• Upcoming updates
Cuckoo Cuckoo Clock Cuckoos too many times only twice a day
davidb4752
New User
Jul 19, 2015
I have an old E. Schmeckenbecher sawmill cuckoo clock. At all hours and half hours it does the correct number of cuckoos except at 1. At 1 it will cuckoo 12 times again. But the rest of the hours will be correct. Any ideas on how to correct this? The movement was just replaced.
harold bain
40,832
195
74
Hi, David, welcome to the message board.
You will have to adjust the snail to correct this problem. It is likely out by a tooth or two. If you paid someone to install the new movement, take it back and let them fix it.
13,664
93
The snail position is most sensitive at the 12/1 point because of the
large difference in counts.
Harold's suggesting is most likely the solution to the problem.
180,026
1,570,419
54,349
Loulou
911
3,090
