DENT# 2387 was on uSS Juniata
Discussion in 'Chronometers' started by Pitmom, Jul 21, 2018.
  1. Pitmom
    Pitmom Registered User
    Jul 21, 2018
    Female
    Just acquired a Dent #2387- it was on the USS Juniata 1869... I have all the papers/logs that were with it.... What is it worth? Excellent Condition looks-wise has been preserved very well, but Not sure if it actually works Absolutely gorgeous.
  2. novicetimekeeper
    Jul 26, 2015
    9,693
    581
    Dorset
    pictures, always pictures
    Jessica Clements likes this.
  3. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,516
    1,565
    176
    retired SW dev
    Boston
    Pictures of the inside as well as the outside. Scans of a sample of the documents will get you an idea of its importance.
    If you want to ask about the value, you need to go to your user profile and check the discuss values checkbox and ask you question in the What is this clock worth or what is this watch worth forum near the bottom of the screen. Members will share their opinions on its market value but those are just opinions. It would need to be examined to get a real appraisal.
  4. Pitmom
    Jul 21, 2018
    Female
    I just added like50 pics of it I think - go to my profile and look at the album I took pics of every angle...... if there are duplicates, Im sorry... just learning. Thank you!
  5. Pitmom
    Jul 21, 2018
    Female
    I just added a .ton. the album is in my profile. Sorry I didnt know you weren't Supposed +o ask value... Still learning... I just wanna know LOL
  6. Tom McIntyre
    Aug 24, 2000
    82,516
    1,565
    176
    retired SW dev
    Boston
    I will try putting them here where folks with no training can find them. :)
  7. gmorse
    gmorse Registered User
    11,084
    1,486
    Retired from Xerox
    Hi Jessica, and a belated welcome to the forum,
    I think you should understand what it is you've bought; it might look like a small clock or a very large watch, but it's neither, it's a navigation instrument, just as a compass or a sextant is, and as such, it doesn't live in the same space as domestic clocks. Yes, it shows the time when it's running, but in order to do its very specialised job it's been designed to work in a particular way; for instance it's intended to run continuously and if stopped and started at random it can be seriously damaged. Marine chronometers have been compared to puppies, they need lots of care and special treatment and if neglected they quickly sicken and can die . . .
    I'm afraid I can't agree with you about its condition, because even from the external views you've posted it's apparent that there's some corrosion on the hands, the silvering on the dial is completely gone, the up-down hand is missing, and the bowl, gimbals and case are pretty scruffy, which doesn't encourage much optimism for the real state of the movement. To show the movement you'll need to unscrew the front bezel which holds the glass before you can lift the movement out of the bowl, but if you're unsure about this, please come back and ask, there's a lot of expertise with these special instruments here. Nobody can begin to hazard a guess at possible value without seeing the movement in some detail.
    Sorry to be somewhat gloomy, but on the plus side you have an instrument from a fine maker with lots of documentation on its history, and the wooden case appears to be all there. A quick Google of images of marine chronometers will show what these things should look like. If you just like it for its looks as an object, that's fine, but if you decide to have it restored to working condition you should be prepared to spend some serious money.
  8. tick talk
    tick talk Registered User
    Sep 16, 2008
    584
    91
    Whatever happened to the pictures?
  9. Tom McIntyre
    Aug 24, 2000
    82,516
    1,565
    176
    retired SW dev
    Boston
    The Media tab at the top of the screen opens the multimedia facility. You can search there by several means and their are facilities for uploading pictures and other media.
    If you click on the image above it will open the album with the pictures (in the image gallery) and show you its cover image. If you double click on that you can see all the pictures in a lightbox.
    The advantage of the media area is that you can comment on individual images and talk about the group of images. It is a bit more difficult to do that when the images are direct attachments.
    We have also increased the number of images that may be attached to a post from 10 to 20 to make the attachment usage a bit easier.
  10. Pitmom
    Jul 21, 2018
    Female
    There are pics.. they are somewhere in here ...somewhere in my profile? Alot of them
  11. gmorse
    11,084
    1,486
    Retired from Xerox
    Hi Jessica,
    They're in the Media library, here.
  12. Pitmom
    Jul 21, 2018
    Female
  13. gmorse
    11,084
    1,486
    Retired from Xerox
    Hi Jessica,
    Because you've limited who can view your full profile, your Media can't be viewed from the profile that everyone can see, but the pictures can be found by searching as Tom explained.
  14. Pitmom
    Jul 21, 2018
    Female
    Oh, well I need to fix that I guess lol.. this website confuses me a little haha sorry
  15. River rat
    River rat Registered User
    Apr 4, 2009
    564
    108
    I would like to see a photo of the movement to see what condition it is in.
  16. gmorse
    11,084
    1,486
    Retired from Xerox
    Hi River rat,
    We all would, although I fear that what we see may not be very encouraging!
  17. Tom McIntyre
    Aug 24, 2000
    82,516
    1,565
    176
    retired SW dev
    Boston
    I will post the pictures of my Dent that has been restored as a comparison. Mine has the outer box replaced by a newly made box and it is not nearly as old as yours, but it does show the appearance of one in good condition.
    box.jpg boxopen.jpg boxside.jpg boxtop.jpg dial.jpg dial1.jpg dial2.jpg face.jpg movement.jpg sideview.jpg staplebal.jpg staplebal2.jpg topopen.jpg tubbottom.jpg tubinside.jpg tubnumber.jpg
    River rat likes this.
  18. Tom McIntyre
    Aug 24, 2000
    82,516
    1,565
    176
    retired SW dev
    Boston
  19. River rat
    Apr 4, 2009
    564
    108
    Best way for photo's is the FROM PC the button next to the POST REPLY button it takes you to your computer photo's and you click the photo you want to post and done. I use a out side hosting site on most forums but it's hit and miss here if it works but the FROM PC has never failed.
  20. Tom McIntyre
    Aug 24, 2000
    82,516
    1,565
    176
    retired SW dev
    Boston
    The photo hosting sites have a recent history of changing their rules about displaying images on other sites. Because we lost many images to those policy changes, we now harvest all external images and save them on our servers.
    Quite often, you can just copy and paste an image from another site, but that should only be done with permission. I sometimes use the screen capture facility (PrtScr) from my own sites and just paste the screen capture here. That seems to work pretty reliably.
    I used PrtScr to capture an image of the image handler tool (the landscape picture in the tool bar). It also allows you to select attachments you have uploaded previously and insert them in the current post you are editing.
  21. Dr. Jon
    Dr. Jon Moderator
    Dec 14, 2001
    5,648
    419
    Aerospace Engineer
    New Hampshire
    Opening the can is a bit tricky but there is good chance the works may be in good shape. These cans are usually fairly well sealed. A lot depends on how the last person who used it left it. It it was properly stopped and the balance corked the internals are fairly safe from damage.
    There are many ways to damage the movement by not handling it correctly.
    The British Navy rules stated that the penalty for opening one of these cans at sea, when in use for navigation, was to be flogged to death.
    It is probably worth getting it restored. These were serviced regularly when in use and the people who did the work often left inscribed notes inside, where they were, and when the did the work.
