Cuckoo sings if the hands are moved backwards, but not if they go forwards
Discussion in 'Clock Repair' started by dalgetty, Apr 17, 2017.
  1. dalgetty
    dalgetty Registered User
    Apr 17, 2017
    Dear Friends,
    My cuckoo clock, an Azura, has a cuckoo that sings if I move the hands backwards, or if I pull the little string which allows me to advance the hours the cuckoo sings. But if I move the hands forwards there is just a "Thunk", and the cuckoo only opens the door a tiny crack.
    You can see the mechanism in this video, where I advance the hands clockwise, then anti-clockwise:
    https://youtu.be/i9DqwKw9F84
    How can I repair it?
    Thanks for your time! (and expertise)
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    I can't tell for sure but it sounds like the wheel timing is
    off such that the warning is not right, leaving the maintenance
    cam in the wrong position.
    Warning should be long enough such that the maintenance lever
    can fall back into the slot on the maintenance cam.
    We'd be better able to tell if the movement was out of the case.
    The video doesn't show much of the movement's action.
  3. shutterbug
    34,341
    30
    Is this a new development or is the clock new to you? I can see that there is no warning run. What is causing that is not clear. If it's a new to you clock, it may be installed or adjusted wrong. If it's a new situation in a clock that has been acting correctly we'll have to go deeper.
  4. ragobo
    ragobo Registered User
    Apr 14, 2015
    197
    sales consultant
    Barcelona
    #4 ragobo, Apr 17, 2017
    A bit risky but you could try to remove the front dial, on most cases is only nailed but not glued. If you remove it you could take a video showing what's going on inside.
    Edit: I found those pictures of an azura cuckoo movement on an ebay listing. As it is endend now I think I can link them here:
    http://www.ebay.ie/itm/Vintage-Celestin-Konrad-Azura-Brass-Swiss-Cuckoo-Clock-Movement-w-Bird-E566b/201422309643
    On the front side there's what looks like a lever with a spring. Just blindly guessing but it could be the spring on your movement (if it's like the one pictured) may be loose and only when you move the minute hand backwards the lever is forced down...as said just blindly guessing.
  5. Tinker Dwight
    13,680
    It is not likely to show much behind the dial. This
    is a count wheel, not a rack and snail.
    It is better to remove the movement.
  6. dalgetty
    Apr 17, 2017
    thanks for all of this advice - I will try to remove the movement and post another video
    the clock has worked until this year, I am determined to get it going again
  7. Tinker Dwight
    13,680
    You will need to remove the flutes first. Use some string and tie the bellows
    closed so you don't tear the bellows.
    They are usually attached with one screw
    and a small brad. Remove the screw and then us a knife to pry it off the brad.
    Carefully unhook the lifting wire.
  8. Chris D
    Chris D Registered User
    Donor NAWCC Member
    Sep 8, 2009
    261
    Coplay, PA
    Does the minute hand turn very easily? Only thing I can think of is that the spring clutch is 'loose' and doesn't have enough tension.
  9. dalgetty
    Apr 17, 2017
    Dear Friends,
    I removed the movement from the case - I've never done anything like that in my life before !
    Here is the movie where I show the backwards action - which cause the cuckoo to sing, and the forwards action, which does not, from several angles:
    https://youtu.be/a2qCHYGBzng
    Thanks again for your time and expertise
  10. Tinker Dwight
    13,680
    #10 Tinker Dwight, Apr 18, 2017
    I noticed that when going forward, the count lever popped up.
    It shouldn't catch. It should lift smoothly and go into warning.
    When it falls after passing the hour it should start the strike.
    I've never seen one quite like this movement but it is a count
    wheel clock most all run on the same principles.
    The wire to follow the cam is a little unusual.
    I'd like to see the front of the movement when it makes a complete
    pass. It is not interesting to see you back it up to strike.
    It may be a symptom but we need to see the front when it completes
    the lift and fall of the J lever ( even if it doesn't look like a J ).
    We need to see the action when moving the hand the full 360 degree,
    not just till warning.
    It also looks like you may have some other timing issues as the hammer shouldn't
    move when going into warning.
  11. dalgetty
    Apr 17, 2017
  12. Tinker Dwight
    13,680
    Can view the youtube. You need to change the privilege level.
  13. dalgetty
    Apr 17, 2017
    Sorry, I think it should be OK now - it should be unlisted, but visible
  14. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    The youtube runs fine now, but I cannot tell what is wrong - cuckoos such as yours are not something I have worked on.
  15. dalgetty
    Apr 17, 2017
    Thanks for looking !
  16. ragobo
    Apr 14, 2015
    197
    sales consultant
    Barcelona
    I think what's going wrong is that the minute hand bush is not correctly syncronized. It's doing the strikes at 15 min and at 45 min. You should take the minute hand off and rotate the bush about a quarter of a turn.
  17. shutterbug
    34,341
    30
    It looks like it's going into warning, but not dropping out to allow the train to run. Look for a stop pin or lever either touching the fan, or the wheel under it.
  18. dalgetty
    Apr 17, 2017
    I'll have a look at that, contrasting the way it behaves when moving forwards and when it moves backwards
    Will keep you posted
  19. Tinker Dwight
    13,680
    The clock is going into warning but it is not starting the strike.
    The wire that is lifting at the front of the clock is most likely
    the culprit.
    Try this experiment.
    move the minute hand until the lifting lever ( the one in front )
    has just dropped.
    Push it down a little against its springiness. You should have to bend
    it. I believe it will trip the strike.
    Please report back.
  20. dalgetty
    Apr 17, 2017
    Hi Tinker,
    I just followed your instructions and that's exactly what happens!
  21. Tinker Dwight
    13,680
    You can see there is a set screw at the right end if the lever.
    You should be able to set it so that it just goes high enough to
    do a single strike at the half hour and the full strike at the
    hour.
    Tinker Dwight.
  22. dalgetty
    Apr 17, 2017
    Dear Everybody,
    This is the sound of victory:
    https://www.youtube.com/watch?v=OSW91A4EQTI
    Thanks to all of you for your help - I had never even opened the back door of a cuckoo clock before Monday. I could never have fixed this without you.
    Above all, high five to Tinker Dwight - thanks a million ! You were right on the money.
    Tomorrow I am going to return this cuckoo to the chalet here in Switzerland, where it has hung in pride of place since the 1940s.
    Best Wishes,
    John
  23. shutterbug
    34,341
    30
    Now just rotate the hour hand to match the call of the bird, and you have it :)
  24. ragobo
    Apr 14, 2015
    197
    sales consultant
    Barcelona
    If there's something in common on all those cuckoo birds is that they are not very polite and always close their door with a bang :)
Similar Threads - Cuckoo sings hands Forum Date
Regula Cuckoo Clock Movement Change Clock Repair Tuesday at 5:34 PM
Cuckoo Bird Tipping Wire Clock Repair Oct 2, 2017
Cuckoo clock music movement? - 8 day or 1 day Clock Repair Oct 1, 2017
Cuckoo sings too slow Clock Repair May 28, 2017
Cuckoo Clock Bird Sings 15 minutes late Clock Repair Sep 3, 2012
