Curious Riley Whiting Label
George Nelson
Oct 5, 2007
931
12
Tennessee
Hi, Everyone!
One of the clocks in my collection is this Riley Whiting column and splat (lower tablet is replacement). It has a curious label, one which I have never seen before. While most of the Whiting labels have his name and the wording in large, bold print, this example is quite different. The printing is small, and the label had been altered before its application to the clock backboard. There are two cutouts on the label, both of which are notated in the photo. (On most browsers, after clicking on picture to enlarge, you can click one more time to enlarge to maximum.) The Whiting name is off-center due to one of the cutouts, while the other area is below his name. The label was printed by P. Canfield Printers, Hartford, so the clock dates to the mid-to-late 1830's. Has anyone seen this label before? Any guesses as to what wording has been removed? Thanks to all for any help with this!
Kind regards,
George Nelson
Jerome collector
Sep 4, 2005
857
82
Omaha, NE
National Awards from NAWCC
NAWCC Fellow Award
George,
That is definitely a curious label. Although I don't really offer this as a likely possibility, the only thing I can think of that would fit is "MOVEMENT MADE BY RILEY WHITING." Can't say I've ever seen that, though. Following on that theme, the other missing part could be "CASED BY..." OR "SOLD BY..." I hope someone else has actually seen an unaltered version, because I'm intrigued. Can you post an image of the movement? Is it, in fact, a Whiting?
Mike
George Nelson
Oct 5, 2007
931
12
Tennessee
Hi, Mike and Everyone!
Mike, thanks for your thoughts.
I haven't known what to make of this clock since I bought it 30 years ago. The label, size wise at least, seems to me that it would be more at home in a pillar and scroll or other short drop case, as all of the printing is down towards the bottom. The overall label size is much smaller than those in my other Column & Splat wood works clocks.
I'm embarrassed to say that I never researched the movement, as I assumed it to be original. I made this assumption due to the facts that there are no extra mounting holes, it is a perfect fit, and that the back of the dial exhibits a strong "shadow" or darkened area(s) corresponding to the installed movement. The shadow of the countwheel and the wooden bridge for the escape wheel are clearly visible, along with the outline of the edges of the movement plate. (I tried to photograph the shadows to no avail. Haunted, perhaps? :eek:)
I've included a picture of the movement, and hopefully better close-ups of the two cutout areas on the label. The cutouts seem to be hastily done, and I believe that the entire label has been glued over either another label or a blank sheet (more likely, I believe) as you can clearly see the other paper through the cutouts. I examined them with a jeweler's loupe, and the label was definitely cut before application to the clock, as there are no corresponding cuts to the liner.
Mike and everyone, I appreciate your interest in my questions and look forward to everyone's thoughts!
Peace to all,
George
Jerome collector
Sep 4, 2005
857
82
Omaha, NE
NAWCC Fellow Award
George,
Now we're getting somewhere. The movement is a type 1.72 by Riley Whiting. What's exciting, though, is that the book, Good for a Time, by Chris Brown (edited by Russ Oechsle), has a Riley Whiting clock with a label showing the same cut-out features as yours. The clock itself is full-size (like yours) and has carved half-columns and a mushroom splat. There are a number of other Riley Whiting clocks in the book but none with the same label layout. So, still no clues to the missing parts of the label. But at least you have company.
Mike
George Nelson
Oct 5, 2007
931
12
Tennessee
Hi, Mike abd Everyone
Wow-thanks so much for the additional information. It is good to know that there is at least one other clock with a similar label out there. Mike, I do appreciate the time you have spent on my behalf-I'll have to get a copy of the book! Am I correct in assuming at this point that the clock would be a early production using up label stock intended for other style clocks that had lost favor with the buying public?
Thanks so much again,
George Nelson
albresee
Nov 21, 2009
26
Binghamton, NY
I have a R. Whiting clock of medium size pillar and splat with carved eagle splat, carved half columns ,and paw feet. It has the same label with the same cut-outs.
George Nelson
Oct 5, 2007
931
12
Tennessee
Interesting, Albresee! It seems that there were at least several
Whiting clocks with this most curious label. Over the years since my first posting,
I've come across at least two other examples. Still no clue as to what
the missing wording was/is. Perhaps in time someone will offer an un-altered
example of the label. The search continues! Thanks for letting us know about
your Whiting clock to add to the "collection". Can you post us a picture or two?
Thanks,
George Nelson
Jim DuBois
Gibbs Literary Award
Jun 14, 2008
3,079
709
Magnolia, TX
James W. Gibbs Literary Award
here is the thought to be subsequent label to the one George pictures......I have not found any labels with the missing information as we see in some of the other clocks...
Dick C
Oct 14, 2009
1,741
82
Here is one that I found .....Perhaps someone can piece the missing pieces together.
I also have one; however, have to dig it out to take photos.
Jim DuBois
Jun 14, 2008
3,079
709
Magnolia, TX
Dick C. so it looks like the first removed word is "movement" (by Riley Whiting) and the other removed lines start with "sold by" So now it looks like we need to figure out the sold by name....progress! Thanks!
rmarkowitz1_cee4a1
Nov 26, 2009
5,437
990
View attachment 359543 View attachment 359544
Having that rubber band right in the middle of the areas of interest on the label is, well, not entirely helpful.
See Oechsle and Boyce, "An Empire in Time: Clocks and Clock Makers of Upstate NY". An essential part of any horological or antiques reference library, IMCO. See pages 146-147.
William A Whiting acted as an agent for Riley Whiting. He worked from a village in Upstate NY called Black Rock which would later be incorporated into the city of Buffalo, NY. His father was the 1st cousin of Riley.
A number of labels were apparently used by WAW. The reported wording of one those labels is probably similar to the one you show indicating "movements made by Riley Whiting" and claiming that they were cased and sold by William A. So, the label of your clock is similar to at least 1 example of WAW's label that I can find, though NOT identical.
Now see Brown and Oechsle, "Good for a Time" (ditto the comments about the above book), page 47. Pictured and described there is another WAW & Co. clock. Note the label there.
Despite the claims made, it is believed that Riley made and shipped the whole clock.
So, I suspect that the clock you posted was one of the clocks from Black Rock (Buffalo) NY with a Riley Whiting movement which William A. Whiting claims to have cased and wording to that effect??
A better look at the wording of the label in your clock would confirm this.
For completeness sake, I would mention that Nettleton, Heath & Co of Scottsville, NY also had labels stating that they cased Riley Whiting clocks when, contrary to the claims on their labels, they were actually selling the whole kit and caboodle. The example of their labels I can find are actually rather different from the one in the clock which you posted.
RM
rmarkowitz1_cee4a1
Nov 26, 2009
5,437
990
Sorry, not a current photo of mine....it is out of the past...
Guess I should have gone back to the 1st post of George's clock's label for a full view!
I hadn't really paid attention to that label until you posted yours.
I believe my hypothesis is correct. It was a label intended for a William A. Riley Black Rock/Buffalo NY clock. Claims on his labels to the contrary, the clocks were probably shipped complete from CT and NOT cased in NYS. I further hypothesize that Riley needed some labelled cases and ones with those labels were what was on hand so they just cut out or overpasted (?) the other parts?
RM
Reactions: Raymond Rice
Dick C
Oct 14, 2009
1,741
82
Here is the clock and the label that I currently have.....about to go out the door I think so I captured the label.
The white band on the top is not cut so I expect that there was a piece of tape or something else covering the whiter portion of the label.
IMG_0486.JPG Riley Whiting Label 2.JPG Riley Whiting Label 3.JPG Riley Whiting Label 4.JPG
David 62
Nov 28, 2004
391
The tablet looks old and is done in the proper style,although Whiting often used exceptional tablets in his clocks.
Staff online
161,026
1,397,057
82,989
Christopher Baum
1,099
2,788
