Crystal regulator spring is a little tired
Discussion in 'Clock Repair' started by woodlawndon, Nov 12, 2019.
  1. woodlawndon
    woodlawndon Registered User
    Jan 18, 2017
    608
    119
    Woodlawn, Ontario
    #1 woodlawndon, Nov 12, 2019
    This is from a French crystal regulator. Guess that's why it had trouble running...
    I think 8 pieces of spring is a record for me.
    Don
    *Edit* Make that 10 pieces, found two more on the floor.
  2. shutterbug
    40,799
    732
    A spring in a barrel, that breaks when nearly fully wound, goes through a chain reaction that cascades like dominoes. We've seen some examples here over the years that had dozens of pieces as a result. It's a little odd though that both your innermost coil and outermost coil broke.
  3. Uhralt
    Uhralt Registered User
    3,868
    388
    Probably one broke as a consequence to the shock that happened when the other broke.
  4. Kevin W.
    Kevin W. Registered User
    21,688
    223
    Thats a unusual thing to happen i would think.
  5. Willie X
    Willie X Registered User
    12,019
    699
    Someone has the record at around 80 pieces.
    You will probably need to replace that one ... :)
    WIllie X
    woodlawndon likes this.
  6. Uhralt
    3,868
    388
    Maybe rivet all the pieces together?
    It seems that the clock has once been cleaned with the complete barrel/spring assembly submerged in aqueous cleaning solution. There's a lot of rust. Probably that contributed to the catastrophic failure.
  7. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    2,911
    257
    Science teacher, writer
    Lancaster, Ohio, USA
    A broken mainspring in a wind-up phonograph will yield a barrel filled with a pudding that consists of 50% graphite grease and 50% half-inch-long pieces of 1" wide spring. I have these tinkling all over the basement floor to this day. These machines have two mainsprings, each in its own barrel, and only one broke. There was no further damage.
    I had a 400-day shattered mainspring once, but I think that was all.
