Dating Kieninger & Obergfell Standard 70mm x 92mm, eccentric nut adjuster Anniversary Clock Movement
JTTrey3
May 20, 2017
52
I am in the process of restoring this 400 day clock (See attached pics). I am trying to determine the approximate manufacture date.
Can anyone help me determine approximately when this was made? Serial # 41799 20170715_122155.jpg 20170715_122201.jpg 20170715_123035.jpg 20170715_222926.jpg 20170715_223103.jpg
The base is a disaster, and I have turned a new walnut base for it. I will post photos when it is finished.
MartinM
Jun 24, 2011
3,091
El Dorado, CA
Early June, 1931. (Provided I'm reading the SN correctly (41799).
John Hubby may amend that, based on better information.
tracerjack
Jun 6, 2016
1,782
276
Lodi, CA
You say the base is a disaster, but I can't see any cracks in the photos. If there are cracks, then yes, a disaster. If it is just tarnished, it will restore beautifully with polishing and be original to the clock.
JTTrey3
May 20, 2017
52
The base is cracked and separating. Since I was focused on identifying the mechanism, I did not post this pic, but you can see some of the damage here 20170715_123104.jpg
bangster
19,988
513
I think this thread should be in the Torsion Clocks forum, but I'll leave it here.
I wonder if that base is repairable?
JTTrey3
May 20, 2017
52
That is a good question. It seems thin, but it might be possible to braze the brass. Such a repair is far beyond my skills. Since this will be a gift, I have chosen to turn a new base out of walnut. It isn't original, but it looks nice on it.
MartinM
Jun 24, 2011
3,091
El Dorado, CA
Much too thin to braze and just applying the heat would likely make it come apart even more
Not to mention the wooden disc on the inside not being able to survive.
Burkhard Rasch
Jun 1, 2007
4,961
222
65
Twistringen
I think that is the problem of the base : someone applied water or another liquid to the base resp "soaked" it in a cleaner of some kind and the wood inside the base expanded and caused the cracs.This is a quiet early KundO retaining its original pendulum.Not disregarding a nice selfmade wooden base :if it were mine I´d look for a donor clock and get the original base for it in course of the restauration.
Just a thought,though...
Burkhard
KurtinSA
Nov 24, 2014
4,531
294
San Antonio, TX
What about using some kind of glue to hold the base pieces together? If the cracks can be closed up somewhat with some judicious pressure, then applying a layer of cement on the inside of the base shell might be enough to keep it together and certainly keep it from getting worse.
Kurt
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,294
241
The Woodlands, TX
JTTrey, thanks for posting your Kundo photos here and your inquiry. Martin's date is spot on based on the serial number you provided and can be seen on the clock back plate. In lieu of a replacement base, your making a turned walnut base to the same profile is a good solution. The correct base can be found if you wish to return the clock to original condition, to my knowledge Kundo didn't make any turned wood bases even though other makers did do so.
With regard to the existing base, could you post a photo of the underside so we can see the actual construction? At the time your clock was made Kundo were introducing a formed steel under-support that has the wood disc sandwiched between the support and the brass cover; if it is one of those a repair is virtually impossible. If it just has the wood disc support there are some ways to close the cracks, although yours has rather severe horizontal cracking as well s the radial crack.
Fitzclan
Jul 20, 2014
700
33
Long Island, New York
Doesn’t seem like you have anything to lose by attempting a repair. I would go with Kurt’s suggestion. I personally think it would look better even if it doesn’t come out perfect.
If the repair is unsatisfactory, you have only lost your time. Certainly worth a try.
JTTrey3
May 20, 2017
52
Attached are better photos of the base. It does look like there is wood inside.
20180719_221211.jpg 20180719_221217.jpg 20180719_221211.jpg 20180719_221217.jpg 20180719_221233.jpg 20180719_221237.jpg
167,209
1,457,103
87,372
Pamula
