlesOvwNMhx6yDP4IPQ4b5AX6AgCHIEewIcYQ64hLCDRGOSEMUIxoQTxDjiGXEHmSWpEg2pARSC/JKH2QcMg9Zg3yEHEUuIfdQAAoPOaUcygjlggpHZUJG+RD1HLWE+oaGo2nQgmg1tBXaD52ELoZscgD9Br2HgWFoMMIYTYwdJhiTgbmFeYyZxHzAHGPJsLxYFawVNhCbjq3CdmCnsVvYCwJqAmECHQJngiiCAoJmgmGCdwS/cKQ4Xpw67jIuEncd14wbwb2HHJKCUIhQl9CNMIGwjPAx4QzhFyI0ERuREmSQ4UT5RG1E40RbxHBiZmIFYmvicOIC4nvEU8Q7JGjIH9VJnEjiSSpIukkWSX6RUpFKkJqTBpNeJ71HOkW6S4Yj4yPTJfMiSyerJxsh2yRHkLOTq5O7kCeTV5MPkK/jATwLXgXvhE/E38YP4NcpQAo2CjUKV4oUilqKEYotShQlN6UupQ9lNmUL5TTlPhUZlTiVBVUkVSlVD9U7aoCajVqT2pM6i7qVeob6kIaaRo7GgSaZpo5mjOYrLTmtFK0dbSJtLe047Tc6Cjo5Oke6q3TNdLN0v+mZ6DXp/egL6XvoNxgIGMQYbBlSGJoZ5hnOGLkZTRijGWsZpxn/MHEwGTNFM9UzzTKdM/MxWzGnMj9gfs9CxCLP4s1yk+U5yxErB6s5azLrA9Y1NlI2FbYgtttsM+wguyi7C3sh+zD0fcfFYc2RydHDscfJzGnKmcrZwbnNxcBlzJXM9Zhrm5uB24Q7lbuLe4+HlceSJ4vnKc8hLx+vI28R7zgfwCfF58d3h2+Rn5Rfmz+O/zH/rgC7gJ1AocCEIFxQXjBMsEVwU4hJyEroutC4MFxYUThS+IHwFxFOESeRcpEFUTJRA9F00SHRczE5sQixh2LfxPnFvcTrxDckmCXsJcogZ6SUNJcskJyRIpEylMqRmpAmkNaTzpQek8HK6MpkyozJEsjqy2bLTskRyxnL5cvNyVPIW8qXyi8rMCk4KdxR2FLkU/RXfKB4qCSjFKs0oIxU1lPOU55XoVVxUKlV2VYVVg1X7VGDqemo5aktqDOqu6u3qB9qKGikakxqUmhe1qzX/KYlo5WkNaFNoe2g3aj9Q0dRJ11nDjJFL9123Qs9Pb1ivQ19If1o/VEDvIGTQavBsaG24Q3DD0YiRvFGk8b0xt7GXSZoE0uTOpNDU3XTQtMPZuJmKWavzDnMw8xHLlFd8rzUZYG1sLNosTi3NLGssTyy0rYqs9q1VrYusN60kbXJsVmzlbBNt122E7FLtXtrL2ifbP/mssDlpMsLDgIOSQ5vHAUdUxwXnYSdrjqtOIs5ZzqvuUi75Lpsuiq6Frnuuqm7lbsduOu733E/9bjk0eqJ9HTw7PQi9fL2GvSm9w73nvbh8UnyWfaV9M3z3fZT96v0++1v5t8agA5wgToPmsDQwOkg3qDUoPfB8sHFwd9DDEOaQhGhTqG9YTRhYWEz4QLhGeEfI1QjKiP+QHb48ArJFd8rL6I4o5KiVqPlo0uiD2NMY9picbFesSNxbHEJce/i5eJvxh8mmCa0JeISvROfJ3EkJUHdi0JyWfLvFMuUR6nkqUGpL68KXs2+upOmm9aQjkp3Tx/OYM9IzljPVM28nXmR5Zj1NJspOz57NUcppyrn/JrDtae5zLkJuWt5qnnV12HXXa8P53Pmp+V/KtApuFuIK/QvnC4SKSqALNHiRmcxXXFs8epNlZt3SpAlXiXjpYKQJx6UWZR1lTOUJ5RvVGhWNFUSVgZVvqqSriqvurjlemv0Nv/tvNsH1dbVvTUsNVdrdu4Y3WmvpamNq92o065rqSevj6xfaVBraGgkagxtfNuk1FR7l+Bu0N2FZsXmOy3YlqCWhVbF1jttBG3BbW/vKd+rv090P+z+8gP1B3cfkj+MerjertN+/xHNo8RHnx+bPO7qYOnI7PjeadM52MXXVdh1+sT9yVS3VPetHkxPcM9yr0Zvax91X2LfTr95f99T7qf5T0+euT97OSA7UDtIPBg1+GHIaOjJMMdw3vDJiMfI3HPF502jlKNJo3svbF6MjImOVY0TjEeOf5wwneif5J8smUJOhUytTRtO97zkeVk8g5gJmVmbNZrtneObK3mFfhX+6uO82fzAa5HXVQtEC7ELX97Yvhl7K/u2cZF6MW3x55L70utljeVHKxwrhe/g70LffVg1Xx18L/a+Zo18LWXtYN11/dWG+kb7B44PRR8RH8M/bm5abD7fktqq/0T9Kf3T789enxe3dbe7d/h2yr/gvsR82d21353aU9xr+8r0Ne/rxbfAb2v7JvvPvot+r/5B9iPpx/cDl4O5Q7XDh0dsRwU/YT+Df67/Mv018Fvk9+0/pH8S/nw9djieOlE4aTmlP806/XPmebZwrnn+6ILtIv+f/vE/+P+3A/iX/yioA8BCHQDh/9EBMANsACeUSvMDQlAuLQnIAoqAKpRM60JZ/3/0AG5Q8h8AhAJXgHggBcgE8qBkuhyoBhqANuAR0AMMAmNQJv3mP7uAUxABEoIUICOURQuBUqAyqAOagragG+gPRoKJYBZYBFaBjWA72Ae+AOfAd+Bn8AA8hxHAKGGsMEGYLEwTZgrlzt6wCFgKLA9WAbsL64QNw+Zg72F7sBM4Fk4N54RLwNXgpnAneCCUNV+DV8Jb4L3wSfgKlDOfIogQjAghhDLCBOGMCEGkIG5AXUAX1AWsIL4hQSQFkgspizRAOiJDoGy5FNmKHICS5W3kGYocxYWSR5mg3FHRqDxUHaobNYPaQp2iydG8aGW0JdQBpKDL0A/RY+h1KE0mxfBgVDA2EP+zMDWYHsw8Zg+LxrJAOfIlbAA2A1uD7cW+wf4gIIQyZHUCB4j9NwgeEEwRbOOQOFacEs4WIn8R7gFuGrdLiCXkJtQkdCVMIrxF2E+4QnhCREckS2RNFEl0k6iDaIHoJzEVsRSxJXEk8U3iLuJF4mPIABWgxDiBpJpkiGSTFE3KS2pAGkhaQPqYdJH0lIyFTJPMmyyXrJ3sLdkZxHpd8kDyG+Q95Bt4LF4Eb4VPwDfgX+J/UTBT6FAEUZRSDFLsUlJSKlN6UxZC+fBnKnIqRSovqkKqp1Q71FRQNuxPXUo9Qv2DholGn+YKTS3NLM0FrQCtDW067SPaDToSOkU6X7pSulG6I3p2ejP6RPo2+ncMOAY5Bi+GmwwjDIeM7IymjImMbYzvmAiZ5Ji8mW4yPWc6ZGZjNmFOYG5lXmbBskizuLMUsgywfGNlZDVgjWZtYn3DhmKTYHNlK2AbYNtnZ2Y3Yo9jb2Ff5sBxyHH4cJRyjHH84eThtObM4Ozi/MxFy6XLFcV1l2uJG8ctz+3HXck9zX3BI8LjzFPIM8xzxMvNa8ObxdvL+5WPhc+ML5Wvk2+bn4HfiD+J/xH/JwE6AUOBRIFHAp8E6QWNBZMFOwR3hJiFzIXShXqFvgtzCdsJXxceET4WERFxh6g+K4oWVRINE70rui5GI2YslibWJ3YkLiDuJl4hPi9BJKEpES/RKbEvySvpIlkh+Roiu55UqlS/1B9pCelA6WbpLRk2GQeZMpk3snhZE9lrsuNyGDktuVS5QXlQXkU+Qb5f/kxBUSFOoV/hXFFZMVFxUAmupKmUoTSuTKRsolyk/FaFQcVJpQ6iu5BqmOoT1Qs1TbVstVl1anUH9Tr1XQ1xjRiNIU2cprlmueZHLUGtCK2n2lhtM+0K7S0dUZ0Ynee6ZLr2ug26B3pKell6C/rs+oH6vQZYA0uDOwbfDZUNrxkuG/EaRRo9N6Y0djNuN4GbmJnUmPwwVfuH7hJmV80WzLnNo8wnLjFcCrj0zAJv4W7RZYmzdLB8YIW0srZqsQasL1k3Wp/amNrU2RzbGtvW2h7bGdvV2Z3Ym9jX259dNr981wFwsHJoc0Q62kPpL87JxanbmdzZx3nQhc4l1GXClcM1zvW1m5Bbutu6u5x7ofueh5bHbY9jz0uebV4YLxevPm9q72DvSR9uiO0rvtK+Bb57fjp+tX4X/rb+HQFkAf4BLwI5AhMDV4JkggqDvgXrBzeEIEKcQnpDaULDQmfCBMMywzbD1cKrwk8irCLaI0kj/SLHrnBeSb6yGiUXdTPqINokuiUGE+MeMxDLGBsduxAnFpcbtxOvFV8Tf55gm9CRSJ4YkDiexJWUnLSaLJd8M/kgxSSlJRWb6p46eJX5auzVxTSptMK0/XSj9OYMbIZHxnAma2ZC5rss+azSrF/ZFtntOWQ5QTnT1wSuZV/bztXJbchD5bnlDV1nu550fS1fJf9W/nnB5YK+QobC2MLlIvmi8qKTG7Y3uiG6Rxcv3ZS/WX7zpMSupLeUoTS29F2ZUllV2UW5U/mzCtaK5IoPlRqVdVWoKs+qsVt8UBK8e9vo9r1qsuoQKAuTrLlZ8+eO3Z3eWqbaRIjvGnX19Zh6n/rJBuGG/IaDRovGria6ptim93dV79Y2o5q9mydbhFryWw5bLVuftDG0JbRt3NO813gfdz/g/uwDiQc3Hxw/vPzwWTt7e1r7ziPDR/ehZDjy8VKHUkd1JwLKhie6hLsKun4+sXnS183Sndr9qUe/p62XvDeid7FPsa+6H9Hv1T/5VPhp4dNfz+ye9Q+wDaQPfBk0Hnw0RDMUN7Q+rDXcPEI6Ej6y/Fzlef0objR4dOGFwouaMcxYwNj8uNx49QR6ImBiflJ+snoKMxU4tTCtOF37Evcy5OXijMpM4yzJbOTs6pzWXOsrylexEOsN5ttf079Oef1lwXyh5w37m+w3B2/t3g4t8i8WLp4suS5NLEssV6wgVvxW5t8pvKtdJVoNX333XvN96xrlWtza5rrh+uMNxo2rG3sfLD70feT8eO3j4ab95vAW/1bh1vEnl09jn0U+l3y+2PbYntqRgJgP++L95eWu1G7lHnzPe2/mq9TXim+wb17fpvfF90v3z7+7fR/7IfSj8MfvA/uDgUOuw6zDr0dmRx0/6X7GQeTX+NXwm+C3/++ZP2J/bvz5dWxz3H3CcBJ38v5U5bT6DDxzORs8ZztPPl+/UL24/d/4/6/9I6HnLDAQ+3EAMUAKkP9j/vTQJJrtf3v/v7NoZcj6/51F2wJOgAfgB9E+CjL+dCAXKAYqId9vBR4DfdD0eRri/BqwDRwApyAKJAXpQA6I8bKgBmgMEd4d8vxYMAPi+22wBbL85xDd34N70GQZDbGdHSYKU4YZwexhvtA8OROaJjdAXH8OW4BtwX7C0RDVeaAZsi7cDu4Hj4PnwavhDyGzfwPfhohOjGBFSCC0EbaIAEQSxPMmRB9iFrGJOEYSI9mRMkhDpAvyCvIa8g6yCzmN/Ig8QZFBPq+EskD5oVJQZagHqDHUGuo3mhTNg1ZBW6OD0JnoGnQ3+hV6F4OCpsIyGDOMHyYNcxvTDXH8KxaLZccqYW2wYdA0uBn7HLuBPSOgJZAkMCUIIMgiqCcYIlgjOMPR4aRxl3DBuDxcK24C95kQTcgJTYBdCBP/ofg7wlMieiJ5yN2jicqIuomWiI6J6Ynlie2J44iriJ8Sr5HASNhJNEk8STJJmkmmSPZJ8aSSpNakMaRVpAOkH8nQkLMbkgWRFZF1ki2RnZOzQfNeb/Jr5A/I58l/4xnwqnh3fCa+FT+H/0lBT6FC4UaRSdFG8YriNyUTpTqlF2Uu5SPKRcoLKk4qfapgqptU/VQfqXHUYtQ21InUDdTT1Ec0jDSaNH40RTR9NJu0RJClO9Jm0D6gXYKmvIJ0VnRJkKMv0IP0AvRW9Mn0rfSLDEgGUQYHhmyGLoZNRnJGFcYAxkrGCcZjJl4mG6ZMpifQfJeOWZ85jrmNeZ0Fz6LFEsXSwrLGimfVZo1lvc+6yUbLZsyWytbN9o2dk92evYB9jAPgkOYI5KjnWOWk4jTmTOd8xvmHS4zLl6uO6z03Lbc5dy73CyizVuKJ5nnM851XkNebt453g4+Zz56vlG+BH89vyp/HPyWAE9ATyBAYFUQJagpeFRwWQghpCKUKDQsjhDWErwo/F0GL6IhkioyLEooaieaJzorhxSzFSsSWxBnFncTviG9J8Er4SdyT+CEpJRkl2ScFSmlKZUpNSZNJW0iXSr+DWO0h0yzzTVZCNkq2Tw4mpy2XIzcrTyVvK39L/qMCr0KAQrvCb0VFxWTFUSVCJVOlYqVlZRZld+Um5a8q4ipXVPpUYaraqtdU59Ro1BzUatV21EXVI9X7NZAaBhqFGsuabJo+mg81j7XUtLK05rTptd20W7SPdJR1MnRmdel13XXv6f7RU9e7pvdWn03fX7/LAG5gZFBmsGkoahhn+MKIwsjZqNXoj7EWNK1dMxE0iTYZNaU0dTG9b3puZmBWZvbZXNr8qvn8JbZLwRCpSS0cLdogDzeyrLTcs1K0uma1ai1knWD90obFJthm0BZv627bYYexs7FrtjuzN7avtj+4rHm55PKOg6LDdYcPjlKOmY4rkImnOC048znHO8+6cLpEuUy5srlGuI67MbuFub1wZ3QPcR/1YPAI9hj1ZPAM9hz1YvQK8XrhzeQd5j3uw+IT4TPly+4b5Tvjx+UX5zfvz++f7L8YIBKQHrAaKBmYE/gxSB4i9k6wWnApZOO6IdUhf0JNQ5vCwDCbsAfh2HDn8O4I8gifiKFI+siwyEmI2XFXFqKEo9Kj1qJlo/Ojd2LUYypijmKNYhvigDjruAfxBPGu8b0JlAkBCaOJrInRia+SBJLSktYgahclf03RSalJOUu1Tm2/SnTV++pwGnNaTNpCulh6bvpOhlZGTcZ5pl1mZxZFVnDWdDZ/dkb2Zo5azu2cs2t217pyqXLDcufyRPJy8/au61+/m4/J98wfKeAoSCnYKFQtvF14UeRY1H+D8UbcjZViheLy4pObdjd7SuhLYkqWSuVLy0tPyuzKesrpy2PLVyoUKiorziovV/ZXMVUlVL2/pXKr+jZ42+X2YDV7dWr1xxrNmjpohut5Z7SWpzajdrtOr+5uPa7eF+K2QENOw16jYWNrE3FTQNP0XaG7uXe/Nhs1t7UQtwS0TLcKtl5r3WszaGu+h7vnc2/sPs/99PtbDzQf3HkIe+j08Gk7Y3tM++Ij6Uc3Hh1Adt7Wgevw6hjpZOtM6Fzukukq6tp/YvCksRve7djd3UPZE9Qz0cvZm9i71CfRl9v3qV+1v6z/4KnB09qnZ88snrUOoAYcBjoHSQe9BweG6IfChqaGuYYThxdHxEdyRrYghpc9Pxw1Gm18AXth/6JzjGzMd+z5OMt4zPjChMhE9sTWpOpkxeSvKbOp1mnMtOt0/0val2EvZ2b4Z9Jm1mcVZ0tmD+aM5+6+Qr5yftU7Tz0fOj/9mvf11ddrC/ILNxd+vDF80/gW/tbxbfci5WLQ4sQS11LS0sqy9HL+8u6K9kr1yuk7q3cPVnGrHqvP3tO9D3s/vcazlry2vC65nrf+eUN1o3zj8IPhh/oP5x+tPt7fxGw6bXZtkW55bT37RPMp8NPzz4yfwz5PbLNtX9l+ucO5E7Mz+4XrS+yX2V2u3ZjdmT2Ovai9qa+sX8O+vvhG/y3g28A+ft99v/M79rvd95bvZz+Mftz68e1A+SDvYPVQ8DD2cOKI9sjz6PFP+E+Tn5U/t39J/Ur6NfWb5rfr77bfv/+o/cn58/qY6djjuO3454nSydWTiVPyU6vTytONM+4z37N7Zz/Opc6vnHefn14oXcRfPP3L/1APcbG/EQAAEqpBj5+tXlwccAEAugAAzqB84KTm4uLsDjRsXgGAZ37/Pov4d2cU9IRmRfHf6n9a/hc886oSy6twIAAAAZtpVFh0WE1MOmNvbS5hZG9iZS54bXAAAAAAADx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iIHg6eG1wdGs9IlhNUCBDb3JlIDUuMS4yIj4KICAgPHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4KICAgICAgPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6ZXhpZj0iaHR0cDovL25zLmFkb2JlLmNvbS9leGlmLzEuMC8iPgogICAgICAgICA8ZXhpZjpQaXhlbFhEaW1lbnNpb24+Mzg8L2V4aWY6UGl4ZWxYRGltZW5zaW9uPgogICAgICAgICA8ZXhpZjpQaXhlbFlEaW1lbnNpb24+MzE8L2V4aWY6UGl4ZWxZRGltZW5zaW9uPgogICAgICA8L3JkZjpEZXNjcmlwdGlvbj4KICAgPC9yZGY6UkRGPgo8L3g6eG1wbWV0YT4KyI2KBAAACXZJREFUSA1dl3lsFNcdx2dmZ/a21yc3GEe2wXZJwEgIqCgYULnTgmhoKEJCCLWCVilUiITSpiAh4C960AaB2kotcaFCEKC44RJHuG0ChkCLzWEu3971etfea45+3oxBqE/y+B2/8/s73lu5J9ony7L0eliWJUmmJCmybMmyizk7DEEjm5KlvP2VFbGGlQNHAGSy5BqgsbfEji3fkaM4w9lyeEwj4/O6JcvQMylDT7sUiYnqgokTsZQt5BuKZFmmrrmEZel0UlVkTvmaekbVFF1Pm5aOQS5VtiRDN9JMFOyXTYaMlyjDBFul6fVoPT1ht9sbDPpjsT5NczEMw8A4Qf3aXuawqKrK1zmCDAlQWrLEPpTQpNO61+tlnkwmPR6PrusuRft/lbKk4w7AWpYBnF6vO5PJ2HJVJv39/YlEgglqfD4farKyspjoZoZ95Pb29qI1Ly9Pc3sDgQAEqVRKVd0o7o5Eg8EgvKqDJ4Ygl7AYum4Yejweb2xsjMVipaWlI0eOhCGZTF+6dOnixYtNTU2caprmcfs8Xm3ChAnTp08fNnz48RNf3P66oaOzTZHV7Ozs78yYvmzZMlSSEJhiGhIsTFAnR3rib+AiSJKVOvzPQ/+u/bKtrc3v9+NBRcW3Fi9eXFv75eXLl/v6+txu4TcoWaZMwHyBAOw5OTnPXzS7VDfY9PcnMdHj865atWrBggVYZnN5ZVUESKh0MhYXRXhM/cTxwwdrPu/q7EYfOwzMRKiiqMwJUjKRFnjIciKRwge3z0uyhEK5JFE01itMsSycMyyzIH/Q3r17s7JCMAYCwf5kUkTdMkT8nUFsieJXF76KRqJejyedSoGGPSw8I70K8gvxhs2XL1+CeU52TiKVyMsrGDy4sKSkLBDw3blzB2xA/NWrV26Pp7Ozu6np8bvvvocd8Vi/N+C33VVVNCEXlx2VkUgEG92aN5nolRQXygzdkmTXe+OrNmzY4KRMPN63Y8eOhoaGuXPnfvDhD0O52R7Ni5fz58/Hoa5w98aNGxPJNMkCcIQQlxRNdZIW5EkfmdigBq97o/F0MmOkjHiq35IVVfOkDWnM2HLVrYXjsd/+6Y/l5eWLFi0K5eeu3/iL33z66fd/sPhG3fWr168MHzoiEul+8eIFcigtEpsQkBlZWUEK0JQxXjExndZhKSJjnfRhAh2+UlqJdFqBW5NnzJzx0Uc/t2RX0+NHV65cyc7J8fh8pmkQtr5E/PHjxyNGDbeuWf95+CA3N3fhwoUoI9HwgQxCFDIQy5dcwFWn/l0ff/xLHOdAoZNI1td1dR1t7f5A0DBNfzD4qrWF+KmaOmz4iIkTJ44pK8O+DBWu6xcvnL9x44YlmUVFRUSL6DY1NnV0dFRVTRw0aNCzZ8+QWTS6uLKykoIV2Lpc6TT9C39NOupA94GzsHAwcS4rK/twxY9IWuw9cOBAXV0d1LCxhJiIUuBEneXZs2cJKpTjx4/H0YcPHx47dqynp2fIkCE4RzYRL4ajhR2EqKJFiQIxOaBl2s1CXb58+bgJ41ta2q5cv8ZOe3t7uKuT/smkoqKC2Dz45j6ukFzVs2bMnj07KxDEb8qmvr7+6NGj4HH33r229nYUA7XH7+MU+0QqGdZALIHLhlekEpO4XfJLliypv3WLHRh27tw5a9aszs5O2ndbS+uIESPIo3nz5hlGhhJ0spGmM23atObmZiSAMDJJDpwReNrpCUJiU8SWa8IeANwdDuP3vn37RhWPxqE1a9b8+a9/uXn9WsY0it8ZPW/Od6mtvJxcn99TWTGWjtrY+N/Tp09TguvXrx81ahR+TJo0acuWLckUHUrgD+ZJriCXy2Orxz4BNGsGJqAXrGjQ4XD487/9/dGjR3PmzPn1ll9xamZ0um5hYWFxcXHRaPruSOz91/ETn332GfvDhg0DZ8hgx9CSkhL8Ax46OwixiXDUI5+JcBylfClS2nra4J4TaNNRQ3m563720zFjS6dN+zb8S773fjwWvXDhgqO4/uaN8+fP/XjNT+jyp8+ewT9sRfrT5mauG6CmTuDCpUySy0T1erzgB1o0PJNmi8mcMYMI9VhHAB48eHDuzNnO7i63pq1cuTIUCr14/vzQoUOIg6CjrZXEJlG7u7uPfHG0trZ25syZqD9y5AgVgjRkOuBRCCiDC4NExvLH2i5Whb5KeLAu0hulEp4+fbp7925fwL99+/bsrEAk3NXc/IQbFGUkERKrq6shxj/Npf7hd78/deoUO0uXfkDqipK1rIKCAgAj/9CNDShiSUegwYosZQA37Ozk5+cDBULhWbt2LcUOaLdu3dq1axctGzVggPTJkycTKgoR4zCRq7Smpoamv2nTJlhQQ4ARAnLIRLKjUshFGWCy5oyvpchTp06dMmUK6T5u3LiKirHsg97hw4dTiST0peUlJNGKFSvYP3bk6LnTZ0hjJ1/48k5AGj2dmsnODlEXmMhOJpXmVOcGRAS4O1qZUbmIW7duHZuke1dXF/0FG2sO/qO1tZUQ0sA2b96MTzBu3br1dv1tBBEtltk5oW3bthWNfoemg8dVVVU0S3zgFOP0jM6FQ/sZeC8JxS4Jc4YOHRoO99DhsIso3717l7IDvcJB+bz8Eol+nhoHD9VAH+2JkV+QMSci8NLnSK6c3Pz79+/7s4LTZ1aTL/AyoHGAZSK3d4QVEVD7cWZZ9xq+2bNnDw7xNkQK2YSNOPfJJ5uuXr3K2ycajRJXjsRFI8sYjsczqqvx4+TJky5NRQ2oLnh/Ec3LzBhO8oOi3+vrTyaARG7rirBGJUgyeM/cudOwf//+5uanDlyU+erVq7ncUXDz5k2Shd7tJBqiyysrly5dOqa0FFnkVzKdBkkeaYX5+cIPIikCJ2InhNtvUrkjHHXAGdgVz0mLW+LJkyfkHjjDzxXBwxBZ1BbEJEtLSwtucRrKzeEJSVrBzpHP543HYzhKJ3tbpa3YBhMjOiO9jpd26Si8xSkAsIIfALEdZNDkRAu5DrHz5RQ7EM0XoUQLLidyblV0UAb7bwZLGOWunpj4Zw/hqCyuNDj5IgJNzJlgEDsMlgxBaavniz4IbPkS+hxibjpHn7OP+DdLUSRvr3n0ceZSBQiJpHjCaHZTlhUpnRIXgtfnQaXjHFc8vLBkdFFzGOT2iMdVOpPSxE8QxsBvCtxjQc7QBFXMtM8GPgjFMxbkJOnjuOIoEBF6fSGgAEqR/rrOnIFz4I8+drDJUfnGGfbfaPkfIpk8NP39D80AAAAASUVORK5CYII=https://mb.nawcc.org/image/png;base64,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 London
https://mb.nawcc.org/image/png;base64,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 thought this p was 1910 - it is certainly this one and not the 1930 "p"
https://mb.nawcc.org/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAF4AAABCCAIAAABRpPbZAAAni2lDQ1BJQ0MgUHJvZmlsZQAAaAXVmnVUFA3472e2l6WX7u7u7u6QRrq7kU5pQUKkFSQlDBSQUkokBUSUEAEFBUFRwCDv+L73F+fc3/3v/nNnD+xzZoY5O8yc/Tyf7zMAwPvCOSjID0YKAP4BYSFm2mos1ja2LOhlAAUwADiADBB0dg0NUjUxMQD+r8vPBQD8u/GV4N9j/V93+583kLm5h7oCAGgCbXZ0C3X1h+r7UM3hGhQSBtXzUD0TGRYE1bBaqKYIgT4gVHf9rT3/rSf/1i7/1mv/7HPJTB3a5xAAMITOziGeAHQq0MIS4eoJHQfHAgAo8gA37wAAIJMAABolVy9nNwDghbYBAv7+gX/r21DN4/LfjuP532pnZ5f/PKazs+d/1v+eC/SXAID0NnSGzuv/7eLvF/4fx/z7Hyd0D7Awh94x0A8D4A0YAs6Aa5j7lb/nAagHBkWFeHt6hbGoQlfFXYBFN8BVSIBFTERU9O/m/2+Wv/fjvx/2wOyf+wykevlf62K1AUDlIXSfdP3XukuDANA0BAB4j/9axwndI5TZANBP7BoeEvHv8RB/35AAAUACUAC0ABPADvAAgoAYIAXIAyqAJqAHGAOXABvAAXAFvAB/IASIBGKBJCANyAauAzeAMuAWcAdoBFqBh0An0AsMAM+BCWAGeA0sA2vAJvAF2Ad+AicgCKJBIhAP0oLMICfID4qBMqASqAkagGagDegEeoIBYDgYC6aA2WABWAZWg03gA/AJOACOgbPgIrgOboM/wGMYHEYIo4AxwrhgwjAZmCpMH3YJdhnmCQuGRcNSYbmwElgNrAXWARuATcBew9ZgX2BHcACOg1PBWeGCcBm4OtwYbgv3gIfA4+FZ8GJ4DbwN3g0fhb+Cr8F34X8QKAQewYIQRMgjdBAWCFdEMCIekYMoQzQiOhDDiFeIdcQ+4hxJhGRA8iPlkLpIa6QnMhKZhixG1iMfI0eQr5GbyJ8oFIoKxY2SRumgbFA+qBhUDqoSdQ/1DDWL+oA6QqPRtGh+tCLaGO2MDkOnoUvRLein6Dn0Jvo3BodhxohhtDC2mABMMqYYcxfTj5nDfMKcYEmxnFg5rDHWDRuFzcPWYruxL7Gb2BMCMgJuAkWCSwQ+BEkEJQRtBCMEKwQHOByODSeLM8V54xJxJbj7uBe4ddwfQnJCPkJ1QnvCcMJcwgbCZ4SLhAdERERcRCpEtkRhRLlETURDRKtEv4nxxELEusRuxAnE5cQdxHPEX0mwJJwkqiQOJNEkxSTtJC9JdkmxpFyk6qTOpPGk5aRPSN+QHpHhyUTJjMn8yXLI7pKNkX0mR5NzkWuSu5Gnkt8hHyL/gIfj2fHqeFd8Cr4WP4LfpEBRcFPoUvhQZFO0UkxT7FOSU0pQWlJeoSyn7KNco4JTcVHpUvlR5VE9pFqgOqZmpFaldqfOpG6jnqP+RUNPo0LjTpNFc4/mNc0xLQutJq0vbT5tJ+07OgQdH50pXSRdFd0I3S49Bb08vSt9Fv1D+iUGGAMfgxlDDMMdhkmGI0YmRm3GIMZSxiHGXSYqJhUmH6Yipn6mbWY8sxKzN3MR81PmHRZKFlUWP5YSlmGWfVYGVh3WcNZq1mnWEzZuNgu2ZLZ7bO/YCdhl2D3Yi9gH2fc5mDkMOWI5mjmWOLGcMpxenDc5Rzl/cXFzWXGlc3Vyfeam4dbljuZu5l7hIeJR5gnmqeGZ50XxyvD68lbyzvDB+CT5vPjK+V7yw/il+L35K/lnBZACsgIBAjUCbwQJBVUFIwSbBdeFqIQMhJKFOoW+CnMI2wrnC48Kn4tIiviJ1Iosi5KL6okmi3aL/hDjE3MVKxebFycS1xJPEO8S/y7BL+EuUSXxVhIvaSiZLjkoeSYlLRUi1Sa1Lc0h7SRdIf1GhkLGRCZH5oUsUlZNNkG2V/aPnJRcmNxDuW/ygvK+8nflPytwK7gr1Cp8UGRTdFasVlxTYlFyUrqttKbMquysXKO8ocKu4qZSr/JJlVfVR7VF9auaiFqI2mO1X+py6nHqzzTgGtoaWRrTmuSaFpplmqtabFqeWs1a+9qS2jHaz3SQOvo6+TpvdBl1XXWbdPf1pPXi9Ib1CfXN9cv0Nwz4DEIMug1hhnqGhYYrRpxGAUadxoCxrnGh8TsTbpNgkx5TlKmJabnplpmoWazZqDne3NH8rvnPS2qX8i4tW/BYhFsMWpJY2ls2Wf6y0rAqsFqzFraOs56wobPxtumyRdta2tbbHtlp2t2w27SXtE+zX7jMffnK5TEHOgc/hz5HEkdnx3YnpJOV012nU2dj5xrnIxddlwqXfVd115uuX9xU3Irctt0V3QvcP3koehR4fPZU9Cz03PZS9ir22vVW9y7z/u6j43PL55evsW+D74Wfld89f4y/k/+TAPIA34DhQKbAK4GzQfxBaUFrwXLBN4L3Q/RD6kPB0MuhXWEUEPgnw3nCr4avRyhFlEf8jrSMbL9CdiXgymQUX1Rm1Kdorei6GESMa8xgLGtsUux6nGpcdTwY7xI/mMCekJqwmaid2JhEkOSbNJUsklyQfJhildKdypiamPrhqvbV5jTitJC0N+ny6bcyEBneGdOZ4pmlmedZblnj2SLZxdmnOa4549dEr5Vcu8j1yJ3Ok8qruo66HnB9IV85v7GArCC64EOhYWFHEUtRVtHhDccbY8USxbduEtwMv7lWYlDSVcpRer30tMyr7HW5Wvm9CoaKzIpflW6Vc1UqVW23GG9l3zq+7X37bbV2dUcNV03xHdSdiDtbtZa1o3UydU31dPXZ9WcNAQ1rjWaNw03STU13Ge7mNcOaw5u3W+xbZlo1WrvaBNuq71Hdy74P3A+/v/PA6cHCQ/2Hg+0y7W2POB9VPMY/zuoAO6I69ju9Ote6bLpmn+g9GeyW737cI9TT0MvaW95H2ZfXT9Cf2n/xNPrp0bOgZ7sDngMfBh0Hl4esh+aHTYenR/RHXjzXej40qjr69IXii94xubEn4zLjnRNSEx2TkpOPpySnHk9LTXe8lH7ZNSM70z2rMNs/pzw38Erj1fN53fmJ10avZxcsFt6+sX+z9tbt7edFv8XvSxFLJ8uJK8iVrHek74pXGVZr3vO+v7cmtda3rrE+uWG+sfzB9cOXj6EfTzdTt4i2ij8xf2r6LPa5d1tre2bHbmfzS9CXk920PbK9iq88Xx99U/k2uW+9v/k95PvFj5wD2oOGQ4nDwSOTo9Wf/j9PfmX9pv3d+Efmz+ix1fGnk8hT9GnJGe9Z97n++cqF/8VFkHOI8z+9ABz6DfPwAIAfDQBAZAP1DjMAQED8b7/4zx4AAIdaLhhUF4Hs4HdYGtwcQYAYQ+agzNF49CKmGRtLoIEjx30kfESUS+xEIkNKRLpDNkJehY+lsKGUpaKhOqF+RzNAW0eXTR/IYMOowsTPTMECsOyxrrJNsndztHBWcuVzX+WJ5g3kc+e/LGAlaCpkIKwloiqqJKYkriChICkvpSCtJKMqqy6nI2+gYKxoqWSr7KziruqvFqmerHFds1qrXfuFzqrukT6JAY+hqpG9caTJddNmsyHzpUv7lggrKmsOG1FbOTsVe/XLag4qjgpOcs5SLmKuQm787lwebJ6MXjTe5D7Evhg/mN+p/8+Ab4HbQRvBSyGvQifDhsP7Ih5Ftly5E1UenR+TGZsYFxHvl+CaaJ1klKyRIpsqdJUtjTodl36RcZD5KWspezpn8Nrj3Ma8iut5+SkFEYW+RQ43zIq1bsqXiJRylNGVk1SgKk4rD6p2bm3cXq6er5m686J2qO5pfU9DV2NnU8fdzuaulp7Wp23D98bvzz1YfrjV/v3RWQe2k6qL44lYt1qPWa9LX1h/2tOSZy0Dzwbnh3ZGgOfUo0IvtMecxqMmiibvTY1Pb80gZlnnVF45zse/vrXw7M3GImKJZ1l/JfBd4WrX+5V1cIPrg/7H4M2SraefPm2T7Mh8cdnN2XvydXMf/139R+hB3eHiT6Jfmr/j/nQdH56Kn4WdP7m4+Of6u0LXfwgeitBDYpHrqDZ0CkYXy4U9JZjDtRGmErkQK5DQk/wmfUfWRV6Gj6awp1SgYqNGU2/RjNO20eXTX2G4zKjOxM1MxPyd5Q1rD9tt9gwOP04zLhluRh44zzbvS75H/OUCiYIe0PUXE6ERORP9IDYmfl+iWDJOyk1aT0ZUllYOkPssP6vwRPGOUo5yuIq9qpoalzpGfUdjQrNZK1vbR0dXl1sPpbel/9ygwTDDyMfYyETClMEMZfbDfP3SvMWk5XOrEesRm1HbcbsZ+9eXVx22HPedTlwwrhRubO4iHsqexl4O3oE+8b55frf82wL6AieC3gZvhuyHHofDIwgiSa9QRFFFU8dQxpLF4eIR8ScJB4nbSe+T51PGUnuv3k+7k34jIz0zOss32z7H6JpSrkgey3WyfDD/oOBj4eui5ze6iu/erCzJK00piyj3rXCqtKwyvKVxW6FaqkbkjkAtTx13PXcDdyNfk/BdyWalFt1Wiza3e6H3Ux4UPaxv73o08fh9x1EXwRPWbpke016fvtT+2097ny0O/BqiHpYesX4eM1r1Ymjs8wTppMyU83QO9M20OUfxSn0+/HXjwspb8kWdpYTlxyu7q+zvbdcK1ic+ID4qbUZvdXw63BbfCfvSsXvyVfVb1v7rH2wHoYejP5l+Rf1+eyx/UntGfn713+sPfABLYeywKbg31DE3Ic2RB6hqtCb6B+YW1KGeELThnAgpCUeJ4ohliPdIGkhdyJjJ3pGX4q0oqCgWKMuoHKhZqT/TtNKG0ynSo+jnGCoYfZhkmNHMCywNrFFsBuws7Ecc05x1XHHcljyivCS8X/hG+RsE0qH7QVeYT4RIZF/0tdgT8SqJFElvKWNpKRlGWZTsgdy6/IzCkGKnUqtyrUqFarFavvo1jQzNVK1E7VidCN1gPS99JwMLQx0jWWMuEzKTP6bvzYbNGy9lW/hbGlkJW5NYf7N5adtmd83e97KeA48j2nHTadj5jkuyq6ubuju7B9Ljk+eE1z3vGz6xvm5+Rv6yAdyBVEGYoJPgHyE7oRthS+GzES8in115EnU/ujGmOrY0Lj8+KyElMS4pIjkoxTfV/apTmn26VYZ5pkmWYbZejs417VztPO3r2vm6BfqFhkWmNyyK7W46l3iVBpdFl6dWXK+srGq+1XN7snq15kctpo6pXrJBv9G56crd3Oa6lt7W+bbd+4gHjA+l200f+T/O7GjoHOna7Eb38PUa9YX3Vz598exokGPIYjhrZPD5+QvFsYTx0Un8lNt0zwzNbMTc63nx1wUL39+aLD5YJl8Jf7f0XmWtaYPiQ9LHgy3PT2vbl3fe73rsHX7L/M71Y+ow/qf8b9SfjZO5s6W/1//f3OAvE2ikAKAOYoUVBwDofgWA29A6ziSIHVCuYEIEAJdkAfBTLACOagFg7lsADvnmX378XUDoBYNecAABGSgaMngCKKIggkyUDMADlAANQAcwAiyQkXIBvJCTigASgAygAFmpBqADGACmgCVgCzgC7oAPEAiEA9FAImSlOUABUAJUAXVAC2SkT4BnwCjwElgAViEX3QOOgDMQCRKDVJCFcoMioCyoBuqDFqAD6AUGgzHgVTAPLAVrwTbIPIfAacg7P4LfwBMYCkYOOScvTBIyTkOYLcwDFgpLgOXASmH1sHbYM9g0bBm2DfsFR8LxkGcKwxXhBpBlesOvwNMhx6yDP4IPQ4b5AX6AgCHIEewIcYQ64hLCDRGOSEMUIxoQTxDjiGXEHmSWpEg2pARSC/JKH2QcMg9Zg3yEHEUuIfdQAAoPOaUcygjlggpHZUJG+RD1HLWE+oaGo2nQgmg1tBXaD52ELoZscgD9Br2HgWFoMMIYTYwdJhiTgbmFeYyZxHzAHGPJsLxYFawVNhCbjq3CdmCnsVvYCwJqAmECHQJngiiCAoJmgmGCdwS/cKQ4Xpw67jIuEncd14wbwb2HHJKCUIhQl9CNMIGwjPAx4QzhFyI0ERuREmSQ4UT5RG1E40RbxHBiZmIFYmvicOIC4nvEU8Q7JGjIH9VJnEjiSSpIukkWSX6RUpFKkJqTBpNeJ71HOkW6S4Yj4yPTJfMiSyerJxsh2yRHkLOTq5O7kCeTV5MPkK/jATwLXgXvhE/E38YP4NcpQAo2CjUKV4oUilqKEYotShQlN6UupQ9lNmUL5TTlPhUZlTiVBVUkVSlVD9U7aoCajVqT2pM6i7qVeob6kIaaRo7GgSaZpo5mjOYrLTmtFK0dbSJtLe047Tc6Cjo5Oke6q3TNdLN0v+mZ6DXp/egL6XvoNxgIGMQYbBlSGJoZ5hnOGLkZTRijGWsZpxn/MHEwGTNFM9UzzTKdM/MxWzGnMj9gfs9CxCLP4s1yk+U5yxErB6s5azLrA9Y1NlI2FbYgtttsM+wguyi7C3sh+zD0fcfFYc2RydHDscfJzGnKmcrZwbnNxcBlzJXM9Zhrm5uB24Q7lbuLe4+HlceSJ4vnKc8hLx+vI28R7zgfwCfF58d3h2+Rn5Rfmz+O/zH/rgC7gJ1AocCEIFxQXjBMsEVwU4hJyEroutC4MFxYUThS+IHwFxFOESeRcpEFUTJRA9F00SHRczE5sQixh2LfxPnFvcTrxDckmCXsJcogZ6SUNJcskJyRIpEylMqRmpAmkNaTzpQek8HK6MpkyozJEsjqy2bLTskRyxnL5cvNyVPIW8qXyi8rMCk4KdxR2FLkU/RXfKB4qCSjFKs0oIxU1lPOU55XoVVxUKlV2VYVVg1X7VGDqemo5aktqDOqu6u3qB9qKGikakxqUmhe1qzX/KYlo5WkNaFNoe2g3aj9Q0dRJ11nDjJFL9123Qs9Pb1ivQ19If1o/VEDvIGTQavBsaG24Q3DD0YiRvFGk8b0xt7GXSZoE0uTOpNDU3XTQtMPZuJmKWavzDnMw8xHLlFd8rzUZYG1sLNosTi3NLGssTyy0rYqs9q1VrYusN60kbXJsVmzlbBNt122E7FLtXtrL2ifbP/mssDlpMsLDgIOSQ5vHAUdUxwXnYSdrjqtOIs5ZzqvuUi75Lpsuiq6Frnuuqm7lbsduOu733E/9bjk0eqJ9HTw7PQi9fL2GvSm9w73nvbh8UnyWfaV9M3z3fZT96v0++1v5t8agA5wgToPmsDQwOkg3qDUoPfB8sHFwd9DDEOaQhGhTqG9YTRhYWEz4QLhGeEfI1QjKiP+QHb48ArJFd8rL6I4o5KiVqPlo0uiD2NMY9picbFesSNxbHEJce/i5eJvxh8mmCa0JeISvROfJ3EkJUHdi0JyWfLvFMuUR6nkqUGpL68KXs2+upOmm9aQjkp3Tx/OYM9IzljPVM28nXmR5Zj1NJspOz57NUcppyrn/JrDtae5zLkJuWt5qnnV12HXXa8P53Pmp+V/KtApuFuIK/QvnC4SKSqALNHiRmcxXXFs8epNlZt3SpAlXiXjpYKQJx6UWZR1lTOUJ5RvVGhWNFUSVgZVvqqSriqvurjlemv0Nv/tvNsH1dbVvTUsNVdrdu4Y3WmvpamNq92o065rqSevj6xfaVBraGgkagxtfNuk1FR7l+Bu0N2FZsXmOy3YlqCWhVbF1jttBG3BbW/vKd+rv090P+z+8gP1B3cfkj+MerjertN+/xHNo8RHnx+bPO7qYOnI7PjeadM52MXXVdh1+sT9yVS3VPetHkxPcM9yr0Zvax91X2LfTr95f99T7qf5T0+euT97OSA7UDtIPBg1+GHIaOjJMMdw3vDJiMfI3HPF502jlKNJo3svbF6MjImOVY0TjEeOf5wwneif5J8smUJOhUytTRtO97zkeVk8g5gJmVmbNZrtneObK3mFfhX+6uO82fzAa5HXVQtEC7ELX97Yvhl7K/u2cZF6MW3x55L70utljeVHKxwrhe/g70LffVg1Xx18L/a+Zo18LWXtYN11/dWG+kb7B44PRR8RH8M/bm5abD7fktqq/0T9Kf3T789enxe3dbe7d/h2yr/gvsR82d21353aU9xr+8r0Ne/rxbfAb2v7JvvPvot+r/5B9iPpx/cDl4O5Q7XDh0dsRwU/YT+Df67/Mv018Fvk9+0/pH8S/nw9djieOlE4aTmlP806/XPmebZwrnn+6ILtIv+f/vE/+P+3A/iX/yioA8BCHQDh/9EBMANsACeUSvMDQlAuLQnIAoqAKpRM60JZ/3/0AG5Q8h8AhAJXgHggBcgE8qBkuhyoBhqANuAR0AMMAmNQJv3mP7uAUxABEoIUICOURQuBUqAyqAOagragG+gPRoKJYBZYBFaBjWA72Ae+AOfAd+Bn8AA8hxHAKGGsMEGYLEwTZgrlzt6wCFgKLA9WAbsL64QNw+Zg72F7sBM4Fk4N54RLwNXgpnAneCCUNV+DV8Jb4L3wSfgKlDOfIogQjAghhDLCBOGMCEGkIG5AXUAX1AWsIL4hQSQFkgspizRAOiJDoGy5FNmKHICS5W3kGYocxYWSR5mg3FHRqDxUHaobNYPaQp2iydG8aGW0JdQBpKDL0A/RY+h1KE0mxfBgVDA2EP+zMDWYHsw8Zg+LxrJAOfIlbAA2A1uD7cW+wf4gIIQyZHUCB4j9NwgeEEwRbOOQOFacEs4WIn8R7gFuGrdLiCXkJtQkdCVMIrxF2E+4QnhCREckS2RNFEl0k6iDaIHoJzEVsRSxJXEk8U3iLuJF4mPIABWgxDiBpJpkiGSTFE3KS2pAGkhaQPqYdJH0lIyFTJPMmyyXrJ3sLdkZxHpd8kDyG+Q95Bt4LF4Eb4VPwDfgX+J/UTBT6FAEUZRSDFLsUlJSKlN6UxZC+fBnKnIqRSovqkKqp1Q71FRQNuxPXUo9Qv2DholGn+YKTS3NLM0FrQCtDW067SPaDToSOkU6X7pSulG6I3p2ejP6RPo2+ncMOAY5Bi+GmwwjDIeM7IymjImMbYzvmAiZ5Ji8mW4yPWc6ZGZjNmFOYG5lXmbBskizuLMUsgywfGNlZDVgjWZtYn3DhmKTYHNlK2AbYNtnZ2Y3Yo9jb2Ff5sBxyHH4cJRyjHH84eThtObM4Ozi/MxFy6XLFcV1l2uJG8ctz+3HXck9zX3BI8LjzFPIM8xzxMvNa8ObxdvL+5WPhc+ML5Wvk2+bn4HfiD+J/xH/JwE6AUOBRIFHAp8E6QWNBZMFOwR3hJiFzIXShXqFvgtzCdsJXxceET4WERFxh6g+K4oWVRINE70rui5GI2YslibWJ3YkLiDuJl4hPi9BJKEpES/RKbEvySvpIlkh+Roiu55UqlS/1B9pCelA6WbpLRk2GQeZMpk3snhZE9lrsuNyGDktuVS5QXlQXkU+Qb5f/kxBUSFOoV/hXFFZMVFxUAmupKmUoTSuTKRsolyk/FaFQcVJpQ6iu5BqmOoT1Qs1TbVstVl1anUH9Tr1XQ1xjRiNIU2cprlmueZHLUGtCK2n2lhtM+0K7S0dUZ0Ynee6ZLr2ug26B3pKell6C/rs+oH6vQZYA0uDOwbfDZUNrxkuG/EaRRo9N6Y0djNuN4GbmJnUmPwwVfuH7hJmV80WzLnNo8wnLjFcCrj0zAJv4W7RZYmzdLB8YIW0srZqsQasL1k3Wp/amNrU2RzbGtvW2h7bGdvV2Z3Ym9jX259dNr981wFwsHJoc0Q62kPpL87JxanbmdzZx3nQhc4l1GXClcM1zvW1m5Bbutu6u5x7ofueh5bHbY9jz0uebV4YLxevPm9q72DvSR9uiO0rvtK+Bb57fjp+tX4X/rb+HQFkAf4BLwI5AhMDV4JkggqDvgXrBzeEIEKcQnpDaULDQmfCBMMywzbD1cKrwk8irCLaI0kj/SLHrnBeSb6yGiUXdTPqINokuiUGE+MeMxDLGBsduxAnFpcbtxOvFV8Tf55gm9CRSJ4YkDiexJWUnLSaLJd8M/kgxSSlJRWb6p46eJX5auzVxTSptMK0/XSj9OYMbIZHxnAma2ZC5rss+azSrF/ZFtntOWQ5QTnT1wSuZV/bztXJbchD5bnlDV1nu550fS1fJf9W/nnB5YK+QobC2MLlIvmi8qKTG7Y3uiG6Rxcv3ZS/WX7zpMSupLeUoTS29F2ZUllV2UW5U/mzCtaK5IoPlRqVdVWoKs+qsVt8UBK8e9vo9r1qsuoQKAuTrLlZ8+eO3Z3eWqbaRIjvGnX19Zh6n/rJBuGG/IaDRovGria6ptim93dV79Y2o5q9mydbhFryWw5bLVuftDG0JbRt3NO813gfdz/g/uwDiQc3Hxw/vPzwWTt7e1r7ziPDR/ehZDjy8VKHUkd1JwLKhie6hLsKun4+sXnS183Sndr9qUe/p62XvDeid7FPsa+6H9Hv1T/5VPhp4dNfz+ye9Q+wDaQPfBk0Hnw0RDMUN7Q+rDXcPEI6Ej6y/Fzlef0objR4dOGFwouaMcxYwNj8uNx49QR6ImBiflJ+snoKMxU4tTCtOF37Evcy5OXijMpM4yzJbOTs6pzWXOsrylexEOsN5ttf079Oef1lwXyh5w37m+w3B2/t3g4t8i8WLp4suS5NLEssV6wgVvxW5t8pvKtdJVoNX333XvN96xrlWtza5rrh+uMNxo2rG3sfLD70feT8eO3j4ab95vAW/1bh1vEnl09jn0U+l3y+2PbYntqRgJgP++L95eWu1G7lHnzPe2/mq9TXim+wb17fpvfF90v3z7+7fR/7IfSj8MfvA/uDgUOuw6zDr0dmRx0/6X7GQeTX+NXwm+C3/++ZP2J/bvz5dWxz3H3CcBJ38v5U5bT6DDxzORs8ZztPPl+/UL24/d/4/6/9I6HnLDAQ+3EAMUAKkP9j/vTQJJrtf3v/v7NoZcj6/51F2wJOgAfgB9E+CjL+dCAXKAYqId9vBR4DfdD0eRri/BqwDRwApyAKJAXpQA6I8bKgBmgMEd4d8vxYMAPi+22wBbL85xDd34N70GQZDbGdHSYKU4YZwexhvtA8OROaJjdAXH8OW4BtwX7C0RDVeaAZsi7cDu4Hj4PnwavhDyGzfwPfhohOjGBFSCC0EbaIAEQSxPMmRB9iFrGJOEYSI9mRMkhDpAvyCvIa8g6yCzmN/Ig8QZFBPq+EskD5oVJQZagHqDHUGuo3mhTNg1ZBW6OD0JnoGnQ3+hV6F4OCpsIyGDOMHyYNcxvTDXH8KxaLZccqYW2wYdA0uBn7HLuBPSOgJZAkMCUIIMgiqCcYIlgjOMPR4aRxl3DBuDxcK24C95kQTcgJTYBdCBP/ofg7wlMieiJ5yN2jicqIuomWiI6J6Ynlie2J44iriJ8Sr5HASNhJNEk8STJJmkmmSPZJ8aSSpNakMaRVpAOkH8nQkLMbkgWRFZF1ki2RnZOzQfNeb/Jr5A/I58l/4xnwqnh3fCa+FT+H/0lBT6FC4UaRSdFG8YriNyUTpTqlF2Uu5SPKRcoLKk4qfapgqptU/VQfqXHUYtQ21InUDdTT1Ec0jDSaNH40RTR9NJu0RJClO9Jm0D6gXYKmvIJ0VnRJkKMv0IP0AvRW9Mn0rfSLDEgGUQYHhmyGLoZNRnJGFcYAxkrGCcZjJl4mG6ZMpifQfJeOWZ85jrmNeZ0Fz6LFEsXSwrLGimfVZo1lvc+6yUbLZsyWytbN9o2dk92evYB9jAPgkOYI5KjnWOWk4jTmTOd8xvmHS4zLl6uO6z03Lbc5dy73CyizVuKJ5nnM851XkNebt453g4+Zz56vlG+BH89vyp/HPyWAE9ATyBAYFUQJagpeFRwWQghpCKUKDQsjhDWErwo/F0GL6IhkioyLEooaieaJzorhxSzFSsSWxBnFncTviG9J8Er4SdyT+CEpJRkl2ScFSmlKZUpNSZNJW0iXSr+DWO0h0yzzTVZCNkq2Tw4mpy2XIzcrTyVvK39L/qMCr0KAQrvCb0VFxWTFUSVCJVOlYqVlZRZld+Um5a8q4ipXVPpUYaraqtdU59Ro1BzUatV21EXVI9X7NZAaBhqFGsuabJo+mg81j7XUtLK05rTptd20W7SPdJR1MnRmdel13XXv6f7RU9e7pvdWn03fX7/LAG5gZFBmsGkoahhn+MKIwsjZqNXoj7EWNK1dMxE0iTYZNaU0dTG9b3puZmBWZvbZXNr8qvn8JbZLwRCpSS0cLdogDzeyrLTcs1K0uma1ai1knWD90obFJthm0BZv627bYYexs7FrtjuzN7avtj+4rHm55PKOg6LDdYcPjlKOmY4rkImnOC048znHO8+6cLpEuUy5srlGuI67MbuFub1wZ3QPcR/1YPAI9hj1ZPAM9hz1YvQK8XrhzeQd5j3uw+IT4TPly+4b5Tvjx+UX5zfvz++f7L8YIBKQHrAaKBmYE/gxSB4i9k6wWnApZOO6IdUhf0JNQ5vCwDCbsAfh2HDn8O4I8gifiKFI+siwyEmI2XFXFqKEo9Kj1qJlo/Ojd2LUYypijmKNYhvigDjruAfxBPGu8b0JlAkBCaOJrInRia+SBJLSktYgahclf03RSalJOUu1Tm2/SnTV++pwGnNaTNpCulh6bvpOhlZGTcZ5pl1mZxZFVnDWdDZ/dkb2Zo5azu2cs2t217pyqXLDcufyRPJy8/au61+/m4/J98wfKeAoSCnYKFQtvF14UeRY1H+D8UbcjZViheLy4pObdjd7SuhLYkqWSuVLy0tPyuzKesrpy2PLVyoUKiorziovV/ZXMVUlVL2/pXKr+jZ42+X2YDV7dWr1xxrNmjpohut5Z7SWpzajdrtOr+5uPa7eF+K2QENOw16jYWNrE3FTQNP0XaG7uXe/Nhs1t7UQtwS0TLcKtl5r3WszaGu+h7vnc2/sPs/99PtbDzQf3HkIe+j08Gk7Y3tM++Ij6Uc3Hh1Adt7Wgevw6hjpZOtM6Fzukukq6tp/YvCksRve7djd3UPZE9Qz0cvZm9i71CfRl9v3qV+1v6z/4KnB09qnZ88snrUOoAYcBjoHSQe9BweG6IfChqaGuYYThxdHxEdyRrYghpc9Pxw1Gm18AXth/6JzjGzMd+z5OMt4zPjChMhE9sTWpOpkxeSvKbOp1mnMtOt0/0val2EvZ2b4Z9Jm1mcVZ0tmD+aM5+6+Qr5yftU7Tz0fOj/9mvf11ddrC/ILNxd+vDF80/gW/tbxbfci5WLQ4sQS11LS0sqy9HL+8u6K9kr1yuk7q3cPVnGrHqvP3tO9D3s/vcazlry2vC65nrf+eUN1o3zj8IPhh/oP5x+tPt7fxGw6bXZtkW55bT37RPMp8NPzz4yfwz5PbLNtX9l+ucO5E7Mz+4XrS+yX2V2u3ZjdmT2Ovai9qa+sX8O+vvhG/y3g28A+ft99v/M79rvd95bvZz+Mftz68e1A+SDvYPVQ8DD2cOKI9sjz6PFP+E+Tn5U/t39J/Ur6NfWb5rfr77bfv/+o/cn58/qY6djjuO3454nSydWTiVPyU6vTytONM+4z37N7Zz/Opc6vnHefn14oXcRfPP3L/1APcbG/EQAAEqpBj5+tXlwccAEAugAAzqB84KTm4uLsDjRsXgGAZ37/Pov4d2cU9IRmRfHf6n9a/hc886oSy6twIAAAAZtpVFh0WE1MOmNvbS5hZG9iZS54bXAAAAAAADx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iIHg6eG1wdGs9IlhNUCBDb3JlIDUuMS4yIj4KICAgPHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4KICAgICAgPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6ZXhpZj0iaHR0cDovL25zLmFkb2JlLmNvbS9leGlmLzEuMC8iPgogICAgICAgICA8ZXhpZjpQaXhlbFhEaW1lbnNpb24+OTQ8L2V4aWY6UGl4ZWxYRGltZW5zaW9uPgogICAgICAgICA8ZXhpZjpQaXhlbFlEaW1lbnNpb24+NjY8L2V4aWY6UGl4ZWxZRGltZW5zaW9uPgogICAgICA8L3JkZjpEZXNjcmlwdGlvbj4KICAgPC9yZGY6UkRGPgo8L3g6eG1wbWV0YT4KQThD5QAALGtJREFUeAFl3IeSHFl2HuAyWd63QxsAM7PLWRMKUnoEhSL08FJscElqdwZj4IFG++7yvkrfuYmhGFQuWJOdlXnz3P/8x95bLG52V4V0FIvF/OQ/fe52u/1+u0+Hr9yW3+lzmw4XS6VSuVx2si+WiqWKe+OpXbG4L6Vv46viPovbCmU37ffx7G6z3+6W1ay4c5aO7Xa/Wq0Wi4XP25v7zWazXDpdbda7/C2e7/R75XKpXq83GrVmvVouG8371r4yzm5n3LUxptPxZDKZLaaTxXi7Xe9igF2lVCmVSFLa7TfzqbfEq9brZWEb33o7sQvlkqmVillmWJcd+YTz8//4adx//zOeSUfR+IUkUnqn644YpFAsF4q7YqlQIujWPQVy7HZxd2FT2JY2uw1Q1sv10rFY7zaru/vr/XblHpKt1+v5fD6dTkk8m81Wy40/F4ul6wbPX+0zy8rNZrM/6PZ6nVotNLHdrdqdpmlXKllWoY+dCZs3kGbjybYQqqW8YravVCqUWCrQU0wrHg3x8rnEeVaqFui3XMgCoJhWEj7NLR4o7EOrcWyrWSmRI4A1esiXxtys17Tq8FeWZS4ahggxdMHsN+vlKtdDsVgu7YuNRmO12hJ3Nl2MHkfX19dXV9ePT3f3N1/G49Hj4+N4PAEXFBxogixgJ8FmA7Wvc/Nyk6hWq7VazTsDi2oZg6rV8vnF6cXF2Tffvjw5Oep0WtVGu7ArLldzsjUqNYjELBMPzMJFOiL8foNkG5P3LZS82LuMb6JZmmaQDP/pm27icw8vfwOisA8qBige9unciCQ2gX+/QlxXjJgVq5tdjF7YhCo2yxVWj0ej+Wy5SfSdjqbD4fDp6enu7uH+/n4yHn5493o5n2HKfB7GY/CEA8va5xaeG7p3hVZKJVQgQ0yzSPXFrFqu1apZLfsv8z/D9+7u7tnpydnZMwdmHR0cdzrtrOrZbBMSrE0/K1cB2m52AtNyleltVmAKTZQKmzLKB5v2xc321pQDMvSHczp33blPfMNNf+SSeQMMSO8gZU4i50nDO6qgnEq1tl5vl+xgsRiPx9jx+cNHEv/800+sYzwc5cdkzGJm6+W8EnwNUgDcUFBNryMeC8q8olxmAqGYuLQvgdDrlsvteguaQqnCiMrM2Ge73R4MBljz3T/8/p/+6z/+6U9/cl4or4NhWZWJzSbzxXIGT9A0a83JZPT0QFOPnBKA5hManCX84wNr/AthyFZki+F5ksUwODQKzDZ7MCU3FkYad8eTyZtiS/yRlSurHd+xms8Wu7WXDVHiIR1XV1efPry/ubn55adXiLaYBWawY4jeBZZWvVCvFmqVWrGS7XbsJbjpMBsDB9ZZzZ8Ju7DsXrc9my9n8wn/GWiRkOj73XzKfocGR8mH4Yhp7nclbzw66TUa9W63Z6DFbDGfz7iKUqnYqCJNvV5psvSnx2G8qDSpLWuGSu58lwUvv+rJbL0qt8cAJd5bKpfKFZ5jCxxu1V80VObnS6Hk9Ro2UMI1GMGez/uXv/719uru/Ye3X758gRBBH58eeJNSsvQSiuwLHGW9wUOxWPZZaFaLzWaVbCYJGoMncMLeXazVGkyVMLzykhPal2dLJliLuMVf7LY8lPPDw0NP8QWL+erTu8vpcP74MH79+vU//rc/np0ff/vN706eHTUaLYhvV9zoJitVmrViuReUzIJz5XrWWK1hOwcoYqIM6QIdQCbJ4iMQCnCK8AANVVKX66wxp5Knqo3mcsZipjM0nS/v728vL68ebu/+5S///HB3hym3t7ez+RQ7dkLTttDrBRA5HCbNL3GePrv1mHm9WsuqECuZG3dIXwI6mWqVeqPVbDXaXPlmxbOvZysuvgCO+YpvijmkCLYu8yhZ+NpKtmKzT0/jn179yp3NFpPnL05mUyT7/cnRM2+r1OsCheBNBY1GgC50ml1WriPBaPwEHeP8Z2iQCQIJHUgl7hCqvM925b3ovzcEspB9U1hsH58eP3/68vny4+Xnq4+f3n/88Pnx/nZ8/8jRzKdjz7fqdShUMsCLncUMDQSw0FEFyTvtIHO/KejKN+K+rJitd1vOm1tczpb7YrGWwabSalQ8vPW1cLlf0iLoONTtKiQMhKvVjawkcKm2W71eb8CXodjt7d2//cv8+upgIhJMpt9//0ceutfulSqV3XZBDC5ZtrFdRT4l84rIatAINVvQ8CLlfcQjgTxFo7hiXqJ1hMoAlVwZdYbBy562CLdev3///unh8cOHd2/S8enDRw5lNhltFkuBg6zNRq0uFGCDQFfeCyPQkQoAgI13uq2Dfo/jBA19eB9DTXa6wemg9XyJpNheqwKwSUHrpRFWosVmW1iWEbmyXm2rIle5hjIkNb1SVu12u556qD2KAMjzNIwUQaLkLWYEyuIJ+21G8oIZLCmSj3k4+8q2UMId8q4j5YtIFG5FkBB0xUXTcEOizE4MT77BJ7OLG+PC4+3958+fX/3wtx///sPf/u1fSIBIplXf72rNxiJGLTXr9Var0e202g34yNH23VZTWPRVrY7GDd82G/VwJcmPRk6bwnOhUNt1GnQwW4AGNQhH+NJ8uY7UmKufTcv8D+ecVca7xWrJ5LeyNI+0OgOGL/BVqqXSbtWqg6C/zwrY9ebd6/F0JE74t/nTn7///vtqo1qqVZFvMhuvtqu6u7PiZLLlN5P7r2WsGjlxQ95u4hEkIypFssWwcGm/3EQOvt5IPabj2cPd/cd37y8/f/zL//rfV18+3159EaL5B864XpFfVNsHXZRpNevtRpPF8BOthvyh1KjX3BOsqfEy7ASf+L5icb0NZeCpgmG340mkkmZYrTDhSoEpo/faGyLlwdbg/F4SWMYRrg9qAs5yvW02WxTOWdOhYqRU3lWyIoq2D3vT+QyjxcoffvgBgpVyhq1HR0fIhToOHxEdzDxsNaDxiTUuhtn4cKsaByokAw2CuJlLl85PRuNPnz69e/P2119/ff3LL1ewef9+s1oKwm7wcEDDTDqtwdFhq9XqdVqowYbqjVqnBaMq64J5hKTgJHLnKcEOOiZgFtJ5FcRmy9WKiJtsX8izGjHUhSCNBGq9XQRy69V6N4/UhowFKa3/q+3r4RWLoFyHRkvFChU1qs+Ojp/Go+Hjk7BAfjrodbrCGUVycCqxmHVKZYMUIPntCGhCyoRC1H5hWjt27KYkcHH/Gy4//vC3v//977+8+olbkSoJnDCP6FLLEu1kKDU2DIRus9Xv9nwjRkI8csJt1sjE5t3aX8so/xyijCSvVa2HwZXDqMVghYTQ4xHVmGqAXe62hclM0JEjSoi4ybhttlzPVwX82fKdYescZqHRpo6a2Lbbr0V3ULd6jRcvX94J40LpVLjcAOiXX35x32F/wJwdWAMNhE3IFBkrZpANNIQP7+sO507oZLvd1Cqya+IW+NrPnz4A5Yf/828oc/Xlcr6YBBMj51NIRugpZ4FpYL/fMyI04WQkghFhJbxLfmT3NByKa0YWAhzxFYvYbGWleBM2VVIFKp0Wk/mUZERsNtr1+kwCFbBMF7lXrjSae65tvyzAGH0gF/Gt0uo0T06Ppb+1qgR7PRw9SH64urPz83JWvPzUatQq0nFK/fXnV4vZ5A//8DuFaKOZyivpVhTF0oV9rV4RncrLcviaoLb8JaCJI87DhlP1Op/h4ucP73959ePrX39REU7HQ1Uzm5OipfRMfcCdVTG4mjJYvgInZpMJvPUEzJ/L5zZ5R8wX4qiCP4ZjVm+xI6SNfJJfCcdTkLqMpnOBpVKj2mW1Cia5xkx+12p1Op360dkzeV5jMt3dPAxn8tt1tVbi0VmTWNjtdQ4PB8C5u6l//vgBU75cfvpyffV4/wBu85LtyXouLy9//vlnMnA6Ipopk8qUE4MyMrMYlQFZIb+TbMnJmBaPQIdcMf9yf3t3dfnp7Zs3r3/99fryy2IxFYw26znTrw+61SwTZ3gWWqNSo/GtGDsePsnfOEsJCui1VeqRwYg7xS1MsiK/TCYHk4ESMlEEw1S23txe3w6HI0nNdNFsrMvVhd6FaCWEH7bbh8+evfzmWx7gcThebAuX9/eL9Vz6WKqUp4vpw/CxP+oMDjrNZs8khdG3716bICaK4ky2022zCDPnJX9+9WOzXoMjSoTriGnvZSmRftF2pMiESsQJ1yu/EeSjOmCwW5BL4X599eOvr159fPt2PB5SfqtZLRW3aMMJKSflY/U68xZaghHGl60EAUtFaZt3lOvVTq/T7LQn02kUFRw2ZVWb9Wa30xtwTe1Gi5URQ2bM1ao4CThZRBW+5FxrjXWUnbtmp9Y9ODw5vzg+OeVis9rwy+2DMCHJre4jhq7W8/Fk+Ph4f/rssHTY59K/XH3+27/+4Cu6k2MdDPoIohNwn1pCiHNxcaHckyAKIDk6BDcFMJlCFnmt+F2Sy22m87WvcIHzUKXe3V5//vjp51c/XX76DGYxnnl1WvWTo0Fh3+UsdAOY/WY1GwwOlba1rHZ0eChdHRz0GUi730OWXbnIDsbz6Xy5RChh7u72tnT7MDqYim/EKhyUz87OiEKmZqs2Wcw5DpmikCaydAP95vRxiCk9c+v3VNWKlqxy2X7/ARO9FSmUKcDdbBbPjgfTqemPuH7/YSVaN+12a9Dvt9rhpVvSinpN+2I0Hl5df/lyddnrd0uVw2IQJexLd0TFncEKQrn39YXYFP6I0bExUVQJxDYeH+bjkdSi6ruSiKfbUZT9dVo9SHMEHBjh8Ea+YIIX5+d6Jdx9o93KGlFPN9ut+8fhL69/HU8WT8PpeLosbYu79SNlz2frTnsgWUkucNsoNHr9g4sXzwH04eM7eFVA1Ki3eOtms95qYp8s2QXKOD09Pz4+Hk0m+AVWwUtyEnot7Gbj0Xj0tF7MuVEJJ2uOjuDBADuCjYvlqFxeL5YAkq+enp52+32hChQyp4gqKS/PcmsCub/zzM85aIwg4CnPHm/v5pMpCwM2vrVatU67AQ6GynVtN6up0LrAqcqiveQ7JJqHJ4dqZhm+SqnWUv0357vdw9Po05erjx8/z6ezUrRIi493T/KL4+Nn7W70MaEjq8Oj7777LjmdK1YZuUGtVihlrW6bB3CotbjOTq8/ms6urq/H0wkyklZkqGQl+bf6kWmNHh6lqbVyQWIp+Rz0+keHR6DRkzEvShWtdJGw+Pz8/OziwhXehCf1Or5F/RC+Jj/IqlhiauGKd1sptbYTxw4XvcyKLEP/J9u2mrV+ryXsGSs8zGrlHcvFZjGP3hTRR5OhmFwr16JNXs2UUlmthm96eI9Po/unoYysUsh2kraFJLisDdrutuhfDWIobaeDo6Oz+eTk5GQ4HqEv/BVcghOVEoZ3UKgjUafZOjs9hYtq9uHxzli09ezoUEPny8dPo6eh4qPl5ZUo6x3cTb1WJzMSNesN5uZ1JmhAwYuaw/WKJDX1d8prZByRmsaRo8I8o/ZVFEBGq1I0ZWhl2GhhFYTYkoq51VZSf81lUHE8Wt7vHjQJdJHuHx+Gk3Ev0yNSWeoAkE2jSqFZ92dWrik+29UmhtTKsr06Sh8c9QFBeimZElcerVn3/Pnz4udPVzfXXnRydnpw2KcaHuTq6kYvjFOQMkLn9NkztrNaTs2n226eHAwUbdPh0/jxQV6PL10uRsWF9uFVdWmzbre9WA2m84mIbMBIMhdTXeRG1iRDiLpZi7BfWRNRPTXvGGf44+lUi+7xTqfunruVeGicRLcx1YfNZqPXawe5ow6rye+m0yXELY/IU++faOJBO7vW73hKUsuRRMpR9dKGf9m22Kq3KvVyeKx96f7m9stB9+XL553u8V5dvd9zlge93osXz3XkpCSIc3TQ1xLnQ3utfrs6aDTa5AfZ0cGhaDN6vJtPo013OOjz1KxbzqFzBAz5Dj1SjvMtntajgX3Q60uCsMaSBRKhDL5jEG7p+iU/k6aWW1P+6QJoZOOSInboAJD0FdWJgsPF0qbdrFMOryaCEq7Z2G8HjIO3rSuRVToK3Ifhg8LppHQuIUa5bLfNm7xMXftKM0ryVKvWVUsC13j1VK6WXjw/7w/aUWUrPhq8WPebb76ZTEefPn9At4ODg/PTEzo4PDgdtPCryRdYSdFB5IB1YkQN6dXZs2P10e0sOmqKJmUiLapkk3+NBjZamr87kR8x16H4JR6oWlLhinlf11HkE5l4JCLxLw7uhityVWgS20ajoSjI4iRp9aYRG9ouxtWLVwegnGO7MRv1gbiA7ZvJdM434E4ELLGsWpFZO9wJFmm7Y7/aRVZVraCnePE0Gm+KG93Sb7572WjVdArwK9vXTk6f3d7f9AcDcjGfbkdW0hf7tqssRat6k/RZMZrh8wkPzRH2+h3i3ewLfK1uRbfd0SHcRnVSNnPQkDB8iobGPppAZp0aQ3MtUX06BZ9/2yyaquQ3uA7tLpoRUd0ttBU228VwyF3eXF1/0G9sN/VQ0/+azeOTg/Oz4wuNsl60i8zZJJmONhSiKo5ev3l38zS6ubn7/g9/UhldX1222t3+4KDbVHhL57mecnUTjfD76eNsNGXbXKqJv/rptaH+x//8772jo/unW8UDO5Lz//kf/4kLlOrpt2pHvXnzTlNmPJ93FyK5vLFx/OzEcsLh0ZF2QbNWHc/md0+Pi91mtl23a9k2yvrCcr1g0LNlcXmj7Fq1Oj1kGT6O1PkMDYuXk/luvdNAldHFpPS1dN6cAVIVZRBQyZvEfd1j2uC3ZPZVEtRqeNI/HJw+O6Y3nQ7aQQTskPLKF42R55GiCYcPjFw/vAkXLvJxVMLnTUto825Frv5dtFU2KFkujxjheNw77GPQ4OQQo0RI3OkfHnxbYHqNl8+/kb9fX14Nh2Mr0e1O7xm/fXLSbtNZQwYQNrIX4DSqZ09xz1bNUuZJyzJQaxfRm1TLsOuYeTpMOkJyNOeiURSLTTlrStEtkj3Ewm4yMKsFwbpKscCN4d6/2x670Grudjs68ufn8qMTpQBHzkBY6Xo80rr2gqhc1V2F7dPwYTA58HgCPda2SYJTnry+vgVoyJH3hsKat2z+4eneYpBQxbs9/+YCHdZbTeL1weDweHAi0zkcHN1c3UqysOZpNDs7u0B9fks7g13U+32voGZJytvrm5vbK30drlckhnssFmFgeqmTnAr+NEefiiJXnBCYOvW/prFWZeFoIXpF68y57CA12GKgOHSlk306ZW61ZhVxOr02TyNf9CVOsSCK4ixnopi6hp4qlfwpzhtlAIZR+MiQcK3XaUdqpGdnrcPSvLRKktZtK9n0LtQ/H99/gI5owLkwfqPB5fjwpN8dmLyY8OHDh18VutfXAooX+SQACcO/d7vuj1TsPvYRAMU4rjhyjBJX9FlT/2glO5kawT0B31d+RBKTe2Inlju1XLWOLGCE1kVXt5qAgdzEd/mABZoIHN7iT70mn/A0OhdoraNRVhxWNQTCEcZShsWQEL0QpUO8m3ScIjo4NyzCChwSEDJpIWoBs0eZ1OvXr89enh2dHB4cDUTJaDnyi+kwGpcp4t7d3ai5pPn+TbOxxAQGkifoCs+6BeKHAfOOUqBfayoAiefIDcpQebQmJ+DA6pOcpkw8QqaFwVgwjHYn5igphW5TgbEjbo0+DsTUciW4VBvCjbbjTHGAUZIOjkZ5T3jOq9HCa43FgbQV43gcCpSINPftvHkYwanRknERCCKcTqlYc663CfODgWxgf3t7ffPlWlWPJtaJUmcr1Cs4RPXNCaw3i+lM7aPX63X7/aH5QMdsi7upRdu8m2eGrnuLz0atZn3g6zpfagVjA5RNXBAgrXKcqwJcPvG0VBDcAYcxQlbDBf9z9BJ+bgUn76TVnncpDbrVKlgvyLifxSMJu3Bs7oyCSdxo1RUO7AKxD0vVXj/lBZYoa/oPsQADdsWIln+5WtTo2Ve4/26n0NLctn/EU+QWsI+OTnDkaW5Vi+fg0ILdYCKgRdE3b34NRpTLUnOWq6zR/ZC4g0ZDEEndlnxIrMQ7MXPsYPUxowjiG1cgwtNJmgAEpkDAU+GSI5CndZnkRZVh6vIcJiEN7G41kFEMnb/JOUshIh+GkyIUTNlpfEiZUz5NFOmKEmb0NCYxBmmTUpGhvN5hUSFqjiJMLDda4VUZV1SFpmPmUdQ8PEnYrFK7WQyhDu/1Rn5FnqWj6NXyICsEbBDvDI4vSU9bXCaecySgMFM0WcLncyGDk7huTQeRpNXpyG3KV+4kf35PxkcqtxSU4cmqmToalyDq0x2GMJA/PcP4R8Oh6K4QwjQcFv1irrUa4fjI0WTmCk5Qgm81Mc/On/vKxNonp9vx2FCcUb/fn06e9F/bnS4SuWifh0qytVyen55B5y9/+Uu1UecATURI3W4XCf/dZBTbcKxW0PZsOtZO4hNb9Qa2W/tlwd5I1YpvPKJd3xKbACQ0YSdmE357tsj/NGVunrSRIulE8jKSEnftS7abfN2VhdjcTSwzamWVlVnWSGKxyBBGVzdb041FH0EwltIF5oAScPIF66uGEsaQCAoAlZWsFtp1q4hN5aqH9lPratZnm/1OV2W83y5kf+1WTZPJIxEDZ6YT9a786/PnL4L0yckpuUMB4WJ2pmTyKNtt0cr/q32kYHjIW6ICdebu33RCr4a01DebgSaSOJ+VDPRUzGzpG4lMMD+cB5vAF8uT4QT4Go4mmjWE0EjPmUYtDnwDk14J0WnPM771euHMNLQuFRyL9aJQXFXSiqotClZQvLJQ+Gp0LDX9WZAZgNjjNGPg2VSlgIyZCn4twYyundmwu62kTWux0+794fs/8fzzsWbG/HBwMONDtI2sOmjuzhcAHQ8fb66/PNxdUKFp4stqyeT0iGclQaPS4BJoOnmugghg8iKUB3NoLi5e5GQhoSOHBuqRPvMNu31AprYgN+cPpDAf/YRmrJYgWVp3LRFdg9aeoJhQSeUcC3gr+/GsB9lyseFQtSzrFs+QFcomQF/hkhZLLk0t4iJnIQZgO4Na2ixQ2lY1dWqcYlBXvELVeaMxnS2lvJK3p/sHPjI0Ydk1ZWFkkwGYBog5crqU4AhVBweDcrln5SPC4nA4nY1TWR7NF0yRYPk085xBbkBAIwhMDjM1YJI5TM8yYLWatmDKhj2DhGE1Sate74oHuCfEYTUWnPBJu0pnv1j1fABYKJWHWlybTezlWYQ1sReOfyWapDzYa2iZ8SPw4PBI1VSpamVMhIPDw4PVfET3BBbKWZ14RD55j01O46l1KL1eXmX4YrkRxdXU+cQS88tqVBNjqpWscn9/9+XL5fOL8163+/7N25svV3bACeVxQ9mmg7zIsWOUdOG8r29v+G87l0wwj01s1qvNOnARZDaSQF4pDMv+jjCtoEPuVnCpHMv1EKVez49nmmArvSFDNFMzCafdbix6wfnN3lJcZB9R7Ub8nYlQKMa6oidi+SliXKwY+AAcp8ZV4bpwyIsAyFpsd9vSd6/W26ChBrZze6t6GH/78gVbCzOZT0U2xgwU+Q6YEEqQor9upyMP/PFvf7e6wnzIGVlYshGqNQsCKE3pyf2yCgWtskt2rgpzYrLmEhq1WdXiaCWSzMDEH9jvTaxLVhMrLyiUXHf+/OTjBF/sxTAxS7hcoP18ApyWqhY/ydg9Fd/dP07nj2yK4cTQqTYxEo15MDB4eqKxt2/ffvz4cTF76rR1mmO9WVvNmy1I6Nb01kVLbqax2uwYi7Lg6GBgzeDd27f+JCT60LDEhFq8xQ7KTx8/RoFYLH54+y4igh1t2gLdbhgRsqR4bNo05yCbQYAln8ZfXVefQCShB8uxFBcnEo7ABKIQsr6xo7soyYUje2bL0TnsHnR6B8XPny0tWwYoFIYS2M1yYaLC6vd//OPx8cnR8bGhLhtXEGZiujYA1taLnW1p/ZFOpGbKAc2/G6vCnz7aXKFaGHSte4TCye2p6DtXm6ouRJuMx4x09HD/5eOH62cn2PzTj6/0PeHSbnXsuLA7KVo6WXk2LYnFOoE8iLVKYTgaNrLAdgvokWsll2cTo3+2GCAR04KI/gGP4Xaf4MgbNIFDxJz8KGYI72uRBZygUcCy08JyVakPTp9/P51vbu84xGv1KBdTizSoeHz07Pnz83/4/s92OJHk6WnEGdWqev69z52rf/37j9rC9kW9+PZ3Fy+/oUAuaLmYvfn5xze//Hh/fV3PyscnxzpysNfIlnPgcyz774v3j+NBp/7y7Pjtu4+ju5ufl4vJ8IlWLy8vEVNEOz05kYdUL8KvyxS0ASTJpm1TXUf7s98/OTrS8Yylwl1BiaDMmSw19GPrrWTOykGn12VJDOL5ixewAbcjmBIetKAHaI9SOrVBTHmdmnIWMbQVeAAoikVZvdntHRwcnR8ePQPfZKROHcl22u26pnn/YHB6/txSHMbCRb7b7Wx0fFvN7uN4bjOQfsK3335LP6huTe7x7vanVz98+vBhOn5UVfZ7HW1dNbc9QsPRfVQLEXwzlNA0WffX86Oplrn1r7sr+XmJNdniaGEGkBE4hWqtVdzZZMttFI38Iz/AuSKF5AVPTYJ5sCC9IIcKDBznzy/wpd8/oNE8bIGYhDHllFXDiFHm+bc1tmU1rSihS2JSdJ74ZobAUak7ry7PJuMnC6Z2tZbsd7ORpRQb2yQNgpUT0mAm7DFFE2ufNejHFantwWCwmM0+ffrw6f2Hv/71n2PryXbZOT7gQQ76FryrKB+/WWDPUsui9lOl0FFGsAUtiCdL3WZFedYMKrVMlih4yypMnxfLLKdBITqVliqq7aaG8ddahMNOtWh05DCO09BI5IOsUlxcXMhxPO4w0dyfoK25w0VVkjaKON0Ea3zhvhw852Yvkqep9swdzCNVTezFjVwYlFIJvYTn0dc6kYwF4OnxkK/d5uGwk66ZwNXl9d31jV1/OqH3t9fahSfnz3/3nR75SafbDENbLiKAO6iqaP/Kyq4tk98e7M+enYwmlskLAir7EHAGfa7BuqwWdUwprECUjKq6hjj8CIwc0jw5WoSDFBBomq+V4H333XeUHe4mRQbZjREETDNNQEEq8n6y5M4m/DxQaB5bFGQy5ICQ3acCjKcA82w+fho92mGvz6BHqUS+e7jTfPSy3337LX6xyMiR9ZZX68urO21C9SEEb6+vpeTyQLXF6enR2fnJH//wu29fnsPFTppZFKTRIYp+NhXZL7NYZTZSia6N2tnpSWdq92FsUcAdUrEC8d6vWZy7XSGC+9Zz5BDq1OU2VpbR6CsuC3HDTu0qIc8vLr777vcSETPlHIrFqD/l7nC0vgLZ/JDLlLdMO1oljgzydO4m7/OrDqEFWMjC30qqqrva6cW5vUBmqEekoUcfhPLvh1c/CYeSBd7Oa7ySL49J7kqWvKwEYbINxLSn4oiqo15VPfW7bUkwpACxXc81aziIxFwZthZyZn+J17riETOJEkC3yVrtakZcpZlWqsnLyn1LvaIsZTqBVDKSotRN9DV5lafO8dHZ8TNqOTpGNESW+IidCM4/OiSseEQGsw/Ry+tOJ+gSYPg/rzRolFAp63OeEl6urSw17nT71j2eP72cr+ZavxYDzMc31uEY18fPl5hmoiajk4PDZ2cvXJekKcGPbZmTdFlAVN1HL61sqfDxfkvTXK9FUrzX7YwGiN3TzSgCW+2e5XNS3d1JMdZ7ZEid1oDBEUakkhQmYrEn5oNB3pt6lf7cVeJHJd7E2SllEe3k4gytgEKL9GdSoDB5ewrcTtR8+p6KeFIo6VUkW1zGbh9v9LX74kSbKYudjrH6HS2uWDPqtLun5xfo7tceWlHilT7I3d2tPWjySwNZrRNOZZMAMj3ys1pi2dHnV0v2x/KyCiiFB87ZUldoWDtJVW8eNaM3VEnU6uhUqKIlxElu6aTlvZJXKJoC2lQGc9hm4pwW7WK2ZRZjTcGEOQ/WYfOaQG6VEh04Gk1RrHd4xJ8uehxxSIsfHkIo51gDgmQToeOv7Uj2THGiOFFxNYgTS+FsrVgTrLurg/UReQ5ODu5unv/886u3b362MiFURftQEG53GCDyeSV1JjcfukVpceFo0Fcfac3zs3KTnr/aluXXw0eVkn9jCwcyWDv3rB2AZrmIX4yUf/oF+VU9Sc/2o0V7gLnJJRn0zIaHKEOm1jAFSrSHiIBl5V+o8kkGIV+AHy4nzENgIAlw4SJW8I+D/qEek+Vr0ICVtB6J36XFz1AUPDOskRUHa3yXH0EYXtqnmUbhWLbDhfrpTO+JK5DK++Lq+lJgNhxuo5vAFmEqWkeJ8Fa4KyrGaL22e13r9ovKVEav92Z3r6mAPRWl4XQFb+U7F2532q44UzzbBfDm3Vv1Dnfm7VbsTFLJpUxtV9vm6c+gObraS89XVr8mEOYs5ePZaJdL4qfBEY043EsLDHED+26Kj/lWsPiS1buNtuCghQpuWolZ+TsCkswnbChwcSSYwgmxLUt5nZIdrzae9Gz4wK/wkVnR8ggDBvQ01hhi4354p5REwUuUJbGdrnYheKTT6mrIqCoFdlt+Y0kifqBheWQ8munmPMo5ZYw2GFhq/3x5dXl1pZbiJnQ8+FX7aGYT7U7dFE7UTo86w7duK6VRFjgxZzbCiqOdIvez4sgBhc2sXA8FmJ2ikWCpp6dgBq4/A7vUxgwc9ntEli44IuOGi5sEp0AkYZJoFGfR2KMjiyYZUuwrWsalrkwHYh62g9u4PNx4pIEURaER+ocdj2v4ce+RysViafggTtp7IB0Cr2YaVAzce7lsTzFk/lYO7l22+N77odDTkxg+6PesYSKlfS96udxw96Dfqqul2pUmdCTtDbk/IwlS2OvejJ04WENQvPBenpGtgYbyGIsr7jQp3sQVJ2TIGeQrV/BUKuKIZg90/MHh852xHyAdCRfQxKZIiOlCsn/lGi9NS4PdQbH0ezvrtC5Ao3swfHhUqCCDn5La00+I+EHXbKF+sdKaFhJiU3r8mnY5XcVvjvLdPpK32G5GSOW0ZEJqAlLWopTpNVrHz87OLk5tFdJSJTqr/f3L78wTChgdrsCOHW6+Ht1ferJogTh5yznyuZVdH7HxSLZitiJUyvSSoUAl4ZJjZL4JmQArPyIGGjS3H7Bo4IVNJePKOYTQUUtr9qRttKIDQsZkYmkt0h+xAASysiDO1s6HOzmLPoalc4SzSGnI6HIJAPC1hV7TAS7xUzYFm18YiACGKVRqumZZpHuWq+q1s4vnktcXL14cP5PCVsOX0Vyx+PzkTHTShgiyp3jK4rATF+g4LMdOJ70LMd8l7nkZf+bAucF5JF+b8EE4wJ3k5AIH92dGcCzGutw6oqDH+LNYHOIHkkHmxCFI7ngQRyLCdeJ1NC7X9FPWiHWbF9CGVRvaAIeaqNmOX6Z6vTiCv9qXsZF6s58MJ15IRcoDWVqKg9H/0M/XiTWz6GH4zUfaaaKdSmL+Uvir1PVoFC9RwRDPz8YQOCpazinxBYO4f2KQBxauh9oj5YnUje7zafgqrxI0Y3lZvonw/AyRHLCAi/FdL8UqfvzYkhOhPhqL8Cs8oc3XcAOaWDNY1PaxucpmEYQPo8rUWIXzi2+sCkHECB4wtByEROUquyDY3i4Kq2uszI5wyd3hoWTB6p4dj5JOe3/CzWEpBaOTP6w1yEWEcFk4XoTr1LXVlwm22tNs2zSBizb6aLMipVTBmozfX5A/3GH8zCDa2/7jA1J5BW0QDPWg2+KNUY6HT0xWFprFjEAgGOTHDXYq16jK01m71ZXms8+QIL6OnWu0w4zj1CaSupUZwkWwtHyRWF2q1ppAabQH9Vbf9ZAjHUHKvJqyPFguWFk8OLC1OAqDeDwfP6WXCB9zsI2k6McqVvK2Wl+V2MwTVSL1054b/ArBhGNWYTvRf0CDcuwFDH9hPGYatpWykhwaV/UhSQ8RB2fLXIFCwJwgDNq573O8fsMlx5RT9dNMkw1txT6BMK2Unjg3tEkgDKEj1IYE6ULAhdaIxTft9HF9xhWoKYCSo+aC4lcAKXUkmmzCs8Tgagic5kBvkYD5NsQrxNp5bbswgkYnyvg9BXfGMKUwUSJARljEidjnndbzAScYpLkbxPSSqLpwNC8jD0bERQdS+nITVuYAEyPNbceJP2NiQbEc5Zin87iBJjeKTy5Q20KCn0jly7jlt4P3Se7GW3HJJ6ycxif/41JcKVRk0AEQsyOra3xPJI68ZICYA8cTsSNXIklIgHIZVqvFD8YHLImy6oYXM2YoTW3Lb8cCn9lGxsSHxgz1WBFF7zyOUBx3HJ/p8PK4mhL6iBxBnViGjQdSLiV0giUe/e3wbIIuPozhhojwKz/pTUE+/3ST+33+hyOMKrQRKPh0+Iwr+iX+yMmcnoNRMnle0DuCXawvWEZ5CUGRn8i0H7sByB903fsNYFnVGgoWC3WRpcwC2a6oBxOA+IVAIX45ytcwKdDupaxR3YWojiRDiOXwZ261zk1SCetkG/VmIJi+DRBzCNZiY/jd+JPF8Dogg19UHolKAY0zvsqnx/6/I+dLCBLgfD3iTdpQ8c7fDle8G1pJDO2kUFkUb8Gj+F/F8rZdZwmacA52VZdkgBqf8OH3A1cvIa+n/PLfNrHgRIju5pho/BEmEAkRongMFPHer5LFt+lwZ0BDEW53Lpx5JMweaTUS0y9INHsQ2vtc9M89rkgTY/D0+FfnbGV66cdXvx2/zTf+mxTubidB7PQy2vBKfsR1XPVYXM9F4asd5pMwMc3YdAEKrsQzvvJJGM0ys/WXwoLx8e7SH3yJHyC5ycWABpgJRvslFEyBAejcF4E8TSAkiZlFvI6EPmU8ng73kGK2G8w3qmoGZWAkwEAnmOLKVwzjhR4JTA3kcBI7gKTCXsDlpGvplQkJU/bWNO1cMckph6OJQB//rzqkYbn7S1dcZ36U6ZoTBR0TwmpCRmRJk4qq0ARpMYaOacvGAugAOPY+QiuCbKAdlp+uWwyJp4NOkWTGo6EOXEsHA/VfP7mMv6CTdo14PBiR/DQILCJ6Fhzhd2z2Sj1fnzHMb4fpuzM5aCdpzZvTCYKmm3zmJ7/dHzIEFuYTn+k8/sq/D5lCOckW8m/pnesI/ps+ePIdjfaccynhUUN9SStBHv9DB0MYOwwkDD/GDBrEtfTG1JwntERed0YRGUwJKIMa6f4AOXRoQ4d8wNUILSGyN7oTBDHHJEk8aLbpetyTjuBE+Kk4vMjh5P8C1Kr13w2WQWQAAAAASUVORK5CYII= Finally, JW in an oval is possibly John Wintle ?
I also had found this one on Captain Huck's Booty website.
https://mb.nawcc.org/image/png;base64,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
The serial number on this one is 56289 - so some 1284 before mine. But know way of knowing how many years that equates to. CHB described it as :
Sterling silver open face pin set pocket watch by Dent of London, circa 1875, approx 1 7/8ths inches in diameter. Clean porcelain dial with black Roman numerals minute ring and subsidiary constant seconds register. Sterling silver hinged back and curvette plain polished case bearing English sterling hallmarks for London and the year 1875 sign JW by the casemaker. Pin-set jeweled movement signed by Dent -- watchmaker to the King and shop locations 61 Strand & 4 Royal Exchange London in working condition.
MartyR
Dec 16, 2008
11,072
346
UK
Let's make a start on this one.
A useful Dent date is 1876, which was the year in which they registered the famous triangle trademark in direct response to the number of forgeries circulating.
Next, it is possible to narrow a watch's date by the addresses it shows. Edward Dent moved to 61 Strand in 1843 and the firm continued to operate there until 1920. E Dent & Co occupied 4 Royal Exchange from 1886 to 1921. This particular combination leaves an unusually wide date gap of 1886-1921.
Finally we have movement #57573. You have to be aware, GJP, that dating from serial numbers is notoriously unreliable; firstly only very limited ledger data is available, and secondly the period between making a movement and casing it was variable in those days so dating from hallmarks is not reliable. Mercer's book on Dent suggests that this movement number dates sometime after 1906 and probably before 1920. However, that is a dating from the general run of movement numbers, but is contraindicated in Mercer's by three Badollet movements in the 57xxx range which date to 1861 (from ledger records)!!!
I once owned Dent #59447 whose (original) case dated to 1920 from hallmarks. If that watch was actually made in 1920, then I'd suggest yours was made before World War I in 1914.
Let's move on to the case. It's Sterling silver, the (unseen) hallmark is for London 1910 (for which it must be a lower case serifed "p") and the casemaker is John Woodman of London (registered in 1897). You don't say if the case has the serial number 57573 to prove it is the original case, but assuming it is then I think the date of the watch can reasonably be assumed to be 1910.
Gosh, I bet you thought this was a precise process :excited:
And finally, the "military" bit ...
You're obviously referring to the "WD" mark on the dial. The first thing that is strikes me is that the exact style of the arrow is not quite right. It's slightly fancified, the flanges of the arrow are too tapered and most importantly the painting on the dial was not good quality - it has flaked, and that is definitely not Dent quality. That last fact demonstrates that this is an after-sale addition, and I suggest that it was done by the owner of the watch.
All of that actually supports the watch date of 1910. I would guess that the watch was owned by an army officer (or maybe cadet) who was posted to Europe in 1914 and decided to have this put on his watch to demonstrate its credentials as an "army watch". For an officer in the field a watch was essential equipment, and it wouldn't surprise me if officers had to buy or use their own, and perhaps having the WD logo was a requirement.
Incidentally, Dents in silver cases all seem to have been bought as "working watches" - the large majority of their pocket watches were cased in gold.
I note that you had some problem with posting your photos GJP, but I'd still very much like to see the case markings and the movement. Would you try again please?
Reactions: jplotkin
GJP@4
Oct 2, 2012
20
Marty,
Thank you for your prompt and detailed reply. I always been fascinated by clocks & watches and have acquired a few since I took early retirement in 2011. i'm hoping to try my hand at dismantling & cleaning a timepiece carriage clock over the coming winter. Fortunately there is a local clock shop who have offered to "put me right". Clearly I am no threat !
Re your comments:
Case back has the following (I cannot photograph them but found exact copies on web)
JW in oval.png Leopard head.png Lower case p.png Lion.png it also has 1 0 2 above a G
The dust cover(?) has the same - except no Leopard head. It does have the 1 0 2 over a G
The cover has been inscribed for a presentation in 1951.
MartyR
Dec 16, 2008
11,072
346
UK
I see it has the same WD mark on the movement. I still don't believe that Dent put that there!
I'm still comfortable with my hypothetical explanation of how and why the WD marks were added. In case I wasn't clear before, what you have is a pretty regulation Dent watch, not one that was made specially for the military. It shouldn't really be called a "military watch".
The inscription on the case is obviously a much later addition ... and those tend to devalue the collectibility of the watch. What would be interesting is to try to discover who was the first owner, who (presumably) carried it in the First World War.
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
For what it is worth, the movement (57573) is inscribed "Watchmaker to the King" so it was engraved after Victoria's death in 1901.
Movement nos 57450 & 57451 ("Montres simples") were supplied to J Dent in August 1881. They were hunters.
One or two similar numbers were sold elsewhere implying that 57*** numbers may have been Audemars numbering rather than Dents.
But we have very few of them and coincidence always lurks in these excercises.
To put this in context, as noted in a previous thread, we have around 5500 serial numbers, or very roughly a quarter of the probable Audemars production between 1811 and 1885.
Of these there are about 400 sales to J Dent by name, and (very roughly) 1600 shipments to Audemars London depot, of which it is reasonable to suppose that a high proportion were sold from stock to Dent and to Frodsham, who appear to have been their major UK customers in the late 1870s and 1880s.
Not sure if that is any help here, but someone somewhere might find it useful....................
P
MartyR
Dec 16, 2008
11,072
346
UK
These 57xxx numbers do seem very odd in the Dent numbering range. Note what I said earlier -
Mercer's {lists} three Badollet movements in the 57xxx range which date to 1861 (from ledger records)!!!
so this might suggest that 57xxx numbers were reserved by Dent for external Swiss makers (Badollet and Audemars at least) over a long period of time. Surprisingly, Merecer does not list any Audemars movements as far as I have seen. That is very strange!
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
Well, they weren't about to mark their movements with the original maker's name were they? - and one thing we know for sure is that Mercer and others didn't have access to the Audemars ledgers as they were only found in the last 5 - 6 years.
But the devil makes work for idle hands.......
Serial numbers supplied by Audemars to J Dent:
1 X 1857 1881
6 X 19** 1881
8 X 3*** 1882 – 1884
6 X 4*** 1881
1 X 4573 1887
6 X 93** 1881
5 X 115** 1881
12 X 14*** 1881 – 2
4 X 161** 1882
3 X 169** 1881
7 X 20*** 1881
6 X 21*** 1881 – 2
2 X 22*** 1881 – 2
10 X 23*** 1882
19 X 24*** 1881 – 2
2 X 25*** 1882
32 X 27*** 1882
2 X 299** 1882
1 X 31051 1882
30 X 323** 1881
5 X 338** 1881
1 X 35155 1885
15 X 374** 1882
2 X 38460-1 1881
4 x 39421-4 1882
2 X 447** 1881
7 X 474** 1882
5 X 49*** 1882
19 X 52*** 1883
1 X 53046 1883
2 X 57450 – 1 1881
1 X 77326 1884
3 X 860** 1881
31 X 888** 1881 - 3
2 X 91840 – 1 1881
4 X 95016 – 9 1881
Six digit numbers, resourced by Audemars’ London depot from Calame-Robert or Courvoisier, can’t remember which; I’ll look it up if anyone is interested.
1 X 121951 1883
2 X 24**** 1881 & 2
104 X 25**** 1881 – 2
31 X 26**** 1882 - 3
These are the known sales, not including possible sales from london stock.
Itb should not be assumed that 1881 - 3 were the only years they sold to Dent.
It is just that they are the only years for which we have a record.
P
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
That fifth date down ought to be 1881 not 1887
The six-digit numbers were bought from Calame-Robert.
Personally I think they were shipped directly to Audemars' London depot without going through Le Brassus.
P
MartyR
Dec 16, 2008
11,072
346
UK
It's amazing, that there seems to be no logic in the Audemars numbering system. In 1881 they mad sreial numbers ranging between 1857 and 95016 !!! Could they have actually made so many watches in one year? It also seems they weren't adopting the Dent system (which was already confusing enough!).
Vaudrey Mercer's book has many pages devoted to outside companies manufacturing movements for Dent, and the (Dent) serial numbers for those, and he makes no mention of Louis Audemars. Mercer's lists are for M F Dent for the years 1851 - 1920, and for E Dent & Co from 1842 - 1862.
The E Dent list includes #38461 by Badollet in 1861, and that is one of the Audemars numbers in 1881 so it's clear that Audemars wasn't supplying E Dent or Dent & Co.
Mercer's list for M F Dent starts at #16327 in 1851, and broadly the numbers increase with the years. It seems certain that Dent didn't produce Audemars #1857 in 1881. In fact, Mercer's list starts at #29331 in 1881, and he shows #29901 as a Nicole movement in 1884 whilst Audemars has #29901 as a Dent movement in 1882.
It's all very confusing :???: Are we sure which of the Dent companies Audemars were supplying, Paul? Is there an address? Whatever, my guess is that Audemars were not marking their movements with their own numbers, but were leaving Dent to put Dent numbers on the movements.
It still begs the question of why Dent seem to have no records of Louis Audemars supplying them, or why Mercer seems unaware of this fact.
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
As far as I recall, the books refer only to "J Dent" or occasionally to "Dent of Cockspur" [Street].
To confirm that I would have to go through the lot. I am a retired old fool but I still have to prune the roses this month...................
Because of the contexts in which the numbers occur I am reasonably certain that virtually all the numbers I have are Audemars numbers - they occur alongside similar numbers sold to other people.
Movements might well have been re-engraved by the recipients or, indeed, by Audemars London depot before delivery.
I am reasonably sure that the depot was not just a stock holdingoperation. Like that paris depot they processed stuff as well.
The problem with the London operation was that it was - most of the time - run by a succession of non-family people who - frankly - screwed the swiss factory right royally.
P
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
I think I must backtrack a bit.
Following some e-mail exchanges with interested parties, I have started to do a more detailed analysis of an Audemars Ledger dealing with sales from the London stock between the years 1881 and 1885 ( the year of the bankruptcy).
So far I have done eight pages (out of forty or so, with around 20 serial numbers each).
Every single watch so far (and they are watches not movements) was resourced from factories other than the Audemars operation in Le Brassus - Calame-Robert, Courvoisier, Matthey Doret, Jacot Br********** (illegible) - and I am sure there will be others.
The serial numbers therefore must be the factories' numbers, not Audemars numbers, which accounts for the great variation in them.
By far the most frequently occurring customer is F Dent (not J, sorry, the script is NOT easy to read).
There are also sales to Charles Frodsham and a number of other customers.
I know that Frodsham and I think, from memory, Dent occur in the other ledgers we have - which deal exclusively with Audemars' own products - but I will have to go through all 5500 entries line by line to be sure.
Watch this space.
Paul
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,315
3,003
86
Boston
awco.org
Thank you very much for your fast reply!
But i have to admit, that i am a bit confused about the production dates you suggest.
The London Hallmarks of the case (if i am not completely wrong) are clearly those of 1841/42.
The case features a crown (and it does not seem to be a modification - there is also no winding-square on the barrel visible, which i would expect, if the movement is a later conversion). The case is also very thin and fits the movement perfectly with no obvious signes of modification .
I really have no doubts that it is the original one.
And the winding mechanism looks pretty different to the Nicole patents i have seen - Were there any Nicole crown-winds with the hands key-set from the dial side?...(This one here seems to have some similiarities to the early patent of Th.Prest).
If I read the hallmarks correctly, would it be possible, that a very special case (which also bears the same number than the movement) was made for a movement which is made at least one or two years later?
I add a picture with the hallmarks, the crown and the movement.
Sorry for the quality - it will take some weeks to get better ones (my watchmaker is taking care of the watch in the moment).
Thank you again for your patience,
Harald
I just stumbled across this thread and was struck by the lack of reference to Arnold & Dent. In 1841, the relationship between Dent and Arnold had just been dissolved. The partnership made a significant number of watches with Prest's keyless work, which I believe this watch displays. The change from the bevel gear to the square configuration may have been a means of avoiding the patent and Prest's royalty.
MartyR
Dec 16, 2008
11,072
346
UK
F Dent is Frederick (Rippon) Dent. He was a watchmaker (originally apprenticed to Benjamin Vulliamy) who worked for Edward Dent from about 1830. His name was then Frederick Rippon. He obviously was held in high regard by Dent, because when Dent died in 1853 he left a significant part of his business to Frederick, including the shops and stock of 61 Strand and Royal Exchange. Frederick then changed his name to Frederick Dent, a wise marketing move, and continued to run the business as F Dent successfully until his death in 1860.
Prior to that period, the firm was named as E J Dent, Arnold & Dent and Edward J Dent. After Frederick's death it became Dent & Co and E Dent & Co.
In parallel to this line, when Edward Dent died in 1853 he left the other part of his business to his son Richard, who named the firm Richard Edward Dent. Richard died in 1857 and his widow Marianne took over the business and renamed it M F Dent, which became a highly successful firm in its own right.
So to return to the Audemars watches supplied to F Dent, these must have been supplied in the years 1853 to 1860; and by the way the addresses of that firm were 61 Strand and 34 Royal Exchange, whilst the address of M F Dent was 33/34 Cockspur Street.
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
Sorry Marty,
The book only starts in 1881 and finishes in 1885.
Until recently I had interpreted the initial as a J, but on closer inspection as a result of our recent exchanges, I am pretty certain it is an "F".
I recall some sales to "Dent de Cockspur" in the same book, but I haven't got there yet.
It's all a bit of a mystery, so I am going right through all the books as well as this one, which might take a while. I'll keep you posted.
Best regards
Paul
Dr. Jon
Dec 14, 2001
7,586
2,005
New Hampshire
One thing to look for a possible confusion is E B Dent. I have a nice watch signed by this maker. He was not of the Dent family but I did find an advertisement in a journal when I looked at the Guildhall Library in London. I think he was jsut another Dent rather than a counterfeiter given that he did advertise. Mercer makes no refernce to him so definitely not one of the famous ones.
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
Here are some F. Dent watches I have seen in various publications.
S/N 22665 HM 1855 movement & dial signed F. Dent London ( I have this watch in my collection)
S/N 23609 C1856 only info I have on this watch
S/N 23960 Same as above
S/N 26940 C 1860 F. Dent
S/N 27429 C 1860 F. Dent
S/N 28083 C 1860 F. Dent
S/N 26384 HM 1862-63
Old stock sold by F. Dent Signed E.J. Dent
S/N 24429 24919 26460
The following S/N may have been sold by F.Dent and may contain E J. Dents name on the dial and the movement
S/N 22932 23609 23960 24773 22855
PS This is not an exact science
MartyR
Dec 16, 2008
11,072
346
UK
Frank, it's great to hear from you again :):):)
Sorry Marty,
Paul, the dates I quoted are straight out of Mercer. They must be right. The company F Dent traded as such only from 1853-60 so if you're happy that your records refer to shipments from 1881-5 then either you're missing an "M" or else Louis was confused about the correct company name which must have been M F Dent ... in fact, Dent de Cockspur St :)
If that's so then tracing the Audemars movements will be much more difficult because M F Dent watches seem hardly ever to come to market. I can recollect seeing just one at auction in four years, which I remember well because it was in a pristine original box and sold for a vast sum of money!!!!
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
The last thing I want to do is argue with anyone about stuff where I am a rank amateur.
I attach a page taken at random from around forty, virtually all of which contain references to F Dent & co. If after all it turns out to be a J, then jolly good, but it looks like an F to me.
P
MartyR
Dec 16, 2008
11,072
346
UK
It definitely says "F Dent" Paul. But equally definitely, Frederick was long dead by 1881 and Vaudrey Mercer shows quite clearly that immediately after his death the company name was changed from F Dent to Dent & Co, and remained so named thereafter.
Further, the Audemars serial numbers you listed earlier are huge numbers away from the serial numbers of Dent & Co watches of 1881, and I have located at least two Dent & Co watches with serial numbers matching those on your list which were provably not made by Audemars, and made decades earlier than 1881.
You said a few posts back that Audemars lists "Dent de Cockspur St" as a customer, and that is M F Dent. My lteast suggestion to reconcile the irreconcilable is that Audemars mistook the name of his customer M F Dent and recorded it as F Dent. I will look at Mercer's book again to see what serial numbers he lists for M F Dent, to see if any might match your numbers.
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
Hi Frank, and welcome back.
Marty, As I said in an earlier post, it is becoming increasingly clear to me that few if any of the numbers in that book were made by Audemars.
They all appear - so far - to have been sourced from several other factories (each with their own numbering system), probably directly by the Audemars London Depot.
I am now sure the numbers are the factory numbers, not anything to do with Dent.
This is borne out by the fact that in several runs of continuous numbers watches were sold to several different buyers.
If some of them coincide with classic Dent numbers it is almost certainly, as I said earlier, that bane of all research - coincidence.
It is dificult to reconcile the F Dent as an error when considering the 400 + "Dent" entries in that book, over a period of five years, and the fact that the entries are in several different hands.
I am not arguing or trying to prove anyone right or wrong.
But the book - to me - at least is clear and I don't think they were making mistakes.
They coped with many more difficult names than that in their Russian, Eastern Europe and German markets and had done for over 60 years.
Is there a possibility there was another Dent handling down-market stuff and calling himself F Dent?
I think I'm going to shut up about this until I have completed the re-analysis of this and the other books.
P
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
Here are some watches MF Dent thart I have recorded over the years
S/N 10035 33/34 Cockspur Street
13049 "
23789 HM 1861 (Nicole)
23023 1862 (Noyer) 33 Cockspurn St.
24682 1864 "
24821 1865 (Gartner) "
25233 1867 (Gartner) "
25149 "
26374 1870 (Phillips) "
26583 1872 (Nicole) "
27798 1875 (Bryer) "
28265 1876 (Nicole) "
28296 1876 (Phillips "
29224 1880 (Phillips) "
30786 1891 (Nicole) "
32382 1902 (Nicole) "
32384 1902 (Nicole) 34 Cockspur
33757 1917 (North & Sons)
33846 1919 (Rotherham) "
29650 1882 (Hammersley)
21272 & 21259 Charing Cross London
27533 1875
Some of these watches were found in Mercers book and others in various
publications. I do not know how accurate this info is.
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
Edward John Dent and his Successors by Vaudrey Mercer Page 588
Some Other Dents John Dent 1883
John Bryant Dent & Co. 1887
John Bernard Dent 1888
John Dent & cO 1890
This John Dent is not related to any of the E.J. Dent clan as far as I can see.
What looks like an F may be a J
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
Tried that Frank,
- gone almost right through the book comparing that initial - in several different hands - with the Js of June & July.
They don't match.
Originally I thought it was a J myself.
That is one of the reasons I am going through it again with a fine tooth comb.
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
I see on the Ledger that the name is Dent & Co. As far as I know F.Dent did not use & Co.
His businness premises is listed as Frederick Dent 61 Strand & 34 & 35 Royal Exchange
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
Another look at the ledger shows what appears to be J. Dent & cie (son or sons) :???:??
In Merceras book page 588 there is listed as a watchmakers John Bryant Dent & Son & John Bernard Dent & Sons
Audemars
Aug 6, 2010
1,143
227
Somerset, UK
www.audemars.co.uk
I assume they were also writing invoices to their customers, so they would have to be addressing them to the correct title or the client would have corrected them, just as they would today.
I don't pretend to understand any of this and as I said before I am not here to argue with anyone.
All I have is what the book says.
How reliable is Mercer?
P
MartyR
Dec 16, 2008
11,072
346
UK
Good question :) And one that I suspect no-one has ever asked because Mercer is the only game in town!
To answer the question as best I can, I have to explain that Mercer is largely a ramble through a large amount of widely disparate data. It is a largely unorganised book which is very difficult to read, and even more difficult to reference.
However there are some small parts of the book which are a clear attempt by Mercer to provide quick reference, and one of these is Appendix VII called Business Premises and Titles. It can be reasonably assumed that the data in this Appendix has been gleaned from a number of reasonably reliable sources such as street directories, registers at Companies House, published advertisements, engraving on watches and clocks, and internal company documents although a degree of cross-matching and interpretation might be required. That data would be further supported by unequivocal data from Registers of Death and Companies House. Overall I would expect the data in this Appendix to be entirely accurate given that Mercer, whilst not a very good writer, shows evidence of being an excellent researcher who can be relied upon not to publish something as fact which he did not have good reason to believe was fact. The book regularly as necessary uses phrases like "it may have been that" and "it is thought that" and even "although there is no evidence that".
So I am 100% confident in the simple data laid out in this Appendix, which shows all the precise business names used by the Dent companies, the years for which they were used, and the exact addresses with which those companies were associated. To give an idea of scale, there are 27 different entries in the list. Each entry also describes the additional engraving on movements such as "Maker to the Queen" found on watches at each address, and also lists the types of watches that Mercer actually saw with that name/address combination.
The Appendix, which runs continuously from 1826 to 1977, quite clearly shows the company name Frederick Dent, and the usages on watches Fredk Dent, F Dent and Dent, in use from1853 to 1860.The corresponding addresses are 61 Strand and 34 & 35 Cockspur Street.
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
Marty is correct, Mercers book is very unorganized, however much of the data is
accurate. Going back to the Ledger it is quite clear that the entries were made
in the 1880s. F. Dent died in 1860 and it is unlikely that those entries in the Ledger
are refering to his firm. Perhaps you can make an inquiry to E Dent & Co. who are
still in business.
Ken TM
New User
May 19, 2013
London, UK
E. J. Dent, Watchmaker to the Queen
54 Royal Exchange
London
25008
The watch belonged to my great- or great-great grandfather, my mother isn't certain. It's impeccable, still runs beautifully.
gmorse
14,836
3,934
Hi Ken, and welcome to the Forum,
Some pictures of your watch would be appreciated I'm sure, especially clear close ups of the inside of the case for hallmarks, and the movement.
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
The Dent Family watchmakers were never located at 54 Royal Exchange. One of their locations was 34 Royal Exchange. S/Ns 25002 thru 25009 these movements were made for MF Dent by Charles Gartner 13 Lower Ashby Street East Central London in 1866.
Ken TM
New User
May 19, 2013
London, UK
You're quite right, it does say 34. I misread it. Herewith a few photos, although after shining a bright light on it I think I have spotted a couple of smudges and a small scratch on the crystal. I'm very new to all this; when I said "impeccable", that was to my novice eye, so please be gentle with me!
Apologies for the lack of photographs of hallmarks - my rubbish mobile phone camera wasn't even close. There's one dead centre of the inside of the front piece which is "G&J" in an oval, then there are two towards the hinge, one of which I can't well make out, the other of which is an "18" in a rounded oblong.
***EDIT*** - There is another hallmark I forgot to mention which you can see in the first photo, on the front of the crown, which is of a crown. Rather unimaginative bit of labelling, or more likely, I'm missing something.
Frank Menez
Jul 11, 2003
1,302
7
90
Somersworth NH
It appears that the case maker GJ was George Jenkins 22 Rahere Street Goswell Road Clerkenwell London He is recorded as making cases in 1857 with his initials in an oval. E.J. Dent died in 1853 and his step son Frederick Dent continued the business using E.J. Dents name on movements until he eventually used his own Name F. Dent . Frederick died in 1860. Even though the watch is signed E.J. Dent it was probably sold by M.F. Dent (Marianna Frederica Dent successor to E.J. Dent.) As I said before S/N 25008 was made by Charles Gartner for M.F. Dent. See E.J. Dent and his Successors by Vaudrey Mercer.
PS Marty R what are your thoughts on tbis watch:???:
gmorse
14,836
3,934
Hi Ken,
Since the pendant was made separately, often by a different maker from the case, it was hallmarked separately as well, according to the regulations.
Ken TM
New User
May 19, 2013
London, UK
Thank you! It's wonderful to receive such a wealth of information from someone knowledgeable, about something has been in my family for such a long time.
I look forward to reading the thoughts of Marty R - if there's any other details about the watch which might help, please let me know.
Now I just need to figure out which of my ancestors the initials on the front relate to!
179,002
1,570,115
54,045
QMAC
909
3,088
Swiss Fake by Kent
