Cord Replacement - wires broken at motor
Discussion in 'Electric Horology' started by semiretiredman, Mar 1, 2017.
  1. semiretiredman
    semiretiredman New Member
    Mar 1, 2017
    There is little left of the wires on this 1934 Hammond clock. I need advice on making a safe and lasting repair.
  2. shutterbug
    shutterbug Super Moderator
    34,641
    I never liked how they originally wired those things. To make a good repair, you'll have to carefully get back to the coil wires, make a connection with new wires, and secure it all again. I think they originally just used electrical tape to wrap around the coil after connection to keep things secure. I can't offer a better way, but wish I could!
  3. David S
    David S Registered User
    NAWCC Member Donor
    Dec 18, 2011
    5,888
    23
    Brockville, On Canada
    davefr over in the electric forum may be able to give some advice.
    David
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Get the back cover off as best you can. Try to not move the
    power wires around. You don't want to stress them at the coil.
    Once you have a clear shot at them, cut them from the coil.
    Usually there is a lug or something that they are soldered to.
    I recommend replacing them with a smaller power cord. Many of the
    cords that are used with computer power packs are good.
    If the lugs are loose be especially careful. You might even use
    a little epoxy to secure them.
    Do not try to remove the old soldered wire left from the power
    cord. There is no safe way to do this without skills most don't have.
    If you break the fine coil wire, it will be a more serious issue.
  5. davefr
    davefr Registered User
    Nov 29, 2008
    353
    Semi Retired Engr. Mgr - Currently Rebuilding Tele
    Oregon
    #5 davefr, Mar 2, 2017
    ^^^Excellent advice.
    You do need to be extremely careful because the coil wires are about the thickness of a human hair and will break off very easily if stressed. It's best to do this under magnification.
    If all you have left is little stubs of the coil's magnet wire then don't try and solder on a thick power cord. Instead, attach some smaller wire like a 20-24 AWG stranded THHN to the coils magnet wires and then attach the power cord to the THHN. (less stress). You'll need to remove the varnish from the coil's magnet wires in order to solder to them. An Xacto knife will do this but you have to be extremely careful not to break off the wires.
    Heat shrink works well to insulate your splices.
    You'll likely need to rewrap the core of the coil to secure/insulate the wiring and provide some strain relief. I use 3M #27 glass cloth tape. (don't use common electricians tape).
    https://www.amazon.com/Corrosion-Resistant-High-Temperature-White-Glass/dp/B00O7S124E/ref=sr_1_3?s=sporting-goods&ie=UTF8&qid=1488479959&sr=8-3&keywords=3m+%2327+glass+cloth+tape
    An even better solution is to slip a piece of large diameter heat shrink over the core of the coil and heat it until it completely compresses around the coil's core. 35-40mm 2:1 heat shrink should be about the right size.
    https://www.amazon.com/uxcell-Meters-Polyolefin-Shrinking-Shrinkable/dp/B009INJX7G/ref=sr_1_1?ie=UTF8&qid=1488478835&sr=8-1&keywords=35mm+heat+shrink+tubing
    Once your repair is complete secure the power cord to the motor frame with tie wraps for stress relief.
    Good luck because this type of repair is pretty tough and unforgiving!!
Similar Threads - Cord Replacement wires Forum Date
help needed with ibm master weight driven clock weight cable replacement Electric Horology Jan 29, 2017
Herschede Electric Tambour cord end? Electric Horology Nov 8, 2013
Power cord for old electric clock ? Electric Horology Jul 1, 2013
Seth Thomas No. 1700 Power Cord Issue Electric Horology Dec 22, 2012
Female cord connector for a New Walnut Telechron 700 Electroalarm Electric Horology May 4, 2012
