Help Cuckoo clock repair
Discussion in 'Clock Repair' started by Robert Horneman, Feb 24, 2020.
  1. Robert Horneman
    Robert Horneman Registered User
    Jul 6, 2017
    15
    I have a three train musical cuckoo. The music and cuckoo play at the same time. How do I adjust that? Also any books ,videos that explain/ show how to reassemble and adjust the movement after cleaning?
  2. Vernon
    Vernon Registered User
    NAWCC Member Donor
    Dec 9, 2006
    593
    45
    Gardener/Arborist
    Typically, there is a wire or similar that blocks the fan on the governor just before the hour and holds the music until the strike finishes. Then it drops out to allow the music to play. This is a supper fine adjustment as too much and the music won't play and too little and it is what you have now.
    Hope this helps.
  3. POWERSTROKE
    POWERSTROKE Registered User
    Jan 11, 2011
    622
    36
    I have the Karl Kochmann book, balcomb books and just received this one. Bought it off eBay. I should’ve bought this one a long while ago. I’ve already done things in this book with the help of the forum....
    Kevin W. likes this.
  4. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,438
    154
    Carson City, Nevada
  5. shutterbug
    41,815
    927
    That's a great video, THT! Thanks for sharing.
    THTanner likes this.
  6. disciple_dan
    disciple_dan Registered User
    Mar 10, 2016
    444
    26
    Clockmaker, General Flunky
    Apopka, Fl.
    Does that 3 train cuckoo mean all 3 trains are between 2 plates? Similar to a grandfather's movement?
  7. shutterbug
    41,815
    927
    Usually not, unless it's a quail cuckoo. The music box is usually separate, and just activated by the usual two train cuckoo movement.
  8. disciple_dan
    Mar 10, 2016
    444
    26
    Apopka, Fl.
    Well, I was asking the original poster that question because he said it was a three train movement and that would surely change the answer. But, thanks for the answer SB
  9. shutterbug
    41,815
    927
    Yep, understood that, dan. I was just clarifying the reason for your question so our OP would see where you were going. I should have left out the first two words. :D
    disciple_dan likes this.
  10. Kevin W.
    Kevin W. Registered User
    22,015
    268
    Books and videos are great investments. I am always on the hunt for good books in the horology hobby.
  11. Robert Horneman
    Jul 6, 2017
    15
    Yes looking from the back, striking on the left ,motion in the middle and music on the right.
  12. shutterbug
    41,815
    927
    Well then, much of what's been stated so far is not too helpful :) The principle is the same though ... something has to hold the music train during the strike, and then release it. It's probably a stop pin, and it may have broken off. Look at the top 2 or 3 wheels of the music train and see if you can see a spot that looks like it used to have a pin attached. And post a pic of the front of the movement for us.
  13. bangster
    bangster Moderator
    19,519
    366
  14. JimmyOz
    JimmyOz Registered User
    Feb 21, 2008
    354
    50
    #14 JimmyOz, Mar 2, 2020
    Does the movement look like the one below. If so, and it has been a while since I have had to work on this type so it is from memory and not to good. Anyway, you see the cam with the pin in it, that can be adjusted, run the cuckoo and see that the black hook lever (hiden under the wheel in the photo) should move down to engage the pin on the cam, just adjust the cam till it holds, when the cuckoo stops it should relase the hook and the music plays. If this is the right movement just fiddle with it a bit as it may have to engage the hook when the cuckoo sets, however not sure? Cuckoo-Clock-Movement-Regula-701-Musical-Movement-_57.jpg
  15. shutterbug
    41,815
    927
    Gosh, those things are a nightmare to get right. There's a wire running inside the plates between the strike and music side. A cam inside regulates the warn and release, and if it's worn even a little it will be impossible to get the warn and release right. It's one of the few clocks I've worked on that I just gave up trying to fix. I'm not sure if I still have it after my recent move.
  16. JimmyOz
    Feb 21, 2008
    354
    50
    Yes they are, lucky they don't show up to often had about 4 in 10 years to do, they are on the more expensive cuckoo clocks. As I said you have to fiddle with it a bit to get it right, although abuse does not help I seem to remember giving the movements a lot :argument: :banghead:
  17. bangster
    bangster Moderator
    19,519
    366
    Oh, THAT one. With the flying fan. :eek:
