Cuckoo Bird question
Discussion in 'Clock Repair' started by Muggie, Aug 12, 2017.
  1. Muggie
    Muggie Registered User
    Aug 11, 2017
    24
    Hi,
    First I'd like to say that I'm a complete novice at repairing cuckoo clocks.
    Uhm, so I was given this Hubert Herr cuckoo clock to examine and clean for someone.
    But one thing I notice is that the bird door opens 3 times at say 3 o'clock instead of opening once and doing three cuckoo sounds.
    It seems odd and I have no idea if this is normal for this model cuckoo clock or not.
    View attachment 353289 View attachment 353291 View attachment 353290
    Any help will be appreciated, thanks.
    Charles Blount
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    It is not normal. These movements have several methods
    to latch the bird out. I don't have a movement like that handy
    so can't tell you how it works on this movement.
    Some have a piece that rotates and some have a bar that drops
    down.
    It is likely the result of in appropriate oiling in the past. There
    are a lot of parts on a cuckoo that should not get oiled.
  3. shutterbug
    34,378
    32
    That clock looks like it has some age to it. It should be noted that cleaning (and especially intact cleaning) won't do anything to fix the natural wear that has occurred.
  4. bangster
    bangster Super Moderator
    16,331
    22
    There's a latch that catches the bird perch wire when the bird pops out, and holds it until the cuckoo is finished.
    For some reason, it's not working. Remove the lefthand whistle & bellows, and check that side of the movement. You may be able to spot the problem.
  5. bangster
    16,331
    22
    Follow this wire up to the top, and you should spot the problem.
    [​IMG]
  6. Muggie
    Aug 11, 2017
    24
    Hi,
    Ok thanks. Tinker that was my first concern when I received it - too much oil basically everywhere :)
    I did not use any fancy cleaning stuff, just a diluted rust remover (with sulphuric acid as ingredient) and water combination, left it in there for 15min
    and then cleaned with dishwashing liquid in warm water. Cleaning with a toothbrush and small paintbrush afterwards.
  7. Muggie
    Aug 11, 2017
    24
    Hi bangster, ok thanks, that makes sense yes. Will have a look at that section and report back with pictures.
  8. Willie X
    Willie X Registered User
    8,084
    29
    #8 Willie X, Aug 12, 2017
    The latch is dependant on its linkage being pushed past the latching point. Adjustment is done by slightly bending that wire that angles downward, just inside the right side door. The perch latch is released and the bird and door slams shut. This is done when the rack drops completely down after the last count.
    Note, the clean-up you did would be considered a rinse. This should never be done with anything caustic. Reason being, that it is impossible to remove the caustic solution from anything except open surfaces. There are many areas of your clock where the caustic residue, along with some water, is now hiding!
    Next time use a petroleum solvent, like mineral spirits or Coleman lantern fuel. That way the material you leave behind won't cause future problems.
  9. Muggie
    Aug 11, 2017
    24
    Confusing and strange that in this photo I took before I started disassembling the clock, the pin is on the other side of the wire?
    Reason for this is to stop the bird functioning?
  10. Muggie
    Aug 11, 2017
    24
    Ok I made some more pictures, but I hope it will be of value regarding the problem.
    Anyway I followed the wire to the top and found the locking rod.
    This is the other side of the drop down lock pin.
    The front, I am still examining the movements by turning the sound chain sprocket and turning the minute hand to
    see how things work here.
    These pins on the gear wheel looks slanted to the side.
    Should I straighten them?
  11. Willie X
    8,084
    29
    The long wire pointing downward at the right side of the movement (as you face the clock) needs to be bent slightly inward. Enough to make the latch actually latch. The latch catch is that vertically movable bar at the red arrow in your first photo (last post). The latch hook is on the silver lever, inside the plates just bellow the latch bar.
  12. Muggie
    Aug 11, 2017
    24
    Thank you Willie, I have a feeling it is going to work with this adjustment you know. :thumb:
  13. Tinker Dwight
    13,680
    I have one on the wall, just like that with the bar that
    drops down. The previous own gave me the clock and said
    that it has never worked right, since new.
    I looked at it for some time before I realized that the slot
    was too narrow and that it would never have worked. I
    widened the slot by about .001 inches and it has been
    working fine ever since.
    Mine is an 8 day and they are generally fussier.
    The bar that falls must be clean with no oil or rust.
    Run slowly by hand, now that you have it out.
    The problem should be more easily seen.
    The pins on the wheel should be straight but I don't think
    they are the issue. If you straighten them, you take a
    chance of having them get loose on the wheel.
  14. Muggie
    Aug 11, 2017
    24
    Thank you Tinker, your thorough examination paid off, good for you to have noticed that,
    and you got the clock for free? - great!
    Now (with manual hand advance) I can see everything clearly and am satisfied as the bar (well cleaned) falls
    easily into place plus I notice the bird perch stays out for the full count now, only coming back inside after the
    number of cuckoos have sounded.
    And I did not put any oil on that bar :) just major places where various rods slot into the front and back plates.
    I used synthetic oil (actually from my ABU fishing reel) :)
    Those pins I left alone yes, but just cleaned them again (this time) with mineral spirits!
    Muggie
  15. Tinker Dwight
    13,680
    As a general rule for the future, only rotating parts get oiled.
    Pivots for levers and such should be dry.
    Teeth and pinions stay dry except a tiny amount on the escapement teeth.
    It really has to do with load. No load no oil.
    Oil accumulates dust, no matter what type. Dust can be abrasive
    as well as gumming up the oil.
    If a clock would run well without oil, that would be best.
  16. Muggie
    Aug 11, 2017
    24
    Wow ... thanks for all replies, hints, guidance re. my specific problem.
    Good news is it managed to help me fix this problem! :clap:
  17. Muggie
    Aug 11, 2017
    24
    #17 Muggie, Aug 29, 2017
    Ok, sorry ... stupid me, this is the correct way the pin and shaft should be (other way around) ... :screwball:
    But now the Bird does not go back into it's home ... :(
  18. shutterbug
    34,378
    32
    Does that lever retract at the end of the strike? If so, you have a return spring unhooked or broken (lower part of the perch wire assembly).
  19. Muggie
    Aug 11, 2017
    24
    Hi,
    It did not at first yes, so I fiddled with angle of the pin (on pedestal ) and also the height of the tail lift wire, and now it does :) ... phew !
    Another question if you don't mind .. about that pin on the pedestal - can it change the amount the door opens, say like less or wider open?
    Sorry, I should have updated the situation as I was watching it for a while now.
  20. shutterbug
    34,378
    32
    Yes, the length of the door wire effects how far the door opens. However, unless you suspect it's been modified, it's probably the correct length. The bird may not be moving far enough to open the door all the way. Check for the perch being obstructed at the bottom of the door opening.
  21. Muggie
    Aug 11, 2017
    24
    Oh ... and I did bend the lever inwards towards the pedestal shaft so that it's exactly parallel with the pedestal shaft (as opposed to in the photo I posted).
  22. Muggie
    Aug 11, 2017
    24
    Exactly ... I fixed that a few days ago. It was only a fraction too low and thus touched the bottom of the door.
    I used my US Made (PO) craft knife (previously used for balsa planes etc.) to cut a little off at the bottom as the door still covers it :)
  23. Muggie
    Aug 11, 2017
    24
    Yes I think its not the original wire. I looked at some other HH clocks wires and they are definitely not the same.
    Actually the door opens too wide for my liking, and the tail lift wire's shape is a problem in this clock, as it moves the door slightly while the birds sings.
  24. shutterbug
    34,378
    32
    OK, you can shorten it a bit then. Bend first, cut later :)
  25. Muggie
    Aug 11, 2017
    24
    Here is a photo I took when I first got the clock.
    The tail lift wire was way off and touching the opposite bellow !
    So at present I only have a basic idea (just guessing really) of it's shape and angle :(
  26. Muggie
    Aug 11, 2017
    24
    Yes I will try, as this wire is thinner as the original it should not be a problem, thanks :)
  27. Muggie
    Aug 11, 2017
    24
    One of this clock's previous owners did a lot of changes :(
    One of them is that he glued the sound boxes while there was holes in the sides (made by who-ever :))
    So I managed to loosen the sound boxes, as luckily only a little amount of epoxy was used and I used brass screws instead. :)
    Also the wood is very dry and I have Linseed oil that I used to apply to the unpainted areas :)
    Lots of stuff ... :)
  28. Muggie
    Aug 11, 2017
    24
    This is my sister's clock and seeing that it's women's month she will be thrilled when she sees it (they are on safari at the moment up north).
    Here where I am, in the Cape it's been very dry and dam levels are so low (25% - 80%) that unless we get a lot more rain soon
    we are in for a difficult summer season coming. :)
    :) Way off topic, but anyway some background info.:)
  29. shutterbug
    34,378
    32
    The bird wire should be straight and UNDER the tail. If it won't reach the bird, bend a couple of 90° angles so it isn't slanted upward like that. It doesn't need to be that long either.
  30. Muggie
    Aug 11, 2017
    24
    No.
  31. Muggie
    Aug 11, 2017
    24
    Thank you shutterbug, I decided to put a longer wire in and it seems to be now :)
  32. Muggie
    Aug 11, 2017
    24
    Thank you :coolsign: - I took about 2-3mm off and it worked like a charm! the door is perfectly still
    when the bird is doing the cuckoos :thumb:
    [video]https://plus.google.com/u/0/photos/photo/112809371052278395969/6461778684222632226?icm=false&iso=true[/video]
Similar Threads - Cuckoo Bird question Forum Date
Cuckoo Bird Tipping Wire Clock Repair Oct 2, 2017
cuckoo clock bird stuck Clock Repair Apr 2, 2017
Cuckoo Bird Arm Adjustment Clock Repair Feb 20, 2017
Cuckoo bird gone cuckoo Clock Repair May 24, 2016
Cuckoo Clock - Bird Arm Spring Clock Repair Jun 10, 2015
