Cuckoo accuracy
Discussion in 'Clock Repair' started by POWERSTROKE, Oct 29, 2019.
  1. POWERSTROKE
    POWERSTROKE Registered User
    Jan 11, 2011
    52
    What is considered a good accuracy for a cuckoo clock? What is the best way to achieve this....
  2. shutterbug
    40,242
    622
    I've had some that were quite accurate (a couple minutes a week). You just have to fiddle with the pendulum leaf a bit.
  3. Willie X
    Willie X Registered User
    11,719
    605
    Within a minute or two per day is good.
    WIllie X
  4. POWERSTROKE
    Jan 11, 2011
    52
    I have one at 40 seconds a day fast and one at a minute fast. When do you stop and feel happy.
  5. Uhralt
    Uhralt Registered User
    3,655
    341
    You stop when you feel happy. The more clocks you have the more tolerant you get (at least that was the case for me).
  6. shutterbug
    40,242
    622
    Some people are always messing with clocks. They don't realize that many things affect the time keeping, including temperature and humidity. ;)
  7. Willie X
    11,719
    605
    You don't have to stop ...
    WIllie X
  8. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    2,790
    224
    Science teacher, writer
    Lancaster, Ohio, USA
    A cuckoo clock should, in theory, have the same accuracy as any long-case or regulator clock because it's weight-driven and uses a pendulum for a time base. I'd guess that the major cause of inaccuracy would be that silly pendulum-rod suspension, possibly followed by eccentricities in the gear train.
    M Kinsler
    the little guy with the zither does his best, too.
  9. POWERSTROKE
    Jan 11, 2011
    52
    #9 POWERSTROKE, Oct 29, 2019
    Do you folks have a general recommendation in regulating a cuckoo? For instance, how long in between should you be adjusting? Is an hour enough or do you need to wait A whole wind cycle?
    when you make the adjustment on the pendulum, how far are you moving it for any given loss/gain. The leaves can be tight, so hard to say how far youre moving sometimes As it’s not a very fluid motion moving that leaf. Are you measuring with a ruler to see how far you need to move the leaf because of the above? How much should it generally be moved for any given inaccuracy? Finally I read a post by Howard Bain that said most cuckoos can be regulated to witching 1 minute a week. I’d love to have known how he did this.
  10. kinsler33
    Aug 17, 2014
    2,790
    224
    I'd screw a fine threaded rod into the bottom of the pendulum rod, and then screw a smallish lead weight onto that
    threaded rod. This would allow the pendulum assembly's center of mass to be moved up or down perhaps 0.2mm at a time.
  11. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,572
    67
    Cabinetmaker,clock repair
    Moultonborough,NH
    The pendulum rod suspension might appear to be silly however, I call your attention to a Welch Patti style movement that used the very same style for a number of years. And I can say that accuracy in time keeping in my experience has not ever been an issue with that style of movement.
    Just sayin'
    tom
  12. Uhralt
    3,655
    341
    I would wait at least a winding cycle, or even a week before making any adjustments (unless time keeping is very far off). If you want to get close to the 1 minute a week, a daily deviation would be just 1/7 of a minute which is impossible to read on the dial. What also speaks against making too may adjustments is that the pendulum rod wears where the leave is pushed up and down. Over time this leads to a thinner part somewhere in the middle of the regulating range and the leaf (or whatever the bob looks like) will tend to migrate to that thin spot, especially when it has been set slightly above that spot.
  13. POWERSTROKE
    Jan 11, 2011
    52
    thanks! With that being said, what is considered a leave it be type of adjustment. At one point are you happy with accuracy?
  14. Uhralt
    3,655
    341
    For a cuckoo I would be happy with around 5 minutes a week. Remember, that clocks with wooden pendulums will run faster in low humidity conditions and slower in high humidity conditions. When you just think you've got it right, the weather changes....
