Crystal Regulator Case Doors
clockmanjoe
Dec 12, 2014
37
I am looking for the following doors for crystal regulators with or without glass.
2 doors - 5-1/8" x 7-7/8"
2 doors - 4-5/8" x 7-7/8"
1 door - 4-1/4" x 6-15/16"
2 doors - 4-13/16" x 8-7/16"
Thank you for your anticipated help.
clockmanjoe
tom427cid
Mar 23, 2009
1,671
106
Moultonborough,NH
I would almost think that looking for that many doors it might be simpler to have some brass milled out and make your own.
Just an idea.
tom
MartinM
Jun 24, 2011
3,091
El Dorado, CA
Would you know of a place that sells milled brass?
There are guys on the big auction site that will cut sheet brass up to 1/4 inch thick to the dimensions you specify and charge by the square inch.
If you had them cut long strips, a local machinist should be able to clean-up the shear-cut edges and put in a channel. You might even have them shave the ends to make your mitres.
You could do it by hand; But, it'd probably not look great, once assembled.
167,201
1,457,052
87,366
PhilGoodew
