Cuckoo part needed- 7&3/4” pendulum
AwesomeEK
Apr 25, 2021
Anyone know a good reasonable establishment to get a pendulum for a cuckoo from? It’s a regula 34 movement.
13,738
1,415
All of the usual suspects sell cuckoo pendulums. See "Clock Suppliers" at the top of this page, 5th category. Willie X
46,395
1,851
The Regula's have different pendulum lengths for different models. Are you sure the title length is correct?
AwesomeEK
Apr 25, 2021
I thought that I was. I believe that information was provided by someone at BlackForest. It was actually in CM but converted to imperial.
46,395
1,851
Check these out. You might want to make a makeshift pendulum to verify length first. Notice that you can get longer sticks and just shorten as needed. That might be the way to go. :)
Reactions: AwesomeEK
AwesomeEK
Apr 25, 2021
THanks, I like the concept, but where do you get the maple leaf to fit over the rod? I dont see any there. I see the hook, slider and rod.
13,738
1,415
Post a photo of your clock. Someone can recommend a nice replacement pendulum.
On a cuckoo, you actually don't go by the length. The bob has to be the right size to be in proportion to your clock, the right color, and the right style (oak leaf, maple leaf, chalet, etc)
The length can be made to be anything you like by ordering a long stick and cutting it off to what you like, when necessary.
The length designation is probably stamped on your movement. The measurement is approximately, handshaft to center of the bob/leaf.
AwesomeEK
Apr 25, 2021
Thanks for your reply. Some of the companies that I called regarding replacement movements told me that the length was the way to choose a pendulum. Here is the pic below. Cuckoo.jpg
13,738
1,415
Repeat, don't go by the length.
Measure the 'width' of the lower three leafs on your clock and shoot for that size, or slightly smaller. The supplied
(7 to 8") length will be adequate with rare exception.
Merritt's ... P-467, P-468, P-469 are
2 1/4", 2 5/8", 3" wide (respectfully).
Timesavers is similar.
Black Forrest actually does sell them by length only! This is weird, you would have to call and get someone to measure the width before you buy. Or, just skip them.
JeffG
Jul 8, 2020
56
12
St. Croix, U.S.V.I.
According to William Bilger's book The Cuckoo Clock Repair Manual, Regula 34 pendulum lengths can be 19.5cm (64), 23.5cm (58), 28.5cm (70), and 40cm (51) and are dependent on the number of teeth on the 2nd wheel (noted parenthetically) to provide the correct BPH for the clock.
As Willie X has said, the size of the leaf would need to be correct, too. Otherwise the weight would be altered and affect the center of mass.
AwesomeEK
Apr 25, 2021
Thank you as well. but WHERE do I get a leaf? I can't find just a leaf.
AwesomeEK
Apr 25, 2021
13,738
1,415
Awes,
You are overthinking this, or maybe just getting way 'to much information', a common problem these days ...
All you do is order a 'brown maple leaf pendulum' with the right size (width) leaf. That's it. This is as simple as I can make it.
Over and out,. Willie X
Reactions: JeffG
JeffG
Jul 8, 2020
56
12
St. Croix, U.S.V.I.
If the supply houses don't have what you're looking for, your next best bet is Ebay- or a benevolent Forum reader.
165,376
1,439,393
86,181
Kevsun
2,873
