Cuckoo Disassembly
Discussion in 'Clock Repair' started by gocush, Apr 13, 2017.
  1. gocush
    gocush Registered User
    Jun 24, 2016
    168
    Olympia, Washington
    #1 gocush, Apr 13, 2017
    [​IMG]First time working on cuckoos. I need info on how to disassemble it. See photo.
    The 2 bellows boxes are GLUED (blue arrow) to the sides of the thin plywood case. In order to access the 4 mounting screws (red arrows) and remove the movement, it appears that I must pry apart these 2 wooden glue joints holding the bellows, then remove the bellows. This seems very destructive to me and likely to split the plywood sides. Is there an alternative, or a way to "soften" the glue? From a blob that oozed out just below the bellows, it appears to be carpenters wood glue .
    Thanks[​IMG]
  2. Willie X
    Willie X Registered User
    8,065
    29
    Yes, the whistles are glued to the case on many newer cuckoos.
    To remove them use a small thin (but dull) knife, start at the bottom and when you get the blade in between the whistle and case a bit, twist it and the whistle will pop right off. Sometimes it will separate cleanly, sometimes a small area of the plywood case will pull out.
    I always clean this glued joint as well as I can, so the whistle can be replaced using the traditional single screw flat head wood screw and small brad/nail.
    Hope this helps, Willie X
  3. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,866
    watchmaker
    Western NSW, Australia
    As above. Yes.
  4. James Holloway
    James Holloway Board Secretary
    Jul 13, 2009
    174
    To remove the bellows a knife as suggested works well. I use a narrow putty blade which is like the knife. Another help is to use a heat gun or torch to heat the blade which will allow it to soften the glue faster and generally pops off without pulling any plywood off the case.
    Hope both ideas help you. Jay
  5. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    621
    Science teacher, writer
    Lancaster, Ohio, USA
    I just had one of these. The bellows popped out when I braced a kitchen knife against the bottom of the case and levered the sharp edge of the blade between bellows and case. I found it helpful to mark the positions of the whistles so they go back in the same place.
    M Kinsler
  6. bangster
    bangster Super Moderator
    16,305
    20
    a. Pry the whistles off.
    b. Remount them with the screw and the nail.
    I've never seen serious damage to a cuckoo clock by prying off glued whistles.
    Is what I think.
  7. shutterbug
    34,335
    29
    It's possible that your doesn't have the screw and pin that has been mentioned. If not, it's just a small screw that goes through the case into the bellows tube roughly half way between the top and bottom ( a bit lower might be better), and a small pin inserted the same way at the upper end to keep it from moving. Don't use glue when re-installing.
Similar Threads - Cuckoo Disassembly Forum Date
Regula Cuckoo Clock Movement Change Clock Repair Tuesday at 5:34 PM
Cuckoo Bird Tipping Wire Clock Repair Oct 2, 2017
Cuckoo clock music movement? - 8 day or 1 day Clock Repair Oct 1, 2017
Cuckoo Disassembly Question Clock Repair Feb 25, 2012
