• Upcoming updates
Cuckoo cuckoo pendulum
analogtime
Feb 4, 2005
156
Wi
Is there a source of "bulls eye" type pendulums for early black forest cuckoo clocks just the bob would do fine that way the hanger could be fabricated to fit the situation.
tom427cid
Mar 23, 2009
1,688
122
Moultonborough,NH
If you have acess to a lathe the "bulls eye" pendulum is not to difficult to fabricate-The pend rod I use welding (gas) rod thread the end use a large hand nut for rating and hammer(on an anvil,vise or similar surface) the end for a hook. A scrap of brass for the cross piece- couple of brass wires-for the guides and bend the staples for the brass wire guides and you are all set. I try to find a piece of old walnut for the 'bulls eye" and with a little color -it looks original. Any way thats one way of doing it tom
Billy
Dec 14, 2004
367
67
Western NY
If you get real hard up for one, like me, I used a corner finish block for a doorway from Lowes. All they are is a 3.5" x 3.5" pine block with a bullseye lathed out in the middle.
I scroll sawed the center out, sanded the back down to roughly 3/8" and attached the hardware.
Looks and works good till I can run across a original one:p Clock Pics 017 (Small).jpg
Billy
You can just see in the upper left corner, one of those blocks used. Thats where the idea came from...
laprade
I came accross a spare "draught" from a board game and it gave me the idea that if you get a "box wood" cream coloured one and cut it down the middle, it might do.
today I was looking at the site of
Meadows and Passmore
and they do a series of black forest and cuckoo bobs.
Mike Phelan
Dec 17, 2003
11,122
427
West Yorkshire, England
Isn't the bottom part of the rod wood, Tom? Making a pendulum like this can be easily done using scrapbox materials - no big deal.
laprade
welding rods also make very good longcase ones, not to mention the older quality wire coat hangers you used to get from the dry cleaners.
the present day, thinner ones, are ok for wags on the wall. they are too thin for the thread on the new susp blocks for LCs.
I once made a grid iron pendulum using welding rods.
Latest posts
Staff online
180,056
1,570,752
54,364
clockminded
911
3,090
