Hey Everyone,
First post here and I tried to search but I’m not sure if i’m using the right terms and didn’t find anything like this.
Anyways, I have a 30 hour Regula movement with dancers and music and it calls on the hour and half hour. It has a silencer lever on the side and when I got the clock that wasn’t working. It was dirty and so I cleaned it and got the clock to work well calling correctly at half hour and hour and the only thing that didn’t work right was the silence lever so I bent the part that pushes on the rod with the spring on it that I assume makes the chime engage or not. I see that it pushes down on it when I push the lever down and releases when I put it back up and it does work to let the clock run and not chime and I can see that the snail is still going through the hours even though not calling but here’s my problem.
When I went to set it back on it will only call once no matter the hour and chimes once on half hour like normal. The weird part and I’m hoping this is some kind of clue but when I take it off the wall and remove the weights and play around with it I get it to work fine. I’m not doing anything really it just seems to work and then I very carefully put it back on the wall and it’s back again to only one chime! I’m very careful to not tip or bump it.
I’m at a complete loss. I must be missing some tests or where to look to see what could be causing this cause it looks like it’s doing the same thing on the wall and off but obviously something has to be different with each situation. Anyone have any ideas what it could be?
I’ll post some pictures in case it helps at all:
