Cutting case back/bezel threads
Discussion in 'Watch Repair' started by NewBernWatchmaker, Oct 28, 2019.
  1. NewBernWatchmaker
    NewBernWatchmaker Registered User
    Jun 1, 2018
    26
    New Bern, NC
    Could someone explain the method for cutting these very fine threads on large diameter pieces?
  2. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    2,519
    94
    Doctor
    Linköping, Sweden
    Single Point threading. You need a thread cutting lathe with the ability to cut fine pitch threads.
  3. NewBernWatchmaker
    Jun 1, 2018
    26
    New Bern, NC
  4. Jerry Kieffer
    Jerry Kieffer Registered User
    May 31, 2005
    2,471
    256
    wisconsin
    An interesting topic that is occasionally required, but seldom if ever addressed in Horological repair. (At least that I have seen)
    However, you have not clarified if for wrist or pocket watches and if for new construction or cleanup/ restoration of existing threads. As such, I will touch on all.
    As others have mentioned, you will need a lathe capable of single point cutting the thread size required. With this capability, you can either machine Taps and Dies or single point thread the work piece directly. With new construction, you can start with the work piece in a shape easily mounted in a Lathe chuck for single point threading. While most existing wrist case backs can also be held this way, existing pocket watch bezels and lids are often another story. In this case, the cases were/are shaped with the lids and bezels screwed in place.
    Again as such, the sharp edged examples are seldom perfectly round nor is the thread perfectly centered to the OD. For this issue, I have installed four aluminum posts in machinable jaws with a ID "V" machined to hold the sharp edge without damage per attached photo. In addition, I can rotate the bezel or lid until I find a spot where the ID thread runs true.
    Considering the short thread requiring that the thread terminate in an exact spot for clearance, I would suggest a hand cranked spindle utilizing a lead screw carriage. In addition, the carriage hand wheel should contain clear and precise calibration markings that can be utilized like a micrometer for depth control. In this case, when setting the threading tool for both new and existing threads, the tool tip is positioned at the desired depth. The hand wheel is then zeroed and threading stops each time the carriage hand wheel registers zero and the tool is retracted.
    When setting up a Lathe for small threads, a slight amount of backlash is required in both gear train and lead screw to permit free operation of the system. Cleaning or restoring an existing damaged thread of this size requires exact positioning of the cutting to tip that is a moving target when backlash exists. To eliminate backlash, I spring load the carriage per the second attached photo. This also gives a more accurate thread on small new cut threads. On existing threads, the threading tool tip is set in an existing thread from the rear of the lathe looking down under optics. To assist precise positioning, a fine threaded setscrew was added behind the threading tool that can be seen in both photo`s
    Jerry Kieffer
  5. NewBernWatchmaker
    Jun 1, 2018
    26
    New Bern, NC
    What a great response, thanks! I should have said for original construction of pocket watch sized diameters. How did I never think to machine the bezel after it was threaded! Trying to get some idea of the threads I was looking at on old 18s case and it appears to be maybe 60tpi, more than 40 at least. Are most original cases UTS threads?
  6. Jerry Kieffer
    May 31, 2005
    2,471
    256
    wisconsin
    Actually most 18s threads I have chased have been around 40TPI give or take a little. They can be sized in most cases with a thread gage applied to the male thread of the case for easier observation.
    Jerry Kieffer
  7. praezis
    praezis Registered User
    Feb 11, 2008
    414
    15
    Germany
    My Lorch lathes that I use for threading:
    Most time I use the green one, mainly for repairing damaged threads on cases or casebacks. It has the 0.5 mm cartridge permanently attached. Nearly all (at least European) case threads are 0.5 mm pitch.
    Another method that I tried for repairing a damaged piece of thread: A hardened bolt with M3 thread I ground down to half diameter to get a cutting tool. Turning the spindle by hand and using the tool like a graver, I follow the thread. The good parts will lead the tool while the damaged part is cut.
    Frank
  8. topspy
    topspy Registered User
    Nov 17, 2013
    601
    21
    Video engineer
    Oregon
    This subject is of great interest to me. Could you elaborate? With gold-filled cases how would you shape the case AFTER threading? Iʻve also always wondered how the edges, threads, etc on gold-filled cases didnʻt expose the copper core.
  9. Jerry Kieffer
    May 31, 2005
    2,471
    256
    wisconsin
    #9 Jerry Kieffer, Nov 10, 2019
    There has been a wide variation in case construction techniques over the years and to large to cover in detail here. However, in short, threaded bezel assemblies are manufactured to a close fit where they are either hand polished or machine polished to a final fit. At that point they are gold filled or plated. If you ever get to the NAWCC museum, there is a section that covers case making and should answer all of your questions.
    Jerry Kieffer
