Cuckoo amplitude.
Discussion in 'Clock Repair' started by POWERSTROKE, Apr 7, 2020.
  1. POWERSTROKE
    POWERSTROKE Registered User
    Jan 11, 2011
    956
    69
    This is a subject that I usually use to see the “health” of the way the clocks is running after it’s repaired or even before so. I have found that most cuckoos have about 3” total swing. Some even more. I have also seen some with less. I like to see 3”, but I have some pretty foood running clocks that have 2 1/4 or 2.5”. Both happen to be older Hubert herrs maybe from the 70s. They run and keep excellent time. They do have decent overswing though. How does this amplitude really come into the health of one of these? Are they all the same? Exceptions to the rule? Just wondering. I’ve also seen people on YouTube repair these clocks and seem to have had similar things happen with less than 3” of total swing. I can usually tell this visually even on you tube by how far past the edges of the outer chains the bottom of the pendulum stick goes.
  2. Uhralt
    Uhralt Registered User
    4,850
    575
    The amplitude is secondary and varies with pendulum length and how heavy the weights are, and other factors. The important thing is overswing. If you have a healthy overswing with visible recoil, all is fine.
    POWERSTROKE likes this.
  3. POWERSTROKE
    Jan 11, 2011
    956
    69
  4. shutterbug
    43,484
    1,241
    Yes. Over swing is the way to determine the health of almost any mechanical clock, including the balance wheel and torsion variety clocks.
  5. Willie X
    Willie X Registered User
    12,774
    984
    Also, the sound. The ticking should be a clean metalic sound that never wavers. Any variation in the sound indicates a flaw somewhere. I call this a 'soft tick' or soft ticking. When you hear this, beware. The clock may run OK for now but it's gonna come back to see you pretty soon!
    Note, soft ticking is especially common in cuckoo clocks.
  6. POWERSTROKE
    Jan 11, 2011
    956
    69
    Interesting. Not sure how to comprehend “soft ticking”. How would you fully describe that? If something is “soft ticking” how long would you expect it to run?
  7. shutterbug
    43,484
    1,241
    The soft ticking is caused by a lackluster EW movement. A healthy movement will spin the EW at full speed, slamming it into the pallets. If you don't see that quick response of the wheel being released and hear the accompanying solid snap of it stopping again, you have an issue in the time train somewhere.
  8. Willie X
    12,774
    984
    Power,
    Next time you have a cuckoo that stops now and then, put a beat amp on it and you will hear the soft ticks. There are no set rules but clocks that stop don't just stop suddenly, they stumble along with diminished power (soft ticking) and eventually stop. Willie X
  9. POWERSTROKE
    Jan 11, 2011
    956
    69
    Honestly, if snot yet had one that has stopped on me after repair yet.
  10. Chris M.
    Chris M. Registered User
    Sep 15, 2018
    172
    Can someone describe over swing to me? Definitely can appreciate soft ticking. A movement that I have been working on was ticking so quietly that I could barely hear it - it stopped over night and had to take apart and redo. Subjectively, I can tell when a cuckoo is a "strong ticker" and when it is a "weak ticker". Weak tickers always worry me. Strong tickers make me happy.
  11. Uhralt
    4,850
    575
    Overswing is the amount the verge keeps lifting after the tooth has been released. Or, more easily to observe, it is how far the pendulum keeps moving in the same direction immediately after a tick, before it changes direction.
  12. Willie X
    12,774
    984
    On a cuckoo, or any recoil escapement, you can guage it by how far the escape wheel moves backwards at each tic. No backwards movement would indicate no overswing. The clock may run but it will be a finicky/undependable clock.
