I have just obtained a Vintage Swiss Cuckoo Clock. I have taken all the components from the Chalet case and cleaned the movement in commercial ammoniated solution and dried thoroughly. Afterwards, I noticed, that the timeside Chain wheel was rather tight so I freed it up somewhat using a blade to push it round manually.
The Cuckoo side works well. If I trigger it, the weight drops and I get coo, koo, gong, as expected.
On the Time side, I don't think the weight is exerting any real force, as after half a dozen swings of the pendulum, the Clock just stops.
My question is, is there an obstruction to the weight dropping or is it simply too dry and has too much friction? Can I oil inside the wheel to re-enable the movement? Any advice please? Howard in Devon, UK
