Cuckoo Clock runs too fast
Discussion in 'Clock Repair' started by Ansel Spear, May 16, 2017.
  1. Ansel Spear
    Ansel Spear Registered User
    May 16, 2017
    7
    I've just had my Regula 25 1-day cuckoo clock returned from service after about 3 years. The pendulum appeared to be the original one, and its leaf weight was approximately in the position I remembered it to be on the stem. However, initially the clock gained 80 minutes across 12 hours. Even when the leaf was moved to an unnaturally low position on the stem (almost off the end), it still gained about 5 minutes across 12 hours. I have now been sent a pendulum with a much larger leaf and, again, I've had to move this to a very low position on the stem to get it almost within tolerance. But it looks odd.
    Could anyone please advise me whether there are any other factors that may change the workings of the mechanism. I notice that the chains have been replaced. The weights look like the original ones, but I did not make a note of their spec before I sent the clock away.
    All suggestions extremely welcome. Thanks.
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    3 years?
    Is that the last time fresh oil was applied?
    I did not make note, is a bad appraisal.
    forget the size of the weight or the length of the original rod?
    what is different about the chains?
  3. harold bain
    Donor NAWCC Member
    39,961
    Replacing the movement could have this affect on the pendulum, as they come with 3 different rated pendulum lengths. A new movement comes with new chains.
  4. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    Yeah. A new movement is ALL new and it should actually not need to be regulated off the end of the pendulum thread, in any direction. Unless of course the old pendulum is applied to the new movement without viewing the pendulum supplied with the new movement. But.. after three years the repairer should probably have noticed this.
  5. Ansel Spear
    May 16, 2017
    7
    To be honest, it probably hasn't been oiled since 1987! But during that time, the adjustments to the pendulum have been minor. I haven't taken the back off, but I paid for a service, and not a new movement. He didn't mention a new movement when I collected it so I'm assuming it's the original.
  6. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    I'm with Harold on this one. It is usually cheaper replace these movements
    than to repair them.
    My guess is that they swapped in the wrong movement.
  7. Ansel Spear
    May 16, 2017
    7
    The movement wasn't so much faulty, as a local company messed about with it, and the sync between all the functions was completely out. This was corrected and a service given (so I have been told).
    Apart from memory and commonsense, how can I determine whether it's a different movement? If they have swapped in the wrong movement, why would that affect its regulation., Apologies if these are dumb questions.
    - - - Updated - - -
    What is different about the chains? They're not tarnished like the others were.
  8. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    #8 roughbarked, May 16, 2017
    It has to be a reluctant cuckoo clock that takes three months to get out of here and I have never replaced a cuckoo clock movement in 46 years of repairing them.
    Sonmebody has mucked up somewhere.
  9. harold bain
    Donor NAWCC Member
    39,961
    There are no threads on these cuckoo pendulums. And new movements don't come with new pendulums. My suspicion is due to poster saying there are new chains. The only other thing would be a too short pendulum instead of the original one, if the movement was not replaced.
  10. Willie X
    Willie X Registered User
    8,076
    29
    A good close-up photo of the movement will tell the tale.
    3 years! Never leave anything anywhere for more than a month or two ... you're lucky to get it back.
  11. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    Maybe it is just trying to make up for lost time :-X
    Seriously - have you noticed the minute hand suddenly moving ahead way too fast and hearing a "flutter"? It is not common on cuckoos, but could happen.
  12. Tinker Dwight
    13,680
    He needs to run it for a few hours to tell if it is fluttering ( possible ).
    Let it run and check it once an hour and note the difference.
    If it is fluttering, there will be a different amount of time gained
    for each hour. If it is a constant gain, each hour, it is the pendulum
    length issue.
  13. shutterbug
    34,360
    31
    That sounds like the most likely scenario to me too. I'd send it back to the shop to do it right.
  14. harold bain
    Donor NAWCC Member
    39,961
    Only if he is prepared to wait another 3 years. I would try to find a longer pendulum if that is the only problem noted.
  15. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    Donor NAWCC Member
    Jul 4, 2009
    1,874
    Look onThe back of the movement. On the right-hand side on the vertical pillar check to see if there is a centimeter number that would be the pendulum length
  16. Ansel Spear
    May 16, 2017
    7
    Thanks Mark. I didn't know that.
  17. Ansel Spear
    May 16, 2017
    7
    It was a bit of a problem and not what I had anticipated.
  18. Ansel Spear
    May 16, 2017
    7
    View attachment 343944 View attachment 343945
    I'm fairly sure that this is the original mechanism. I can't find an indication of pendulum length. The regulation is roughly correct now with this replacement pendulum setting. It's much, much lower than before the service. See original pendulum as comparison.
  19. Chris D
    Chris D Registered User
    Donor NAWCC Member
    Sep 8, 2009
    262
    Coplay, PA
    Could be that the repairer swapped out the chain wheel for some reason... worn pivot, broken click etc. He may have installed one with a different tooth count by mistake and now you need the longer pendulum.
  20. Tinker Dwight
    13,680
    I doubt a chain wheel would make it run fast. More likely the escapement wheel
    was replaced.
    It does look to be an unusual movement so not likely to be a replacement.
    I've not seen that coupling before for the music.
    One wonders if a 3 year sit in the shop that it may have been apart and
    lost a few pieces.
    It would be interesting to watch it running while viewing from the back side.
    A video would be a big help for us to help you.
  21. Ansel Spear
    May 16, 2017
    7
    I'll see what I can do with the video. Thanks.
Similar Threads - Cuckoo Clock runs Forum Date
Cuckoo clock will not cuckoo but runs Clock Repair Yesterday at 11:04 PM
Regula Cuckoo Clock Movement Change Clock Repair Tuesday at 5:34 PM
Cuckoo clock music movement? - 8 day or 1 day Clock Repair Oct 1, 2017
Cuckoo Clock restoration Clock Repair Sep 8, 2017
Cuckoo clock runs until right before the hour or half hour Clock Repair Jul 11, 2013
