cylinder watch running fast
Discussion in 'Watch Repair' started by glassblower, Jan 7, 2013.
  1. glassblower
    glassblower Registered User
    Sep 7, 2008
    19
    Hi! I have a 1907 pin set cylinder watch that is running fast. I have replaced one of the jewels as it was not running before but it gains an hour in 24 hours. Any help? I have done the adjustment for time but it only slows it down a bit.
    Thanks.
    Lou
  2. richiec
    richiec Registered User
    Feb 24, 2007
    6,731
    549
    automotive warranty inspector
    Brick, Ocean, NJ
    Take a close look at the hairspring first for touching coils, improperly adjusted regulator banking pins. those are the most obvious reasons for a really fast watch beside dirt. Was it demagnetized as well?
  3. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,568
    126
    Gothenburg
    Also check that the hairspring jumps between the adjustment pins.
    I can not make out from your picture how the hairspring is attached but it is very common in cylinder movements that the hairspring is pinned in place and the stud is not removed from the balance cock. Another common thing is that the hairspring extends a few cm through the collet. This makes it difficult to tell exactly where the hairpin was mounted and any error here will give you a movement out of beat and timing issues.
  4. gmorse
    gmorse Registered User
    11,362
    1,637
    Retired from Xerox
    Hi glassblower,
    Was the watch fully cleaned when the jewel was replaced? Dirty watches do usually run fast.
  5. rrwatch
    rrwatch Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Member
    Sep 4, 2000
    1,428
    269
    Watchmaker
    Pooler, GA USA
    This may seem obvious, but if one of the escape wheel teeth is broken off, it will make the movement (whether lever or cylinder) run fast.
