Crystal Regulator Doors
Joseph Superfine
Sep 13, 2009
207
88
Can someone help me find where I can obtain the very tinny screws that hold the brass door frame together on a crystal regulator door.
Burkhard Rasch
Jun 1, 2007
4,941
208
65
Twistringen
I´d try with an optician,the small skrews fo the old-style glasses (like mine) might fit.
Burkhard
the 3rd dwarve
Nov 3, 2000
686
25
I have a stock of small machine screws, what size, pitch, material, and head configuration are you seeking?
D~
Joseph Superfine
Sep 13, 2009
207
88
Thank you for the reply.
The screw size is .050 - 1.25
Would you know where I can get a tap & drill for these screws?
the 3rd dwarve
Nov 3, 2000
686
25
Joe,
I am unable to help you because I don't understand your size designation.
The first number should designate the screw size. The second number is the thread pitch.
1.25 is a standard metric pitch but on larger threads.
What does the .050 designate? Is it measured in MM?
D~
BLKBEARD
Nov 15, 2016
759
24
CT
sailorsandsettlersantiques.com
I don't think your giving the needed info. It seems your measuring thickness & length. If you have a jeweler or an optician nearby who does repair they will probably be happy to measure a screw for you.
Once you know that, sourcing a replacement will be much easier.
166,191
1,447,873
86,723
CrisWinston
2,882
