Cuckoo movements- attaching suspension post
MARK A. BUTTERWORTH
NAWCC Life Member
Jul 4, 2009
2,529
176
Muscatine, Iowa 52761
They become loose, even on new movements. With the possibilities of riveting or peening, Loctite, etc., what is the preferred method for some of the repair folks?
JimmyOz
Feb 21, 2008
1,088
278
66
Gold Coast Qld
I worked in a cuckoo shop for over 10 years and had this issue often, even had to change posts on new movements when a long post was required and we did not have any. At first I peened them in, however the thin plates and tendency to bend and trying to get it in at 90 degrees on some was frustrating. What I did was use one of those thin cutting wheels and cut a slot in the post about 6mm past the shoulder ground a bit of steel round stock to a wedge and tap it in, a bit of solder to hold it and cut off the excess with the same small cutting disk. Dose not take as long as it sounds, however it make for a nice clean job especially on a new movement.
47,827
2,290
If I understand correctly, he cut a slot in the base of the post and used a steel rod to force the slot open, securing the post in place. Then solder to hold the steel/brass together, or possibly hold the post in place too.
Reactions: Vernon
169,773
1,481,794
49,157
DavidEckman
2,965
