Crystal size questions
Discussion in 'Watch Repair' started by Howdydave, Sep 17, 2019.
  1. Howdydave
    Howdydave Registered User
    Oct 23, 2017
    267
    31
    Former Software Appl. Eng. / Technical Writer
    Rochester, NY
    I just obtained a size 16 Waltham Vanguard circa 1926 with an AWC Co. Toronto case.
    The case is a Fortune and I am attempting to determine the crystal size.
    I haven't had any luck finding tables anywhere.
    The case serial number is 3911141.
    If I am measuring it accurately, I make the crystal size to be 20 13/16 or 46.9 mm.
    Does that sound right?
    Many thanks.
  2. Rick Hufnagel
    Rick Hufnagel Just Rick!
    NAWCC Member Donor Sponsor
    Oct 25, 2018
    1,209
    1,504
    Plumber
    Pittsburgh pa
    Howdy, Dave.
    If you remove the crystal, you can measure the existing crystal, or the opening, with a caliper for a precise measurement.
    Even two watch cases that are seemingly exact may have slightly different sizes.
    If you measure the bezel, do so across the diameter of the opening in a few different spots. For example, between 3 and 9, then 12 and 6. This ensures that it is a consistent size.
    Howdydave likes this.
  3. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    4,814
    2,207
    New York State
    What's wrong with the existing crystal(looks good in your photos)
    For me, I replace all plastic crystals immediately with glass. If the existing glass crystal has a few scratches
    I don't make any changes (as it matches the patina of the watch case). If it's
    chipped or cracked(or very scratched) I replace them as well. Plus when I break them myself, I need to replace them
    as well(broke a few hunting case crystals recently);).
    I would look up in google Dave's Watch parts
    he has everything you need(including good advice).
    Rob
  4. viclip
    viclip Registered User
    Jul 20, 2018
    568
    358
    For a 16s watch with your bezel configuration, I'd expect the crystal size to be about 43 mm or 19 lignes.
    If there are slight scratches on the existing crystal (glass), these can be polished out by hand. Indeed I've polished out fairly deep gouges in some of my crystals, albeit beginning with wet/dry sandpaper.
  5. Howdydave
    Oct 23, 2017
    267
    31
    Rochester, NY
    #5 Howdydave, Sep 17, 2019
    Rob,
    The crystal is fine, there is just an entry in Pocket Watch Database for the crystal size that I wanted to fill in.
    My watch has a glass crystal that is in good shape and I'm not going to screw around with removing it because I tried that with an older watch one time and I broke the crystal due to the fact that the glass had become very brittle.
