Cuckoo clock Mfg. Co.
jimkatzin
NAWCC Life Member
Jan 3, 2003
21
I am working on a movement made by the Cuckoo Clock Mfg. Co., Germany. It is a 30 hr non-musical movement, stamped 100/171. It is in very rough shape and hardly worth repairing. Is there an equivalent movement made by Regula or Herr that is a direct fit for this movement?
Jim
jimkatzin
NAWCC Life Member
Jan 3, 2003
21
Jim
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
In all probability JK, it probably is a "REGULA" movement. Regula "25" (25 often stamped on movement backplate) is a one day movement. Altho most are of same pendulum length - that should be a consideration. Most modern ones are so interchangeable you'll find it aligns perfectly with the original mount holes and little or no mods necessary. I'd snatch one offa EBay for probly under $20. Shoot. Ya may even find a Cuckoo mfg. one there if that's important to you. I find "HERR" movements of better quality, more expensive, and likely less interchangeable.
J
Jim Galazka
I have a cuckoo clock co. 100/171 movement that has no weights.
Can anyone tell me the proper size weights used for this movement.
Thanks in advance.
tymfxr
May 13, 2005
1,202
36
Jim, if you still need more info on your clock check out this site http://blackforestimports.com/
Call them and if the person you talk to doesn't have answers for you, ask for Peter. Mike C.
165,345
1,439,134
86,159
Clockjoyner
2,873
