Cross slide shoe
Discussion in 'Horological Tools' started by Tokei, Feb 26, 2015.
  1. Tokei
    Tokei Registered User
    Sep 16, 2009
    34
    #1 Tokei, Feb 26, 2015
    Hi all,
    I recently bought a cross slide for my Peerless lathe.
    It's a Boley Leinen. That means it doesn't rest flush with the lathe bed.
    I was reading up on some old threads that this type of slide needs a shoe.
    Couldn't find any example on the web so decided to make my own.
    (hand tools guys, sorry)
    I'm attaching a couple pics. Hope it's helpful for anyone with the same issue.
    Works great and stays nice and firm without having to tighten the nut too much.
    That could risk cracking the t-slot in the slide.
    Tokei
    PS. The half round brass bar rests against the front of the lathe bed. Does anybody have a solution for the damaged slide top T-slot ?
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    72
    Can you turn the top around, 180 degrees?
  3. Tokei
    Sep 16, 2009
    34
    Hope these help
  4. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    Actually, I think Tinker's comment was a suggestion and not a request for for more info.
    But, with the new pictures, I don't see any way to do what Tinker was suggesting.
  5. Tokei
    Sep 16, 2009
    34
    Lol Martin guess I'm kinda slow today.
    But no there's no way to turn the top to use the good side.
  6. MartinM
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    I'd think there would be some kind of a secondary parts market for something like that, as, I'd bet most of them got replaced due to problems with the leadscrew or tool post.
  7. trim
    trim Registered User
    Feb 19, 2010
    151
    I have seen this damage fixed somewhere on the web - I don't have the link unfortunately.
    They simply milled off the broken top sections and screwed on two new plates to form the top of the slots. It actually looked OK, and was 100% functional.
    I have read that this problem can be caused by the style of tool holder you have. I was not convinced of the argument either way.
  8. Tokei
    Sep 16, 2009
    34
    Martin:
    Wish there was a market for parts but haven't seen one yet
    Trim:
    I'm sure I saw it too. There was a site showing such a repair but it was a while back and can't find it anymore
  9. tsmith
    tsmith Registered User
    Nov 5, 2008
    161
    Geologist
    Cypress, TX
    I would think milling off the broken areas and brazing a replacement top would also work or maybe a combination of the two if you think the brazing lacked strength by itself. The replacement sections would be easy to fabricate and depending on the mount, would share the load with the unbroken slot.
  10. Tinker Dwight
    13,666
    72
    I'd say the milling and plates would be better.
    Most likely stronger than the original cast parts.
  11. Herschel
    Herschel Registered User
    Aug 13, 2019
    19
    I don't get what the half round brass bar is for? I would like a cross slide for my peerless and wondering what kind of cross slide would work. Good information I just don't get the brass bar thing.
  12. wefalck
    wefalck Registered User
    Mar 29, 2011
    551
    39
    Geochemist (Consultant)
    Paris
    To align the shoe perpendicular to the lathe bed, to align in turn the cross-slide.
    Normally there would be a kind of shoe sitting on top of the lathe bed with its negative profile. The sides of it would be absolutely perpendicular to the bed and the exact width of the recession in the cross-slide.
    Other types of cross-slides are flat at the bottom and there is a kind of stop with a key on top that fits exactly into the T-slot of the bottom. The stop has surface exactly perpendicular to the key, thus aligning the cross-slide.
  13. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    2,280
    878
    Watchmaker
    Baltimore
    It may have been me. Ten or fifteen years ago I pulled one of those lantern toolposts through my Levin Side rest and repaired it by milling the damaged section off, brazing a new plate and cutting the slot. Then I made a better toolpost.
    The problem is the lantern post where the toolpost key/clamp is smaller in OD than the adjusting nut. You can pull the clamp through like a punch press die. "Do not overtighten" is a subjective term!
    Below is a pic. Everything is soft to begin with (else you could not drill/modify these like many have; or by repairing with drilled holes for screws.). Surface grind the upper plate after the repair and all is well.
  14. Herschel
    Aug 13, 2019
    19
    Thank you I thought it would be to align it but he said it rest on the front of the lathe bed. Maybe it hangs off the tailstock end and rest against the end of the bed. I guess that would somewhat align it
  15. measuretwice
    measuretwice Registered User
    Jul 28, 2019
    50
    Toronto
    That looks really good...I've a similar repair pending for a boley slide rest. imo these messed up t slots are so common with these small lathes because of that style of tool post. If the tool post bolted into proper T nut of a decent length there would be a much longer section of T slot taking the load. You also end up with a lot of leverage with tool overhang with this style
