Curator Slate Blacking
Discussion in 'Clock Case Restoration and Repair' started by TJ Cornish, Aug 5, 2017.
  1. TJ Cornish
    TJ Cornish Registered User
    Sep 12, 2013
    134
    St. Paul, MN
    I finally remembered to order some Curator Slate Blacking with my most recent Timesavers order, and have resumed work on the clock in my avatar which had a couple etches in the marble. I sorted those out with marble etch remover, but that left the marble gray, hence the Slate Blacking.
    This is my first use of the stuff. The directions say to apply a coat without rubbing. I'm struggling to get the hang of this - a coat that seems to flow enough to have good coverage is fairly thick, almost paint-like. I was assuming it would be thinner and something that would soak in more. Am I doing something wrong?
    Thanks!
  2. gleber
    gleber Registered User
    Jun 15, 2015
    774
    Downingtown, Pennsylvania USA
    I used a micro fiber cloth that was dampened with water then covered the bottle opening with it, tipped the bottle over to get some on the cloth, then applied is smooth strokes. Being thinned, it dried fast and I applied 20 - 30 coats. It took about 5 coats to start to look even.
    You can see more discussion and the results in this post. https://mb.nawcc.org/showthread.php?127544-Bailey-and-Company-Clock-Finish-Help-Request
    Good luck
    Tom
  3. 0132joshua
    0132joshua Registered User
    Dec 24, 2015
    55
    hi, try this, aquire a scrap clock case first to test, worked for me, lightley go over the case with damp, not soaked, wet or dry 1500 grade paper, clean case with meths or spirit, get some good quality instant black shoe shine, with the foam applicator, give a even coverage, let dry, must be dry, then ,very very lightly, buff with finest of wire wool, dont rub, just buff, repeat many many times, this is a slow proccess, the results are, for my clock, a nice subduded shine, with virtully no white haze showing, great improvement, not to shiney, looks original, please test first on a scrap case.
  4. Chris
    Chris Registered User
    Nov 4, 2001
    2,445
    36
    Clock and phonograph repair
    South Easton, MA
    Personally, I hate that slate blacking stuff. I never liked the look of it and gave up on it. My method will be 100% controversial and some will crucify me for it. I clean the black marble case with acetone and paper towels. Before the acetone evaporates, it tells me what my end result will be. If the case is a nice even black, I clear coat the entire case with clear acrylic enamel from a spray can. It darkens the black marble and puts a permanent shine on it. Some might find it too glossy, so you can use a satin clear, too. Sealed with the clear coat, maintenance is minimal (light wipe with a damp rag to get the dust and not need to ever wax or worry about streaking the slate blacking with a reactive cleaner). It's reversible, too. Just wipe the clear coat off with acetone and it's raw marble again.
Similar Threads - Curator Slate Blacking Forum Date
French Slate Clock woe's Clock Case Restoration and Repair Apr 14, 2016
Slate And Marble Case Clock Case Restoration and Repair Jan 11, 2016
Advice on cleaning a real marble case...not black slate/marble, not onyx. Clock Case Restoration and Repair Oct 3, 2014
Black Slate Clock Clock Case Restoration and Repair Sep 27, 2014
Question about CURATOR SLATE BLACKENING Clock Case Restoration and Repair Feb 21, 2014
