Cuckoo clock keeps stopping
dullster
Feb 20, 2021
12
59
I have restored an old cuckoo clock. When I start the pendulum it will tick for about a minute than slowly stop.
I had to replace the chains, the weights, bellows, cleaned the gear box, bought a replacement back, new hands and brought a pendulum. I have timed it as best I can, which appears to be rocking evenly. (Don’t know the terms). Any suggestions? 7F787FD1-91A7-4F65-9235-55D5BDE74AD7.jpeg
13,559
1,350
Greetings,
One thing, your pendulum is to big for the clock. Also, everyone will want to know more about your "cleaning of the gearbox". Willie X
dullster
Feb 20, 2021
12
59
I took the clock apart and soaked in the clock ammonia cleaner for 24 hours, than with a toothpick and toothbrush, scrubbed and rubbed. After, I rinsed it with water and dried with a blow drier. I let it sit over night to dry out then oiled every little oil hole with clock oil. How did I do? I thought I ordered a small pendulum. Is there a ratio of size it should be? Shouldn’t my clock still run regardless of size?
This was my husbands grandfather clock so I watched a lot of videos to clean it, oil it and time it.
Dick Feldman
Sep 1, 2000
2,465
177
Colorado, usa
How about a picture of the inside of the cuckoo house.
What is stamped on the movement back plate?
It looks like you have weights for a 30 hour run clock movement.
Is the movement an 8 day movement?
You said " I have restored an old cuckoo clock."
If it is old enough, the movement is probably worn to the point that it cannot be dependable.
Dick
13,559
1,350
Pendulum size is not critical but that one is to big. This would make a borderline movement undependable. Did you check your movement for wear. Look up " checking for wear". Willie X
POWERSTROKE
Jan 11, 2011
1,123
74
Dick
8 day movements have the weights on the outside case holes
dullster
Feb 20, 2021
12
59
I weighted the existing weight I had and order weights that were the same weight. 275. I believe it’s a one day clock. These are the 2 I currently have without taking more
028342C5-E97E-4DC5-9E0B-D718D4304C48.jpeg FB7058B5-87B0-4ECA-B891-B5772ACDFB33.jpeg
dullster
Feb 20, 2021
12
59
View attachment 641489 View attachment 641490
I just ordered a 6” pendulum. Will try that. I thought the gears looked good and didn‘t seem to have excessive if any play.
13,559
1,350
This is an older clock, so it would probably have had 320, 375, or 420gm weights. Tomorrow ... I can look this up in my notes, if you like. Willie X
Reactions: NEW65
dullster
Feb 20, 2021
12
59
That would be wonderful. I added extra weight to the side that runs the clock but it didn‘t seem to help. The weight that it had with it was a 275. Reading up on it said I could go heavier with no problem, so I looked at the 320 but I think were ever I was ordering from came in sets of 3. I’m hoping the shorter pendulum will do it. The timing sounds good (ticking). I appreciate your help. Fixing clocks is almost addictive. I really enjoyed it.
Vernon
Dec 9, 2006
963
120
Try running it with the hands removed. Also, it looks like there is a wire over the bird and it should be under it. Check the bellow wires connections, the higher note should come first.
dullster
Feb 20, 2021
12
59
This was a progress photo. The wire is under the bird. The bellows work if I run them manually. I checked that because the wires were missing and had to replace the wires.
dullster
Feb 20, 2021
12
59
Pendulum wire looks bent. Make sure it's not rubbing the case and that the clock is flat against the wall.
The timing wire is a little bent to get it to rock evenly. I will check the pendulum wire this weekend. As much messing around as it did. It would be bent as well. I’ve tried running it without the back to make sure it is flush with the wall but it didn’t change anything. Although I will try it again.
dullster
Feb 20, 2021
12
59
The only thing I didn’t try was with the hands removed. I will try that.
roughbarked
Dec 2, 2016
5,938
793
Let us talk about bent;
I'm sure many members know mine.
What you really need, is straight and level.
Make this your mantra.
46,175
1,774
Nothing really jumps out at me, but I think Willie is correct about the weight. Those old count wheel movements often used very heavy weights .... about 1/2 the weight of modern 8 day clocks. Check to be sure the crutch loop is centered on the pendulum hanger, and not too tight. A tiny bit of oil there is OK, and put a smear of oil on one of the pallets, so it it transferred to the teeth of the escape wheel. That's the only wheel where the teeth should be oiled. NOT MUCH oil :)
Reactions: NEW65
13,559
1,350
That's a Regula '01'. It requires 420gm weights. Hopefully, "thar's yer problem".
Reactions: NEW65
Vernon
Dec 9, 2006
963
120
My Herr 30 hour with a count wheel has original 276 gram weights. I suppose that if you did not disassemble the clock and clean/peg holes and fix wear, you might expect needing the additional weight to overcome the dirt and wear as it is a fairly light weight? Have you tried it without the hands?
dullster
Feb 20, 2021
12
59
I have not. I will try it tomorrow.
13,559
1,350
Full,
I wouldn't do anything until I had the proper 420gm weights. It will probably run just fine. Willie X
Reactions: JimmyOz
dullster
Feb 20, 2021
12
59
Full,
I cheated and added another weight. It has stayed running. I need to work on the hands. I ordered some that didn’t quite fit so I did some modification to make it fit because one hand that was on it didn’t belong to the clock. I will try adjust the pendulum to see if it is just to slow first. Thank you for all your help. Do you have a book with all this info. How did you know what kind it was?
dullster
Feb 20, 2021
12
59
Drum roll.....and the winner is....weights. I received the new weights and it has ran ever since. With a little adjusting of the bird, it is ticking and cuckooing just like (almost) new.
Thanks for the help. Now to find another one to fix.
Reactions: roughbarked
164,890
1,434,810
85,856
nottmrd
2,872
