Cutter numbering systems
Discussion in 'Horological Tools' started by DeweyC, Dec 30, 2012.
  1. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    577
    Watchmaker
    Baltimore
    I have a number of "Carpano Type" wheel cutters; the solid circular ones with the cutting edges cut radially. There are several systems; one is Carpano System starting at 00 and going up from there; it is a progressive system (profile gets larger). Then I have Carpano cutters with a number followed by an "M" or "C". There is also a Swiss system that is whole numbers; another set of cutters is marked in decimals (I suspect these are marked in module system) and finally I have a couple where the width of the tooth is used marked on the cutter.
    Does anyone have a definitive answer for how these numbering systems relate to anything. I thought I had a copy of a table that correlated the Carpano numbers to module; but I have not put my hands on it.
    Thanks!
  2. Todd W
    Todd W Registered User
    Mar 6, 2004
    171
    If you have a copy of J Malcolm Wilds book Wheel And Pinion Cutting in Horology in appendix IV there is the table to go from Carpano numbers to module. If you don't have the book email me twdiesael@aol.com and I will send you a photo of that page.
    Todd
  3. DeweyC
    Feb 5, 2007
    577
    Watchmaker
    Baltimore
    Thanks Todd. I do have that book and I found the table. Now I have to figure out what the other systems mean.
  4. sharukh
    sharukh Registered User
    Oct 10, 2011
    227
    Doctor
    Mumbai, India
    I know this is an old thread but have you progressed any further in figuring out the cutter numbering system ? I just picked up some cutters and I can't figure out what the markings mean.
    Also, by "Carpano type" do you mean the cutters without gaps between the teeth ? As opposed to the modern ones from Thornton ?
    And, yes, I did look at the charts in the J Malcolm Wild book.
    Sharukh
Similar Threads - Cutter numbering systems Forum Date
Crystal cutter? How do I use it? Horological Tools Dec 11, 2016
Staking Tool numbering system on the punches? Horological Tools Aug 11, 2015
Waltham original gear cutter, thread cutter, lathe... Horological Tools Jul 11, 2015
Sherline wheel cutter?? Horological Tools Feb 15, 2015
Bergeon-Tecnoli wheel/pinion cutter identification Horological Tools Oct 31, 2013
