Cuckoo clock carousel problem
Discussion in 'Clock Repair' started by Kipster, Aug 11, 2019.
  1. Kipster
    Kipster Registered User
    Feb 5, 2019
    46
    Neenah, WI
    Hi all- general question regarding drive gear for musical carousel.
    Unable to make carousel rotate. Which way should the black gear attach? I tied multiple ways and the black gear is not turning the carousel. Thanks DB
    C2F7FDA8-2CC0-49AB-9649-3DC0A016E03F.jpeg 1A051B86-007F-4721-AE5D-EB888B66862C.jpeg 510496DE-E4B9-4828-ADB9-3DDB29EDDBC3.jpeg 4D8AAB0A-CA71-4D9F-A24C-E7713588D559.jpeg C767D8CA-01E8-4019-8859-6C2A6C229ADA.jpeg 4103CCF7-EE70-4E4A-82CB-243559F31CE9.jpeg image.jpg image.jpg
  2. shutterbug
    43,438
    1,232
    #2 shutterbug, Aug 12, 2019
    From what I can see, it should move CW as when looking at the first pic. If the music box works without turning it, you have a cracked pinion.
    Of course it will be moving CCW when you hold it upright.
    Usually the problem is the plastic pinion gear (below the canister in pic one) that is cracked, and the music box won't run. In that case, you can get a new regulator. It will need to be tweaked to work right. One I replaced last week had to be modified greatly. I lifted the main activation arm with a 3mm high washer and had to bend the shut off tab to match the new circumstances.
  3. Kipster
    Feb 5, 2019
    46
    Neenah, WI
    What keeps the plastic pinion gear attached. Is it pressure pressed?
  4. disciple_dan
    disciple_dan Registered User
    Mar 10, 2016
    626
    44
    Plant City
    Show us the way it all mounts in the case. Most carousels are not direct drive.
  5. shutterbug
    43,438
    1,232
    I believe it is pressed on. I don't try fixing those. It's easier to replace the whole unit. Here are some examples. Be sure to get the right one :)
  6. Kipster
    Feb 5, 2019
    46
    Neenah, WI
    Thanks everyone.
    I am attaching a few more pictures.
    First question-which side should the black pinion gear be seated? The gear does not look cracked. Also, I don’t see a problem with the pinion that it attaches to. The gear turns, however when I attach the carousel. The black gear won’t turn.
    Second question-the white plastic gear on the governor is cracked? How do you determine which Governor size?
    C8E04472-5163-4A42-9A2A-4100C676D0FA.jpeg 640E7964-E89E-4482-8906-317FBBF57AD3.jpeg 2A51E1FC-FC78-44FF-8D59-74CCC0B45037.jpeg C6A20DA3-F7FA-46D6-9324-FFE4C47FFAF1.jpeg 540038F6-F2FC-48DA-878C-043958200B18.jpeg CE406578-D45E-471B-9C76-D528210E37BB.jpeg CF842CE7-6C03-49DC-91E6-A7454A20C05B.jpeg
  7. shutterbug
    43,438
    1,232
    I think the pinion side will go up, to interact with the carousel. You have to count the teeth on the pinion and match it, or it will run either too fast or painfully slow.
  8. Kipster
    Feb 5, 2019
    46
    Neenah, WI
    #8 Kipster, Aug 14, 2019
    Exactly what item do you count the teeth. Could you show me a picture. Is it a part on the governor?
    Changing subject- the black pinion gear works the larger gear on the carousel. I don’t know if the small gear on the black gear pinion does anything. I’ll show another picture.
    825C691E-1385-44DC-B373-8D9B986951A4.jpeg 73B44726-C83D-492C-BB57-1BA040F40F3B.jpeg
  9. Vernon
    Vernon Registered User
    NAWCC Member Sponsor
    Dec 9, 2006
    710
    76
  10. Vernon
    Dec 9, 2006
    710
    76
    You may consider just replacing the plastic pinion that's cracked. I believe that some of the suppliers sell them.
  11. shutterbug
    43,438
    1,232
    What Vernon said.
    So that pinion in the first pic appears to be more of a spacer than anything. I'd put it on just as you have it in the pic.
  12. Kipster
    Feb 5, 2019
    46
    Neenah, WI
    The pinion gear is the smaller gear correct. The arrow is kind of pointing at both gears? Also, I have not seen the small plastic gear for sale. Do you happen to know which supplier?
  13. Vernon
    Dec 9, 2006
    710
    76
    Yes the smaller one. You might check black forest imports. That one is made of metal. I assume that it should fit. Someone here had purchased plastic ones but not sure where they got them.
  14. Kipster
    Feb 5, 2019
    46
    Neenah, WI
    Thank you everyone for your input.
