Cuckoo weights
mizeddie
Jan 7, 2020
I have two cuckoos..one is a true cuckoo, the other is a child's bunny with eyes that move side to side instead of the bird. I have had both for about 45 years. Just a couple years ago, I discovered weights were lost.
Each clock only uses one weight. So, I need to know what weight to get. I would assume they are one day clocks, only having the one weight. Thanks for any help. I seem to have developed an affinity for clocks, and would like to get these running again and hung up.
JimmyOz
Feb 21, 2008
781
164
65
Gold Coast Qld
If both only require 1 weight I would get 275 grams for each.
Reactions: shutterbug
mizeddie
Jan 7, 2020
Here are some picstures of the front of my clocks, and the best I could get of the inside back for the works. I don't think there are any marking on the rabbit works. Thanks for all the help!
mizeddie
Jan 7, 2020
These would use the lightest of weights.
Thank you! I appreciate all ;the help I can get. They may be simple touristy cuckoos, but they came from Germanyin the early 70s while my brother was stationed there. They were sent home as Christmas gifts for my Mom and the rabbit was for my oldest daughter.
46,162
1,768
Those are novelty clocks and movements. I agree that a light weight will run them. You could rig up some weights with stuff you have around the house in order to decide what weight you need to buy. You want to run them with the least weight that will keep them running all day. They will both take the same size. The heavier the weight, the faster they will eventually wear out. I don't believe that particular movement is made any more.
JimmyOz
Feb 21, 2008
781
164
65
Gold Coast Qld
They still make both of those movements, the one not pictured (weather house) has bellows attached to it so it may need the 275 grams,
46,162
1,768
And just FYI, the man and women on top are just part of a barometer of sorts. One or the other will be out, showing fair or foul weather.
Similar threads
164,810
1,434,022
85,813
objectsnthemirror
2,863
