Cuckoo Question
Discussion in 'Clock Repair' started by Frank Manning, May 15, 2017.
  1. Frank Manning
    Frank Manning Registered User
    Nov 22, 2005
    336
    Vernon, CT
    Hi Everyone,
    I have a cuckoo question. It concerns a cuckoo with three trains. The clock has two doors; one for the cuckoo and one for the little boy. I have it all done. I thought. My concern is that when it cuckoos the door for the boy opens but closes at the end of the cuckoo but then reopens as the music plays. Is it supposed to open when it cuckoos? I believe the levers for this are down between the plates. Should they be readjusted if a change is needed?
    Thanks, Frank[​IMG]
  2. shutterbug
    34,360
    31
    The musician door should stay closed until after the cuckoo. The cuckoo door closes, the other door opens, and the music starts. The door is probably controlled by the music train, but often has a cam lever in the upper left corner looking into the back.
  3. bangster
    bangster Super Moderator
    16,320
    21
    Could we get a shot higher up in the inside, to where the bird and the music man live?
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    The cam lever you describe does run off the music box. If the door is opening at the wrong time, some resynchronising is needed. in some of these clocks, this is hidden in the attic of the case. The case needs to have the ceiling taken out to access it.
  5. Willys_1
    Willys_1 Registered User
    Jan 2, 2013
    52
    Project Manager
    Pleasant View, Utah
    Many cuckoos have a lever/wire that stops the governor on the music box while the cuckoo is active. When the cuckoo stops, the lever/wire moves enough to allow the governor to turn freely. It's hard to tell from this pic if that is the way this cuckoo was engineered.
  6. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    #6 roughbarked, May 15, 2017
    Yes but this isn't where the door opens from. A cam is generally turned by the music box and this cam opens and shuts the music man's door. If it is out of synch it generally has a grub screw so that it can be adjusted correctly.
    This clock has a different system. The rod that opens the music door is on the right of the clock and I suspect that the worm drive runs the door? This could mean that the warning wire is running the music box too soon but that would also mean that the music is starting as the cuckoo is still counting hours.
  7. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    This being a count wheel clock with specific hardware to run the
    zither player, it might be completely different than the more modern
    movements where the music is more of an add on.
    I think before I'd say much, I'd need to see a video of the
    mechanism in action and most likely the front of the movement
    as well, since I can't see any coupling between the strike and
    music at the back of the movement.
  8. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    This is true.
  9. shutterbug
    34,360
    31
    I recall seeing this movement before, now. There is a release wire between the strike and music wheels, which I don't see in the pic. However, it's between the plates, so may be there. The music goes into warn when the cuckoo activates. The count lever falling into the deep slot releases the warn lever, and the music man comes out when the music train starts. The worm gear controls the fly, but there's also another wheel behind it. There's a cam between the plates that wears and messes up the warning system. I'm not sure how you would go about making one of those. It releases one pin and quickly stops another. When it wears out, it allows the second pin to be missed so the train starts prematurely.
  10. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    Interesting information. As may be inferred by my previous posts. I haven't seen this movement before this.
  11. Frank Manning
    Nov 22, 2005
    336
    Vernon, CT
    Thank you everybody for your information. With that I believe I found the answer; at least it works now. There isn't anything in the upper area or no fly on the music box . The music box is just the ddrum and a gear. If you view the side door thee is a vertical lever that activates the boy arm. That vertical lever has attached to it, between the plates, a lever that goes over to the strike side. So, that lever activates it and the door is opened by the vertical lever in the side view. The gap there is very important. I had to adjust the lever arm between the plates and the vertical one in the side view. Now it is running correct,
    Thanks, Frank[​IMG][​IMG]
  12. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    It looks to be one of the better made cuckoo clocks.
Similar Threads - Cuckoo Question Forum Date
Cuckoo Bird question Clock Repair Aug 12, 2017
JMIUS Cuckoo question Clock Repair May 23, 2017
Regula 72 Cuckoo Movement. Auto beat question Clock Repair May 2, 2017
Quail cuckoo question Clock Repair Apr 30, 2017
Cuckoo Question? Clock Repair Mar 7, 2017
