Cuckoo chimes and cuckoo's too fast
Discussion in 'Clock Repair' started by blindowl1234, Mar 19, 2017.
  1. blindowl1234
    blindowl1234 New Member
    Mar 19, 2017
    I have a cuckoo clock from George Kuehl Clock Co Chicago, Illinois circa 1900. I've had it since 1981 and over the years no major issues until recently.
    It cuckoo's on the half hour fine, the top of the hour is the problem. For instance at noon it will cuckoo very fast for say the first four cuckoo's at noon, ABC1Cuckoo.jpg then something
    appears to engage and the rest of the cuckoo's are normal. I've looked and there's nothing that appears worn or out of place inside. Any ideas on what to look for?
    It was working fine one day and then the next it just started this problem. Thanks in advance.
  2. Willie X
    Willie X Registered User
    8,067
    29
    The fly at the top of the movement is probably loose on it's shaft. Test by holding the fly's shaft stationery with one finger and turning the fly. You should feel some resistance. No resistance ... best to remove the fly to restore the tension/friction.
  3. blindowl1234
    Mar 19, 2017
    #3 blindowl1234, Mar 19, 2017
    Thanks! I didn't see a fly unless I can't see it. I attached a pic of the inside. ABC1Cuckooguts.jpg
  4. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    Here are two pictures of a similar movement- although not lyre - showing where the fly should be and yours with a red arrow pointing to the arbor where the fly should be attached. Note that the fly is quite small. On mine it is approx 12 x 24 mm.
  5. blindowl1234
    Mar 19, 2017
    Ok I see it in the picture now. Looks like a project for next weekend maybe. Thanks
  6. THTanner
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    Timesavers, Black Forrest and others have fans and fan blanks if you need some
Similar Threads - Cuckoo chimes cuckoo's Forum Date
Regula Cuckoo Clock Movement Change Clock Repair Tuesday at 5:34 PM
Cuckoo clock chimes too much and door doesn't shut Clock Repair Feb 22, 2016
cuckoo clock chimes 5 minutes early Clock Repair Jan 21, 2014
Cuckoo chimes early and doesn't stop correctly Clock Repair Oct 29, 2011
Cuckoo clock erratic chimes/cuckoo Clock Repair Jul 19, 2010
