Chris D actually one other small question if you don't mind - I've just about gotten this thing adjusted, the saw men saw, the clock ticks, the axe man chops and the music plays after cuckooing... but now sometimes the music doesn't play, if i gently pull on that pine cone, it will, and sometimes will continue to play on its own after other cycles. It seems the mechanism that runs the fan is also what causes the friction to prevent the pine cone from dropping, if i loosen the screws there too much the pine cone simply falls to the ground - is that the trick, to loosen just slightly somehow? Unfortunately to make small adjustments everything has to be taken out and readjusted which breaks something else usually![]()
