Count lever and locking lever.
Discussion in 'Clock Repair' started by crossie, Sep 11, 2017.
  1. crossie
    crossie Registered User
    Nov 3, 2012
    84
    Hi All,
    I have purchased a cuckoo clock from Ebay that was advertised as a 'vintage Russian cuckoo clock for collectors'. It was working, but was very dirty inside. I decided to rebush, polish pivots and clean the movement. When I put it back together I found that I had a problem. It has a count wheel strike, which I am not familiar with, and is the first time that I have come across one. The count lever goes down into the notch of the count wheel and the lever catches on the detent at the same time. Then the count lever rises up and carries on chiming continuously. Also the weight on the chime side drops to the floor instead of locking.
    I have had it apart many times but to no avail, and it is now driving me nuts. Any help would be very appreciated.
    Many thanks Crossie
  2. shutterbug
    shutterbug Super Moderator
    34,652
    45
    I'd suggest taking that count wheel off, and see if the locking lever and pin will stop the clock that way. If so, put the wheel back on so the deep notches match where the lock occurs.
  3. gleber
    gleber Registered User
    Jun 15, 2015
    774
    Downingtown, Pennsylvania USA
    It is hard to tell from the photos whether this uses the same levers as a traditional American count wheel clock, but you might want to review the design and operating sequence found at: https://mb.nawcc.org/showwiki.php?title=Count_Wheel_Basics
    I would check to see if it has a stop/warning pin, as I suspect that is not synchronized properly with the other levers and the locking lever doesn't catch this pin. Hopefully it is a simple adjustment of the wheels to get things sync'ed up properly.
    If you still have problems, better photos of the movement would help.
    Tom
  4. crossie
    Nov 3, 2012
    84
    Hi shutterbug, thanks for your suggestion,I tried that but alas it did not help, I will try glebers way,it has a stop warning pin but I need to have more information on how to synchronise the wheels. crossie
  5. shutterbug
    34,652
    45
    Sounds like you'll be splitting the plates again. It's all part of the learning curve :)
  6. crossie
    Nov 3, 2012
    84
    Hi gleber,sorry I took so long to reply to your comments to my post,you were right it was not synchronised properly, it took a few goes to get there but I got there in the end, thanks,crossie
  7. gleber
    Jun 15, 2015
    774
    I'm glad to hear you got it working.
    Tom
Similar Threads - Count lever locking Forum Date
New Haven restoration-Count wheel/count lever Clock Repair Aug 30, 2017
Old PHS Wall Clock Count Lever Adjustment Clock Repair May 6, 2017
Adjusting a low lift lever on a count wheel strike Clock Repair Jan 22, 2017
Count wheel lever assembyl Clock Repair Nov 15, 2015
Count Lever Notch Clock Repair Nov 3, 2015
